Old 01-29-2010, 01:46 PM   #51
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Originally Posted by slowguy View Post
Hate to bring this thread back from the dead but looking at where the cracks are on the back of the wheel, it looks very even throughout each spoke. Could these deep scratches/cracks have been caused by your calipers?? Reason for this inquiry is because I ran 17x9.5+38 (with a 5mm spacer, effective +33 front offset) on my STI and caliper clearance was MINIMAL at best (two, three sheets of paper clearance) and I have noticed some visible scratches from the caliper on it.
And any word from Enkei?
Thanks for bumping it. I've been forgetting to get back in here and update.
Marks are not from the brake calipers. There was plenty of clearance and I would have heard/felt any contact. I also looked over the other 3 wheels and they have the same marks in the spokes. Probably normal.
In any case the update is that Enkei called and requested that I send them the other three wheels. Not sure what they are going to do with them, but they are going to sell me a replacement set at cost. So its still an expensive "oops", but at least I'm not out $1100 to get a new set of RPF-1's.
Scooby921 is offline   Reply With Quote
Old 01-29-2010, 02:04 PM   #52
Web Foot STi
Member#: 39086
2004 STi
I had an Acusump blow it's top and Mecca cut me the same deal. At cost seams to be SOP. Still better than a sharp stick. Did they offer to show you photo micrographs of the fracture zone? They don't want those other wheels out there...
Web Foot STi is offline   Reply With Quote
Old 01-29-2010, 02:36 PM   #53
trick3d
Member#: 202146
2010 evoru
GG
trick3d is offline   Reply With Quote
Old 01-31-2010, 11:44 PM   #54
slowguy
Member#: 4326
Ah okay. Gotcha. Yah, at cost shouldn't be too bad and you're back on the road again with a new set
slowguy is offline   Reply With Quote
Old 02-15-2010, 03:44 PM   #55
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
New update...
Finally got everything figured out with Enkei. They checked the 3 other wheels I sent back and compared them to 12 other wheels they had in stock. Nothing looks cracked or out of the ordinary. They are returning those 3 wheels and sending and replacement for the broken one.
The cool/scary info...
They sent the broken wheel back to the main office/R&D/analysis group and they ran a bunch of tests. After taking measurements, running material analysis, and looking at the crack under microscopes they've determined the cause for the break. The outer portion of the wheel was twisted with respect to the hub mounting surface. The spokes were physically bent. Some extreme amount of cornering force caused a misalignment between the rim and the hub of the wheel and the spokes finally gave out.
Old 02-15-2010, 04:29 PM   #56
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
****... if i had heard that back, I'd probably feel pretty proud of myself
/me brags "I drove her so hard, the wheels gave out from under me!"
shane86 is offline   Reply With Quote
Old 02-15-2010, 04:29 PM   #57
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
New update...
s000000000000000.............the design isnt stout enough for the conditions encountered and associated hardware(tire) that was used....ie too little wheel for too much tire and vehicle weight?????
Old 02-15-2010, 06:19 PM   #58
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
You must be using some sticky tires and 3 wheelin' into a corner pretty good there. So now you have 2 sets of the same wheels?
ritky is offline   Reply With Quote
Old 02-15-2010, 10:52 PM   #59
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Wheels were used exclusively for auto-x for 3 years. 235/40r17 advan neovas and the car weighed in at 3200lbs with driver. Not the stickiest of wheels by any means. They're a hell of a street tire, but its no r-comp. And the wheels cracked within the first week I decided to start using them for DD use.
I can think of two possibilities...
1.) I bought the wheels used and its possible that the previous owner had beaten on them a bit and it simply took this long for the wheel to finally give out.
2.) There is one auto-x event I ran on an incredibly f'd up lot. There were two points on the course where the bumps were big enough to get the front end of the car airborne. Its possible I had the wheel turned going into one of those and caused the bend when the car landed.
Old 02-16-2010, 08:24 AM   #60
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
wheels are wear items....the fail just like all other man made mechanical objects
the fact that tires were changed quite recently makes me think that the issue was acclerated by that
Once again wheels are a wear items. This is why most race teams replace or service (inspect) at regular intervals.
CUNNINGHAM is offline   Reply With Quote
Old 02-16-2010, 12:35 PM   #61
littlewhitewagon
Member#: 103068
11 STI sedan
^^^Yup. I can't think of a better excuse to buy new wheels for my car.
littlewhitewagon is offline   Reply With Quote
Old 02-18-2010, 11:36 PM   #62
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
So much torque the wheel spokes twist off the line....
pinkertonpunk is offline   Reply With Quote
Old 02-19-2010, 12:02 AM   #63
JVD
Member#: 213130
He must have been stretching tires. Surely that was the cause.
Seriously though. Must be pretty weak to just twist like that from normal driving. Surprising.
Seems like they took care of you though. Wouldn't really stray me away from them. I've owned a set of SBC RPF's before. Such beautiful wheels.
JVD is offline   Reply With Quote
Old 02-19-2010, 12:06 AM   #64
Uncle Scotty
Member#: 16200
OK buy Nates beans
normal driving???
I think not
Platinum Autos sold broken head STi :[ Drewbiehd North West Impreza Club Forum -- NWIC 43 03-30-2010 06:24 PM
WTT 17x8 Black RPF-1's for Silver BBS or Silver RPF-1 MattD87 Wheels/Tires 3 04-22-2009 08:59 PM
Pics of Enkei RPF-1 in gold? NightmareOnSubySt Tire & Wheel 39 03-15-2004 11:47 AM
Enkei RPF-1 final install pics Cosworth Member's Car Gallery 39 05-09-2003 02:44 PM
Enkei RPF-1 teaser Cosworth Member's Car Gallery 20 04-04-2003 07:43 PM
