Old 08-16-2009, 03:53 PM   #1
CasperForester
Member#: 212713
2000 Forester
Default 2.5 N/A with 2.0 Turbo
Ok so I have a 2000 Forester, and i am looking to turbo it. Only looking to run 5psi. So far I have the TD04 turbo the Oil pan off a 2.0, TMIC, and exhaust housing parts. Like headers, up pipe, and down pipe, I was wondering how safe would my motor be on only 5psi? Or is there something needed that I am missing?
CasperForester is offline   Reply With Quote
Old 08-16-2009, 11:32 PM   #2
2milehi
Member#: 81633
'98 RS-T
+40,000 miles on about 6 psi.
You'll need a turbo engine water pump and notch/replace the front cross memeber.
2milehi is offline   Reply With Quote
Old 08-17-2009, 12:00 AM   #3
Candor
Member#: 219200
How much oomph does 5psi add?
Candor is offline   Reply With Quote
Old 08-17-2009, 03:24 AM   #4
CasperForester
Member#: 212713
2000 Forester
wow thank you, what about injectors? any advice is useful. I'm kinda new to subaru's so yea
Old 08-17-2009, 03:27 AM   #5
CasperForester
Member#: 212713
2000 Forester
oh and I heard something about a MAP sensor having to be instailed?
Old 08-17-2009, 12:37 PM   #6
Abest10
Member#: 190962
00 STM RS
04 FXT
Your Forester is a 2000 so it is MAP based. Either put a check valve in it or throw a MAP voltage clamp on it.
And for injectors Id say run stock ones for 5psi. Just go with a upgraded fuel pump like a Walbro 255.
Abest10 is offline   Reply With Quote
Old 08-17-2009, 04:05 PM   #7
2milehi
Member#: 81633
'98 RS-T
I'm running stock injectors, fuel pump, and ECU. The 5 psi of boost helps out a lot. Some of the passes that I travel (11,000 ft) use to require a downshift into 4th. Not any more
I still don't understand why one needs to add a zener diode for the voltage clamp on the MAP sensor.
Old 08-17-2009, 08:33 PM   #8
Candor
Member#: 219200
Might have to look into this
Old 08-17-2009, 09:25 PM   #9
2milehi
Member#: 81633
'98 RS-T
I did the install for $600. I did all the work myself (including notching the front cross member).
Old 08-18-2009, 02:03 PM   #10
CasperForester
Member#: 212713
2000 Forester
what about a tune? everyone keeps telling me "ohh you'll lean it out without a tune." I've been wanting to do this forever because everyone else has wrx's or sti's and I'm sick of hearing. "it can't be done" well obivously it can lol, I just want to learn more about it before i do it.
Old 08-18-2009, 11:22 PM   #11
2milehi
Member#: 81633
'98 RS-T
Like I said, 40 thousand miles, 211 million feet, 2.5 billion inches. My car runs fine, it is not ideal and a tune would make it run better. But it works plenty good at 6 psi and spark plugs have been "wearing" fine.
If you are mechanically inclined, DO IT!
Old 08-19-2009, 12:32 AM   #12
socallmechris
Member#: 213905
2005 RSTI
Dark blue
i lost cyl 4 in my 02 wrx but i have access to a 2.5 n/a block (well, its the whole car) for 500 bucks. im hoping it will work out ok for me with all the 2.0 turbo stuff in stock form on the 2.5 n/a block
socallmechris is online now   Reply With Quote
Old 08-19-2009, 01:15 AM   #13
CasperForester
Member#: 212713
2000 Forester
i'm gonna do it i just wanted to learn more about it before i did it. but you said the water pump is i'll i'm missing, well hell thats a 100 dollar part. my top mount will be 150, my exhaust will be 130. how did you run your exhaust after the down pipe tho? just curious. sorry I am asking questions. I just don't want to blow my car
Old 08-19-2009, 01:18 AM   #14
CasperForester
Member#: 212713
2000 Forester
ohh and my motor has about 160k on it... but compresson is fine, an old lady owned the car before me. Only down side it's a auto
Old 08-19-2009, 04:35 AM   #15
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
Quit whining and swap a 5MT. It's easy.
Carter is offline   Reply With Quote
Old 08-19-2009, 10:33 AM   #16
CasperForester
Member#: 212713
2000 Forester
yea I was thinking about it, but putting in the clutch pedal is a pain in the ass. but I want to see how the auto holds to boost. Because i don't think there is a person that can shift faster than a auto. But at the sametime I want to shift through gears lol. So idk we will see how things go in the next month
Old 08-20-2009, 07:53 PM   #17
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Link for buildup?
JamesWilson2 is offline   Reply With Quote
Old 08-20-2009, 11:25 PM   #18
silentt
Member#: 119995
2004 Outback XT
Peachy
My auto lasted me 3 months (with a freshly rebuild torque converter) at 10psi.
At 10 psi the ECU freaks out and throws a CEL.
silentt is offline   Reply With Quote
Old 08-21-2009, 01:01 AM   #19
CasperForester
Member#: 212713
2000 Forester
k so i will need to look into a tranny swap, and also a map? but how would I run the map? and how hard/easy is a 5mt swap?
Old 08-21-2009, 11:06 AM   #20
2milehi
Member#: 81633
'98 RS-T
Originally Posted by JamesWilson2 View Post
Link for buildup?
UGH - I looked for about an hour on my price list of my buildup and could not find it. But here is my buildup link - http://forums.nasioc.com/forums/showthread.php?t=824400
Old 08-21-2009, 11:16 AM   #21
2milehi
Member#: 81633
'98 RS-T
On my car, the previous owner ran 2 1/2" back from the last cat. So I joined the downpipe to the existing 2 1/2". As for questions - ask away.
Old 08-22-2009, 03:29 PM   #22
CasperForester
Member#: 212713
2000 Forester
what was the toughest part about doing this? I mean 2.0 headers and everything will work? Or did you go with a different setup? what about up and down pipe?
Old 08-23-2009, 09:53 AM   #23
2milehi
Member#: 81633
'98 RS-T
I used the factory turbo exhaust manifolds and up/down pipes. I started by bolting the turbo to the downpipe and then bolt the downpipe to the tranny. Next I positioned the outlet of the downpipe to a good location. Then I made two brackets to lock the location of the turbo. Then I added a 1 1/2" extension to the up pipe.
Old 08-23-2009, 11:07 AM   #24
iluvdrt
Member#: 46248
82 Brat
Tan
How did you route the coolant and oil lines??
I just wanted to verify that you said you are using no EM?
I have the same engine as you (98) LGT wagon, and have been thinking about this for a looooong time. I have att the parts chilling in my garage. I just havent done it yet.
How did you make the intercooler like that?
iluvdrt is offline   Reply With Quote
Old 08-23-2009, 09:31 PM   #25
2milehi
Member#: 81633
'98 RS-T
I added the coolant lines by plumbing the turbo in series with the throttle body. I modified the banjo fittings by soldering 5/16" steel fuel line to the fittings. The oil line supply comes from the front oil supply and the return oil goes to the valve cover.
I am using EM - just factory, stock, what ever Subaru programmed in '98.
The inlet of the intercooler is a 2" aluminum pipe TIG welded to inlet side of the intercooler. I plugged the factory inlet holes. This makes adding the intercooler a lot easier.
Add the turbo - you will enjoy it!
2.5 short block with 2.2 heads? Zero92828 Normally Aspirated Powertrain 7 05-02-2009 05:22 PM
wanna swap my 2.5 n/a with 2.0 turbo??? ruster Subaru Conversions 26 01-10-2005 02:33 AM
2.5 sti block with 2.0 regular wrx heads serious Normally Aspirated with bolt-on Forced Induction Powertrain 21 08-03-2003 12:36 PM
Why can't use 2.2 or 2.5 PH1 trans with 2.5 PH 2? rallynutdon Transmission (AT/MT) & Driveline 6 04-02-2003 06:01 PM
black 2.5 spotted cruising with 2 silver rexes Rexwell Rocky Mountains Impreza Club Forum -- RMIC 1 03-12-2002 12:12 PM
