Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-15-2009, 02:29 PM   #1
gifters
Member#: 119762
2003 Subaru Baja
Black/Silver
Default Install Baja Sport Activity Lights
Has anyone installed the Sport Activity Lights on the Baja? I'm wondering what the Clip Removal Tool is and if anyone had better directions / pictures of the wiring process.
Thanks,
Gifters
gifters is offline   Reply With Quote
Old 08-20-2009, 05:40 PM   #2
Alpha Wolf
Member#: 140505
2005 Baja Turbo
Pearl Blue
Cool
Yes I have.
I used a small flat blade scewdriver to remove the covers.
If you buy a Subaru kit it comes with new covers for the bed panel.
It should also have the required Solenoid to plug in under the dash.
The Baja is basically pre wired so there is very little wiring to do.
2003 kit will even work on 2005 car if you just buy the 2005 solenoid as it is not the same one as on the 2003.
Pull console insert
Pull center dash cover
Pull lower insert with tray. Install switch
Find wire taped up to hu
Feed wire down to switch.
Once switch is plugged in install lower insert with switch.
Install center dash cover
Install concole insert.
Under left side of dash install solenoid.
Go to passenger side rear bed rail which requires you losen the roll bar.
Remove right side bed liner cover.
Plug in wire
Remove rear roof/window cover on passenger side
Plug in wire you got with lights to plug in rear roof panel.
Run wiring along inside of passenger side of roor rack side rail.
Lead up to front roof rack bar.
Mount lights
Plug lights into wire you lead to roof rack bar.
With parking brake on at least one click, turn on new Activity light switch and see that all is working.
Adjust light position to suit your needs.
Done.
Note: As per instructions to remove connection to heater/Defroster before removing center dash per instructions. Passenger side floorboard pull wire off of arm or you can brake the arm by pulling on controls when taking center dash apart.
Alpha Wolf is offline   Reply With Quote
Old 03-07-2015, 03:20 AM   #3
5050GRIP
Member#: 343562
Thanks for the helpful how to Wolfy.
5050GRIP is offline   Reply With Quote
Old 06-17-2016, 07:56 PM   #4
Rsmith8126
Member#: 449047
Default 2005 Subaru Baja sports light
Thanks,
Gifters
anyone know where I cal get a set of sports lights thanks Ronnie
Rsmith8126 is offline   Reply With Quote
Baja sport activity lights bypass toolbox1234 Baja Forum 2 06-24-2009 12:11 AM
Baja sport activity lights (roof mounted) toolbox1234 Newbies & FAQs 2 06-03-2009 07:18 AM
problem with Sport Activity Light installation dfritz Baja Forum 14 02-19-2008 08:02 PM
Sport activity lights? yellowblaze Baja Forum 22 01-19-2007 01:35 PM
