Old 08-16-2009, 09:32 PM   #1
JSarv
Member#: 163445
l33t *******
[email protected]
Default Filter leak on 02
Yea I searched found a few things buttttt nothing completely relevant.
Its leaking above and running down the oil filter. Has been going on for quite a while with more than one filter... So its obviously coming from the cooler somewhere.
Anyone have any info on a fix for this?
-jerod
JSarv is offline   Reply With Quote
Old 08-16-2009, 10:49 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Well - there's an o-ring seal at the top of the oil cooler - the thing you thread the oil filter onto is also the connector/hollow bolt which holds the oil cooler in place (and thus places pressure on the o-ring) - could be that the filter bound up once and when being tightened or removed, loosened/damaged the o-ring. You could try tightening the connector tube up and see if that solves the problem (or if that doesn't work, pull the oil cooler and replace the o-ring)
Old 08-16-2009, 11:06 PM   #3
JSarv
Member#: 163445
l33t *******
[email protected]
thanks. Are the oil coolers expensive?
-jerod
Old 08-17-2009, 08:55 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
-jerod
The whole OEM kit (cooler & lines) was ~$325 last time I looked.
Your issue is a simple fix, no need to replace the cooler.
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 01:41 PM
Oil leak on oil filter? alenk37 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-15-2009 03:29 AM
Oil filter leak or just spillage? element533 Service & Maintenance 2 07-13-2003 01:31 AM
98 rs oil filter fit on 02 wrx? christoph1371 Bay Area Impreza Club Forum -- BAIC 2 05-22-2001 02:44 PM
