![]() Tire & Wheel Forum sponsored by The Tire Rack |
#26 | |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, 1,000,000 whp 2 aw tq |
#27 | |||
Thanks Sir Alex!
Moderator Member#: 88606
Vehicle:2011 GMC Sierra 1990 Miata |
![]() Quote:
#28 |
Member#: 204121
TXIC
Vehicle:2005 WRX Wagon CGM |
Scooby, what color did you paint them? I like the wheels, but for some reason the factory silver color they come with makes them appear smaller. I like the gunmetal color you chose though. Any updates form Enkei or your supplier?
#29 | |
Thanks Sir Alex!
These wheels were painted Subaru's factory bronze that they use on the Leggy and Tribeca. I just had the shop put in more black to darken them up. They used 35% more black. Turned out fantastic IMO. They look almost black at night, but shine a bright bronze in the sunlight. If you're looking to have some wheels painted the same color I have the paint can/mixture percentages if you use a shop that has the PPG paint system. Perhaps when we get another sunny day up here in MI I can snap some pics of them out in the sun. |
#30 | |
Member#: 204121
TXIC
#31 | |
Thanks Sir Alex!
Gunmetal looks good on CGM. So did this bronze. I had both on my CGM WRX .Some candy for you since you're thinking gunmetal...rota torques ![]() These were my old winters in a rattle can bronze, the RPF-1s are a bit darker ![]() |
#32 |
Member#: 204121
TXIC
Thanks! You actually posted that first pic and last pic in my thread about which color wheels for a cgm WRX
. I like the gunmetal color b/c it's dark but just light enough to stand out from the tires, so I think I've ended up choosing the 17x9 DPT's in gunmetallic. But now that I see I could get the RPF1's in a similar color I think they're back on the list.Last edited by draco159; 08-18-2009 at 06:02 PM. |
#33 |
Thanks Sir Alex!
Update:
Got a call from Enkei last night. At current they aren't going to warranty the wheels. Having them painted apparently voided something. The customer service guy doesn't understand why, but that's what he was told. Being superb customer service he wants me to send the cracked wheel in so he can have it looked at and analyzed. He's going to keep pushing to have them warrantied. for Enkei's customer service! |
#34 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
wow.. scary stuff... Had a similar thing happen to the stock 17 inch aluminium wheels on my previous car.
And I am considering picking up some RC T4 wheels, but am afraid that since they are in a size that Enkei USA does not bring in, they might leave one in the cold.. ![]() |
#35 |
Thanks Sir Alex!
Update #2...
I got the tire dismounted from the wheel yesterday to box it up and ship it to Enkei. When I looked at the wheel again I noticed dark lines across the back side of the majority of the spokes. When I run a fingernail over the spokes I can catch a couple of the "lines"...more cracks. Now I'm really glad I caught the crack and stopped driving ![]() Pics coming when I can get them uploaded to the interweb. |
#36 | |
Member#: 43950
Vehicle:07 WRX LTD Wagon Satin White Pearl |
Mind you I have no idea the particulars of your stripping process. Wikipedia entry on Hydrogen Embrittlement |
#37 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
The Enkei US guys are very nice and will work with you resolve whatever they can. Unforunately, they do have to abide by the rules and by altering the finish of the wheel, you voided the warranty because they have no way to know if the work was done right or not. This was one of my worries when I powdercoated my Enkei ES-Tarmacs because I didn't want white wheels on a white car.
It's good that you can accept that wheels are a wear item like tires and it's even better that you inspected it. At least RPF-1s are still available and not very expensive. |
#38 | |
Member#: 39086
NWIC
Vehicle:2004 STi White |
These wheels were not baked. That is a heat treat/artificial age issue. They were striped with and aircraft chemical stripper. One that the FAA is ok with using on Al. They are kinda picky about such things. Those black lines on the other spokes is the typical wear debris that works its way out of a tight crack fretting and propagating. In the past I did a lot of fatigue testing of cast A356-T6 Al truck hubs and saw a lot of those black lines. Typically the initial one would be so tight that wet florescent dye penitent would not indicate, but wipe the black off and run for another hour, or so and the black line would be back. Sooner, or later that crack would take off, trip the limits, and you would have a box of broken parts. It's impressive when a hub disassembles itself at 1,200 rpm under 13,200 lb vertical and 6,600 lateral load... Glad that wheel the had enough belt and suspenders so that the whole spider didn't tear out at once. Looking at the photos again from the back you can see the relatively sharp corner where the parting line was ground. Perhaps this is where things started? I know inside radii get all the attention, but outside corners can cause problems too. |
#39 | ||
Member#: 43950
Again, I have no idea what alloy the wheels are made from or what potential issues the stripper and its related process pose, I'm simply suggesting the possibility that the stripping process weakened the wheel. Given many auto-x and open track guys run these wheels without issues, I wouldn't write off the possibility. Of course it's unlikely Scooby921 will be paying someone to autopsy his wheels, so we may never know for sure. |
#40 |
Thanks Sir Alex!
Pics...red paint marks outline what I feel are additional cracks. As mentioned yesterday, I can catch my fingernail on a couple of them.
#41 |
Member#: 72285
South East
Vehicle:2003 WRX PSM w/FXHID FLA Turnpike > I-95 |
Wow, you better go check your other wheels!!!
#42 |
Member#: 39086
NWIC
Interesting pics. I can now see why the cracks didn't start by the hub and did in the middle of the spokes.
My OEM wheels have the same sharp corner on the back of the spokes, but they do not have the grind marks I can see in the photos. I went and looked. (I'm not a fan of forgings over castings in fatigue however.) |
#43 |
Member#: 70252
Vehicle:05 STI blue |
i guess guys at the evo forums know that the rpf-1s are more prone to cracking then the nt03's. good luck with your wheels
#44 |
Member#: 115961
Vehicle:2005 STi Wagon WR BLUE |
Any Updates?
#45 |
Thanks Sir Alex!
Been awhile since I've gotten a response from Enkei. After a couple emails and voicemails they responded.
Warranty dept said no warranty coverage because they've been painted. The person I was working with, whom I believe is a sales rep and not a customer service person, said he'd sell me a new set for a discount since they shouldn't have cracked. I'm happy with that. I kinda figured I'd be SOL. But first he wants me to send the cracked wheel in to be analyzed. Perhaps they'll find a casting flaw and it will get covered. Can't hurt me since the warranty guys already looked at pics and said no. Perhaps the physical specimen will change things. UPS picked it up yesterday and I'm not sure how long it'll take. |
#46 |
Member#: 127232
W. Canada
Vehicle:Do You Even Subaru |
Nice!
You just find the number off their main website? |
#47 | |
Member#: 43950
#48 |
Street's closed, pizza boy
Member#: 17301
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
Did you ever hear back from them about this?
<- glad he never painted his Tarmacs since they don't make em anymore |
#49 |
Member#: 4326
Vehicle:2010 turdle |
Hate to bring this thread back from the dead but looking at where the cracks are on the back of the wheel, it looks very even throughout each spoke. Could these deep scratches/cracks have been caused by your calipers?? Reason for this inquiry is because I ran 17x9.5+38 (with a 5mm spacer, effective +33 front offset) on my STI and caliper clearance was MINIMAL at best (two, three sheets of paper clearance) and I have noticed some visible scratches from the caliper on it.
And any word from Enkei? |
#50 |
Member#: 103068
SCIC
<--- stupid guy for powdercoating his Tarmacs... but they are all bent to hell now. These things were not as strong as I thought they should be. Berms from the tracks, potholes and jumping things... ugh.
| Thread Tools | |
| Display Modes | |
| Platinum Autos sold broken head STi :[ | Drewbiehd | North West Impreza Club Forum -- NWIC | 43 | 03-30-2010 06:24 PM |
| WTT 17x8 Black RPF-1's for Silver BBS or Silver RPF-1 | MattD87 | Wheels/Tires | 3 | 04-22-2009 08:59 PM |
| Pics of Enkei RPF-1 in gold? | NightmareOnSubySt | Tire & Wheel | 39 | 03-15-2004 11:47 AM |
| Enkei RPF-1 final install pics | Cosworth | Member's Car Gallery | 39 | 05-09-2003 02:44 PM |
| Enkei RPF-1 teaser | Cosworth | Member's Car Gallery | 20 | 04-04-2003 07:43 PM |
