Old 08-14-2009, 01:43 AM   #1
desertrat21
Member#: 206784
06 sti
aspen white
Default How much torque on lugs for track days
I'm just curious what you guys torque your lugs to for track days? Any different than regular driving
desertrat21 is offline   Reply With Quote
Old 08-14-2009, 02:18 AM   #2
Web Foot STi
Member#: 39086
2004 STi
Stock is good. Do you want to suck your lug nuts through your wheels?
A re torque isn't a bad idea...
Web Foot STi is offline   Reply With Quote
Old 08-14-2009, 07:36 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I usually do 75 ft. lbs. Torque them before every session. Do NOT torque them after you've just come in from a session and everything is hot.
Old 08-14-2009, 09:21 AM   #4
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
So, when you retorque them before a sesion, do you loosen them first?
mmiller2002 is offline   Reply With Quote
Old 08-14-2009, 10:11 AM   #5
mav1c
Hoodbridge!
Member#: 560
No. Just check them. 99% of the time they won't budge, but it's that 1% that you need to worry about. It's also a good check to make sure you haven't cracked/broken any lug studs.
Old 08-18-2009, 12:05 AM   #6
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
After you mount your track tires,go out in the paddock (or parking lot depending on the track layout) and do a few figure eights at a low speed, then retorque. 75 foot pounds should be fine, I think that is what my torque wrench is set at.
bcblues is offline   Reply With Quote
Old 08-18-2009, 12:27 AM   #7
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Hmm been using like 90 on track days....too much then?
I usually go over them with 85-87. Then do some eights and reclick with 90lbs?
Oops
Wrx_Fan_0717 is offline   Reply With Quote
Old 08-18-2009, 03:23 AM   #8
STi-MAN
Member#: 70252
05 STI
blue
I usually do 73 lbs and never had a problem.. only problem with over torquing is sometimes you brake wheel studs. or i have in the past.
STi-MAN is offline   Reply With Quote
Old 08-18-2009, 07:31 AM   #9
mav1c
Hoodbridge!
Member#: 560
Oops
Too much. Highest I'd go is 80.
Old 08-18-2009, 07:08 PM   #10
Wrx_Fan_0717
Member#: 152080
Damn alright....80 it is.
Old 08-18-2009, 09:31 PM   #11
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
I haven't tracked my car yet, but am I missing something here. My wheel torque is my owner's manual says 58-72 ft/lbs and my shop manual says 65.7 ft/lbs. I always torque to 65 and have never had an issue on street or at an autocross. 80 ft/lbs or higher seems really excessive to me.
SubySal is offline   Reply With Quote
Old 08-18-2009, 09:55 PM   #12
WickedSTI
Member#: 39408
WickedSTI is offline   Reply With Quote
How much torque on the case bolts??? w/arp case bolt kit hectowrx Built Motor Discussion 6 10-08-2008 08:55 PM
how much torque for wheel lugnuts? stisp33d Vancouver Impreza Club Forum -- VIC 12 02-10-2004 03:58 PM
How much torque for the engine drain bolt? Impreza01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-21-2003 08:20 PM
what to put on car for track day protection Jerry Seagreaves Interior & Exterior Modification 1 02-28-2003 12:36 AM
How much torque? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2001 01:51 PM
