08-15-2009, 08:49 PM | #1 |
Member#: 80663
SWIC
Vehicle:2005 STi |
What would happen if spark plugs were not tight enough?
Spec is 15 ft. lbs. What would happen if someone were to only get them to around 10 ft. lbs.?
Reason I ask is that I am doing mine right now. I seem to be doing a pretty good job of feeling the 'stop' after the crush washer, I'm just wondering what would happen if I happened to not get them quite tight enough.
08-15-2009, 09:00 PM | #2 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
1-They may loosen over time (leading to #2)
2-You may lose some compression pressure |
08-15-2009, 09:02 PM | #3 |
Member#: 80663
SWIC
Vehicle:2005 STi |
Hmm, well I guess that is better than stripping it. Would it be noticable over time or would the car just suddenly feel like it is misfiring?
08-16-2009, 01:34 AM | #4 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
you will(should) be able to hear it...but if it spits the plug....THAT can strip out the head, too
harbor freight has a 1/4" drive 20-200in-lb torque wrench for $19.99 http://www.harborfreight.com/cpi/cta...temnumber=2696 perfect for spark plugs....Mine has served me well for years |
08-16-2009, 02:45 AM | #5 |
Member#: 96448
Vehicle:02 WRX VF34 |
08-16-2009, 03:30 AM | #6 |
Member#: 80663
SWIC
Vehicle:2005 STi |
I drove it around and it seemed fine. I managed to get them pretty tight...I'm just so paranoid about stripping them.
I have a torque wrench...but it is the bar-type that goes up to 75 ft. lbs. so I don't entirely trust it on something like this. |
08-16-2009, 12:46 PM | #7 |
Member#: 37359
Vehicle:2003 WRX |
If you have access to a vise and some dumbells, you can check your beam torque wrench. Clamp the square drive horizontally in the vise and hang a 15 lb dumbell from the handle, 12" from the pivot. Adjust the pointer to read 15 ft/lbs.
I did this with my clicker to check it's calibration. Of course it's not super accurate, but torque specs are just an approximate surrogate for measuring tension in the fastener anyway. |
08-16-2009, 01:34 PM | #8 | |
Member#: 16200
as I have several torque wrenches and tried both the 3/8 drive ones I had....that lead me to buy the 1/4 inch drive one I listed, above |
08-16-2009, 05:15 PM | #9 |
Member#: 80663
SWIC
Vehicle:2005 STi |
what is spec on the plugs in inch pounds?
08-17-2009, 09:36 AM | #10 | |
Member#: 73043
Vehicle:2019 STI/370Z/Jeep Black/Black Cherry/Green |
08-17-2009, 11:16 AM | #11 |
Member#: 116052
Vehicle:2011 STI ( Sold ) WRB |
like scotty mentioned, 1/4" would be real handy. I did my plug changes couple month ago. i had no problem torqueing down three of plugs with 3/8" wrench but there was no room for the rear driver side one.
08-17-2009, 12:22 PM | #12 |
Member#: 216135
Vehicle:2011 |
Multiply ftlbs by 12.
And it is common knowledge that bean torque wrenches are much more accurate. The accuracy lies in the fact that a stiff rod behaves like a spring in small angle bends. However, it's precision is the issue given you must rely on the graduations that are on the scale. Clicker torque wrenches aren't as accurate (in general) but are much more precise. With a beam wrench, unless it has been abused, the only recalibration you'll have to do is make sure the pointer is on 0 when it is unloaded. The obvious other disadvantage is having to be looking at the scale dead on (to avoid parallax) when setting the final torque. I'm sure this is the case on a Subaru flat four since you probably can't see the scale when when it is in position. I milled out an aluminum arm and made a device like leecea mentioned for checking the accuracy of a torque wrench. I bolted a piece of cast iron that weighs 10lbs at the end of the arm and in the middle it has a nut on it that can slide in a milled slot with graduations on it for adjusting the distance away from the pivot. You must only take measurements when the weight is at 90 degrees from rest (arm is parallel to the ground). In the end it has proved that my 0-75ftlb Crastman bean torque wrench is 100% perfect throughout the range (within the precision of the scale)...I usually test it at 15lbft and 60lbft. My autozone 3/8" clicker is consistently 1-2 lbft too low in the early settings and gets more accurate above 30lbft (this is usually the case for clicker torque wrenches...more accurate in the higher range of the operating range). I haven't tried the HF 1/4" clicker I bought a few weeks ago because my device isn't good for measuring any less than 10 ftlb. |
08-17-2009, 01:51 PM | #13 | |
Member#: 80663
SWIC
Vehicle:2005 STi |
What would happen if you were to totally disconnect? | KC | Off-Topic | 44 | 12-04-2008 02:02 PM |
What would happen if a car were put into gear will all 4 wheels off the ground? | vision.dynamix | General Community | 47 | 10-29-2007 04:02 PM |
The "truth" about what would happen if all "illegals" were gone. WARNING: TASTELESS | avatarr | Off-Topic | 19 | 05-05-2006 10:28 AM |
what would happen if i were to just drill through my OEM muffler? | Handsdown | Normally Aspirated Powertrain | 9 | 01-23-2005 01:27 PM |
What will happen if you plug the other nipple on a Greddy Type s bov? | LqSilver | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 01-19-2004 12:45 PM |
