Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 08-14-2009, 02:17 AM   #1
wrxmuch?
Member#: 196486
2004 WRX
Default Not hitting target boost 2004 wrx stage 2
My 2004 wrx wont go above 12.8 psi. I have turned the wastegate arms 2 turns shorter. This allowed the boost to come on much faster it seemed but doesnt raise the max psi shown on my ap.
Should I do the 3/16th's mod next?
P.s. I've tightened all my hoses and checked for leaks. The only thing I havent tried is the HWG map.
HWG is use at your own risk so that kinda makes me do:
wrxmuch? is offline   Reply With Quote
Old 08-14-2009, 05:37 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
is you car tuned? or is it stock ecu?
oops saw you have ap..
i would check for the restrictor in vacuum line from turbo
compressor to wastegate.
Old 08-14-2009, 11:18 AM   #3
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
What maps are you using? I take you are using an ots map because you have mentioned target boost. What is your target boost? 16.5?
I would try the HWG, if you try it once and hit a fuel cut then its not for you. Generally speaking hiting a fuel cut once isnt going to blow your car up. It is a saftey feature afterall. You could start testing it out by going slowly with the throttle and watch the AP. Any OTS map has a use at your own risk principle to it. They are designed for the masses and there is always a risk no matter how minute ..
Dubstar112 is offline   Reply With Quote
Old 08-15-2009, 12:20 AM   #4
wrxmuch?
Member#: 196486
2004 WRX
I'm using the ots 1.30 stage 2 93 octane map. I'll try the HWG map.
Old 02-19-2013, 10:39 PM   #5
sureshot007
Member#: 142405
#716 G2 OBS
Did you ever figure this out - I can't seem to get about 13psi.
sureshot007 is offline   Reply With Quote
Old 02-20-2013, 12:35 AM   #6
Wrex Roller
Member#: 292110
2003 WRX
wrb
I know on my my WRX I went stage 2 and the shop doing the reflash notice i was only running 9psi of boost no matter what. The problem ended up being I was missing the resistor pill on the vacuum line. hope that helps some
Wrex Roller is offline   Reply With Quote
Old 02-20-2013, 10:53 AM   #7
Mosting3
Member#: 296753
2005 V7 JDM STI swap
@ what gears u guys don't see the boost u want? 1st gear?
Mosting3 is offline   Reply With Quote
Old 02-20-2013, 10:56 AM   #8
sureshot007
Member#: 142405
#716 G2 OBS
Any.
I'll check to see if the restrictor pill is in there. I bought the car mechanically stage 2 with no tune, so I've just been trying to tune it, and no matter how tight my wastegate arm is (or WGDC tables), the boost doesn't change.
Old 02-20-2013, 11:07 AM   #9
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Be on the look out for exhaust leaks pre turbo. Also be sure to make sure you dont have the catted up pipe still. If you do, it can disintegrate(the cat material) at any point and take your turbo with it. It also keeps your EGTs high and prevents you from boosting to the higher PSIs
endrswrd is offline   Reply With Quote
Old 02-20-2013, 11:08 AM   #10
sureshot007
Member#: 142405
#716 G2 OBS
I had smoke tested for leaks, and that's all good. Previous owner said he just installed an STI uppipe.
Old 02-23-2013, 02:23 AM   #11
dollar5th
Member#: 324540
Boost leak test?
dollar5th is offline   Reply With Quote
Old 02-28-2013, 02:56 AM   #12
Decepticon wrx
Member#: 348548
I just went stage 1 in my wrx and only hitting 7 psi. Target is 13.5 so I called cobb and they told me to check my resistor pill. Looked at it and the hose was taped where it should be. Ordered a pill thinking it had to be missing since it was taped up. Ill find out Tuesday or Wednesday if it is that and ill let you know.
Decepticon wrx is offline   Reply With Quote
Not hitting target boost on Gabedude's stage 1 map NJ2.5RS Open Source Reflashes 19 08-12-2010 01:05 AM
Stage 2 = not hitting target boost. t4nk AccessPort 3 04-12-2007 09:41 PM
Target Boost 05 Wrx Stage 2 Rdwrc AccessPort 2 11-20-2006 04:05 PM
Who has used an MBC to hit target boost on cobbs stage 2.5? blackie Engine Management & Tuning 2 04-01-2005 02:28 PM
AP stage 1 not hitting target boost line Engine Management & Tuning 8 02-20-2005 10:27 PM
