Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 08-14-2009, 09:32 PM   #1
Roel03
Member#: 127450
2007 WRX
Satin White
Default Tire size
I'm getting 17x8 5zigen fno1rc and i wanted to know what tire size i should be running. I do autox my car once a month and wanted to know which would be the ideal width. Thanks
Roel03 is offline   Reply With Quote
Old 08-15-2009, 12:14 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Ideally for autoX you would get the widest tire that you could fit on the rim. For a 17x8 rim with street tires I'd go with the Bridgestone RE-11's in a 255/40R17.
speedyHAM is offline   Reply With Quote
Old 08-15-2009, 10:17 AM   #3
recnelis
Member#: 92778
2000 Impreza 2.5RS
The widest and stickiest tire allowed by your class rules.
The widest and stickiest tire allowed by your class rules that you can afford and fit on the car without rubbing (badly).
recnelis is offline   Reply With Quote
Old 08-15-2009, 11:55 AM   #4
Roel03
Member#: 127450
2007 WRX
Satin White
ok thanks guys. i really appreciate your input
Old 08-15-2009, 12:23 PM   #5
alphaomega0
Member#: 147678
07 wrx
obsidien black
i guess if you want to avoid rubbing use lower profile if your allowed.. i am running 245 / 35 /18 on 18's and i dont have any rubbing issues, before i had the 40 profile and in hard cornering it used to
alphaomega0 is offline   Reply With Quote
Old 08-15-2009, 06:08 PM   #6
silvios203
Member#: 200163
2004 impreza sti
I have 17x8 rpf1 and running 245/40 on stock 04 sti suspension and have no rubbing and I think it's perfect. I think if you want 255 you may have to roll your rear fenders
silvios203 is offline   Reply With Quote
Old 08-15-2009, 06:14 PM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
your situation doesn't really apply. 245/40/18 is much taller than 245/40/17, which is nearly the same as the oem 225/45/17.
Old 08-15-2009, 07:23 PM   #8
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
I'm running RE-11's and getting rubbing issues, but i'm on 17x7 rims 225/45R17. I know a lot of people running these tires (cuz i work for bridgestone) and in the larger sizes they are not having the same issue as me. So I would recommend them in that size.
Its about time for me to sell all my cars.
Dirty25RS is offline   Reply With Quote
Old 08-16-2009, 07:55 PM   #9
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You need a better alignment if you are rubbing with 225/45-17's.
Old 08-16-2009, 08:28 PM   #10
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
The widest tires are not always the best. If you have tires that are too wide, they can lower performance.
ahendrickson is offline   Reply With Quote
Old 08-16-2009, 08:31 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^^This is the autocross section. Most every Subaru running today is heavy enough to heat up all but the most extremely wide tires out there.
Jay
Old 08-16-2009, 08:53 PM   #12
SoloSTI
Member#: 113854
2004 Impreza STI
I have heard that I can run 255's or even 275's on the OEM rims is this true?
What do you mean by this?
What DOT race tires do you think is best for autocrossing?
SoloSTI is offline   Reply With Quote
Old 08-16-2009, 09:11 PM   #13
Dirty25RS
Member#: 56731
I have a good alignment. the backs are OK. I'm running 1/8th degree toe out front, 0 back
I've increased front camber from 0 to -6 gradually over the past few AutoX's and they are still rubbing.
this is with -6 camber. 225/45R17 RE-11's. 40psi in the front (i've gradually increased from 30 weekend to weekend)
I'm not willing to go any farther since I'm already at twice the typical camber regime. I have reduced the amount of rubbing, its not making it all the way down to the turn-up anymore.
Old 08-16-2009, 10:02 PM   #14
Roel03
Member#: 127450
2007 WRX
Satin White
My car is lowered on coilovers so i dont think I will go to 255 because I don't want to worry about any rubbing issues.
Old 08-16-2009, 10:18 PM   #15
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
-6 degree of camber??? Wow, that's alot. what camber plates you have that can get -6 camber?
mug23 is offline   Reply With Quote
Old 08-16-2009, 11:34 PM   #16
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
If you have -6 degrees of camber, you do not have a good alignment. That is way too much.
I have setup WRX's with 245/40-17's and have not had rubbing issues, if you are running a 20mm thinner tire, you should be able to get your setup to not rub without any issues.
Old 08-17-2009, 07:13 AM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
In autocross, the most rubber on the track is almost always the best way to go. There's no concern with rolling resistance, aerodynamic drag or anything like that. Subarus are heavy, you can get heat into some big-big tires....especially if you have a codriver helping out. IIRC, it's not until you're looking at 300+ series tires that you have to be concerned about not getting heat into them. Lower if your car is lighter. We have no problem heating up 275's in an FSP car weighing 2450lbs......that should tell you something when you're driving a car that's 2900+ lbs.
Oh, and the best autocross tire out there right now is the Hoosier A6. They don't last too long, but good lord...... the grip is just amazing. Downright Addictive......mmmmmm!
Jay
Old 08-17-2009, 07:46 AM   #18
Dirty25RS
Member#: 56731
I guess I'll have to repeat. I've gradually increased weekend to weekend from 0 to -6. I know its too much but the rubbing decreased as I got closer to -6. -1 on the bolt (maybe just -0.9), -5 on the plates.
And i listed my other alignment settings, which are good. And are still accurate.
But this isn't my thread so Im done discussing my rubbing issue.
Old 08-18-2009, 12:59 PM   #19
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
deleted (but I still would like to see a head on shot with 6 degrees of camber)
275 can fit on stock bbs's, but they will rub. People do it fairly often in AS class
xcdhridr is offline   Reply With Quote
Old 08-27-2009, 01:00 AM   #20
derekmatthews
Member#: 221734
dont make the mistake of gettin the widest tires, they wont improve performance
derekmatthews is offline   Reply With Quote
Old 08-27-2009, 06:36 AM   #21
Storm
Member#: 5218
96L Most Over-
Developed Beater
We've got results to prove otherwise.....
Jay Storm
Old 08-29-2009, 09:36 PM   #22
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
The widest, stickiest tires that will fit on your rim and under your fenders is definitely the way to go for AX. Since you will be driving the car on the street as well, you will likely choose to compromise on the AX performance to get a decent daily driving experience (no rubbing and no r-comps).
bcblues is offline   Reply With Quote
Old 08-31-2009, 03:55 PM   #23
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
What other mods do you have? Are you trying for a specific class?
Old 09-03-2009, 11:50 AM   #24
Roel03
Member#: 127450
2007 WRX
Satin White
I have a wrx with a vf39 and sti topmount, with a turboback. I just started in autocross so I am not really competetive. I want to incerease my driving first then start to get more competetive.
Old 09-03-2009, 08:03 PM   #25
bcblues
Member#: 17256
04 STi
Then get some really good extreme performance street tires. Something like the Dunlop Direzza Star Spec or Kumho XS. Those tires are quite forgiving and give great feedback as you approach the limits of traction, which makes driving and IMPROVING your driving far easier. I would avoid r-comps until you get a better feel for the ways traction works, and until you get used to autocrossing.
Sticky for Rim sizes and tire sizes? TomsSound Brakes, Steering & Suspension 8 02-01-2012 09:30 PM
Tire sizes and speaker sizes... samtheblur Legacy Forum 9 06-03-2005 08:04 PM
Racing Tire Size to Street Tire Size mav1c Brakes, Steering & Suspension 0 11-18-2002 03:16 PM
Interesting Tire Size/Contact Patch Size/Shape Info - aka why I don't have 18" wheels rao Brakes, Steering & Suspension 6 06-19-2001 04:08 PM
Here is tire sizes chart. No more tire size Qs? Yeah, right! 25psi Brakes, Steering & Suspension 18 04-18-2001 03:29 PM
