Old 11-15-2011, 11:53 AM   #1301
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Hard weekend for lots of guys and motors, that GTX turbo is a motor killer, big power, big distruction. Great thing is it will help further develop the EJ series motors. Great job going for it this weekend with big power! Going to be a great races to come with the big boys in the class / Subaru going head to head.
Token-Negro is offline   Reply With Quote
Old 11-16-2011, 01:07 PM   #1302
LICmotorsports
Member#: 54890
well it gives the ability to up the power and sustain it for sure...not sure its the killer per say, just means we need to adapt and adjust to new found pressures and levels the car now runs at consistently
-Noah
LICmotorsports is offline   Reply With Quote
Old 11-16-2011, 09:05 PM   #1303
LICmotorsports
Member#: 54890
Race motor is completely disassembled. The 2 other rods look just like this as well (Rod #3 is in two pieces from breaking/failing). If you look at the arrows you can see where the bends went from the pressure and ultimately the rods not being strong enough to take the power we are putting out.
If you look real closely you can see the lower end of the rod (Crank End) where it actually started to narrow from it getting stretched, the in the center you can see it bulged from that material shifting to the center line, then at the piston end of the rod its again bent and narrowed.
Bearings, other cylinder walls, heads, head gaskets, and crank are still all perfectly fine...bummer a part that was suppose to be able to take the power couldn't but we live and learn....and come back stronger, as this is an easy fix (aside from the trashed mess of a motor we have going on). But its nice to know it only came down to a failed component as we predicted, as opposed to other underlining issues or compromises in the setup.
-Noah
Old 11-16-2011, 09:09 PM   #1304
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
thats nuts, some crazy A beam rods in the works?
scby rex is offline   Reply With Quote
Old 11-16-2011, 09:10 PM   #1305
LICmotorsports
Member#: 54890
you got it!
-Noah
Old 11-16-2011, 09:14 PM   #1306
LICmotorsports
Member#: 54890
we always pick our parts wisely and honestly I still like these rods. They just can't do the power we are at anymore.
These rods are the same ones we used all last year in our race motor and earlier this year. they work great for no more than 550whp....which we are no longer at anymore
-Noah
Old 11-16-2011, 09:18 PM   #1307
scby rex
Member#: 104878
02 wrxbastardchild
understood, the development continues.
Old 11-16-2011, 10:51 PM   #1308
LICmotorsports
Member#: 54890
always!
-Noah
Old 11-16-2011, 11:16 PM   #1309
mxpop
Member#: 103776
2006 STI
Is that a K1 rod?
Originally Posted by LICmotorsports View Post
-Noah
mxpop is offline   Reply With Quote
Old 11-17-2011, 12:24 PM   #1310
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Wait so your saying that the rod is not suppose to look like that
Got to admit as much as it sucks to blow stuff up, its fun to push products to there limit and really see what they are capable of.
So next year we can expect 850WHP?
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 11-17-2011, 12:27 PM   #1311
LICmotorsports
Member#: 54890
yeah agreed.
These rods are still at top of my list for great rods given what they are (H-Beam), they aren't capable of the power level we are now at...its simple, we go to something I or A Beam from here on out. I will still use these rods and continue with them...just not in our race motor anymore, they worked great for 1.5 years at our old power levels, which is nothing shy of a lot, its just even more now...everything has its limits and we found them on this particular rod
-Noah
Old 11-17-2011, 12:34 PM   #1312
haberkorn
Member#: 97732
2004 STi
65 Nova [email protected]
Looks like it was aweful close to puking all 4 rods instead of just one. I guess the damage is done regardless huh?
Good luck the rest of the season...I'll be following you guys.
haberkorn is offline   Reply With Quote
Old 11-17-2011, 12:37 PM   #1313
LICmotorsports
Member#: 54890
I don't think it would of to be honest. The only reason the one snapped is b/c after bending it hit the sleeve, which caused it to break off into pieces
-Noah
Old 12-01-2011, 03:36 PM   #1314
LICmotorsports
Member#: 54890
NEW BLOG FROM COBB TUNING.
A brand-new motor, a rain-slick track, and rivals running quicker lap times are not the best elements to make for a successful racing weekend. The LIC Motorsports and their Subaru STi were facing an uphill battle for Global Time Attack’s 2011 Finals at Infineon Raceway, but with the hard work of the LIC Motorsports crew, and some help from COBB Tuning’s Gary Sheehan and Tim Bailey, everything came together perfectly. Not only did LIC Motorsports take home 1st Place, but they set a new class record utilizing an impressive chassis and AccessPORT Alpha Speed Density Tuning.
Adam and Noah Levy of LIC Motorsports needed a motor to match the chassis development from the previous seasons of racing. The motor build was completed using a sleeved block, pistons, bearings, a GTX turbo, and a higher capacity oil pan. LIC Motorsports also decided to eliminate the BPV to increase turbo and throttle input response. Everything was buttoned up only 10 hours before hitting the track. The outcome? “Power delivery is awesome!” Gary Sheehan was also impressed with.....READ MORE
-Noah
Old 12-02-2011, 07:05 AM   #1315
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Great write up, and congrats on the victory! What cams are you guys running?
waynoSTI is offline   Reply With Quote
Old 12-02-2011, 11:31 AM   #1316
LICmotorsports
Member#: 54890
these are the heads we run on our TA car
LIC Motorsports TA Heads w/ Cams (04-06 STi)
-Noah
Old 12-10-2011, 10:38 AM   #1317
LICmotorsports
Member#: 54890
Take a look at the new LIC Motorsports "Get LIC'd" Men's T-Shirts that are in production. These are projected to be done by end of this month and will be shipping first week of January. Feel free to jump on a pre-order and get yours before they sell out!
Available in: Black or Grey and sizes M-XXL
Online Store: Men's T's Catalog | LIC Motorsports
-Noah
Old 12-10-2011, 10:54 AM   #1318
scby rex
Member#: 104878
02 wrxbastardchild
nice shirts
Old 12-10-2011, 01:44 PM   #1319
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
The car is gorgeous and the shirts are cool. Any plans to combine the two?
INKMAN is offline   Reply With Quote
Old 12-10-2011, 01:53 PM   #1320
LICmotorsports
Member#: 54890
Thanks!
As in a shirt with our car on it?
-Noah
Old 12-10-2011, 01:55 PM   #1321
LICmotorsports
Member#: 54890
updated our post in Top Scoob Tarmac Thread with specs
Be sure to vote when the time comes!
-Noah
Old 12-10-2011, 02:42 PM   #1322
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Thanks!
-Noah
Yes sir, and you have my vote!
Old 12-10-2011, 06:52 PM   #1323
LICmotorsports
Member#: 54890
we have a few designs in the works
-Noah
Old 12-10-2011, 10:25 PM   #1324
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
I tried to order a shirt and hat but it won't let me choose my country in the drop down its only says USA...
How do I order by phone?
Old 12-10-2011, 10:38 PM   #1325
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
Congrats on that 1st place guys.. Cant freakin wait for cobb to release the new SD tuning!
mpsti05 is offline   Reply With Quote
Building Time Attack STi...Stock STi parts FS! dentsport NESIC Vendor Classifieds 35 07-17-2006 11:33 AM
World One Time Attack STi Part-Out!!!! advanwrx Private 'For Sale' Classifieds 23 07-15-2006 05:01 PM
USED SET OF LE28N'S OFF OF TIME ATTACK STi!!!! WorldOne Wheels/Tires 11 11-20-2005 07:34 PM
World One Customer EVO MR + World One Time Attack STi!!! WorldOne Member's Car Gallery 34 11-14-2005 12:44 PM
World One Time Attack STi goes to PIR!!! WorldOne Member's Car Gallery 63 10-22-2005 02:55 PM
