08-16-2009, 08:33 PM | #1 |
Member#: 43560
Vehicle:2009 Lancer Ralliart Black |
Pic request : Where to pour Seafoam in a 2006 WRX?
Requesting a pic identifying exactly which hose in my 2006 WRX I need to pour Seafoam in. Thanks.
08-16-2009, 08:45 PM | #2 |
Member#: 216135
Vehicle:2011 |
Power brake booster vacuum hose?
08-16-2009, 09:00 PM | #3 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
No, I would not use that spot. Instead, use vacuum line off of BPV.
08-16-2009, 09:04 PM | #4 |
Member#: 43560
Post pics please. I've seen pics demonstrating this on older Subarus but none like mine.
08-16-2009, 09:05 PM | #5 |
Member#: 216135
Vehicle:2011 |
Why wouldn't you want to use the brake booster line? Seems that most people I've seen use SF for induction cleaning use that vacuum line.
08-16-2009, 09:13 PM | #6 |
Member#: 32459
08-16-2009, 09:14 PM | #7 |
Member#: 32459
08-16-2009, 09:28 PM | #8 |
Member#: 216135
Vehicle:2011 |
As a sanity check, I went into the garage and checked. On the 08/09 the brake booster line goes directly into the middle of the IM so it will feed all 4 intake manifold runners. I guess it's different on the earlier WRXs.
I couldn't see where the BPV line went...it heads under the IC. |
08-17-2009, 01:58 PM | #9 |
Member#: 43560
08-17-2009, 02:14 PM | #10 | |
Member#: 216135
Vehicle:2011 |
It's the middle device on the right side. |
08-17-2009, 02:39 PM | #11 | |
Member#: 43560
08-17-2009, 02:51 PM | #12 |
Member#: 216135
Vehicle:2011 |
08-20-2009, 09:19 AM | #13 |
Member#: 73043
Vehicle:2019 STI/370Z/Jeep Black/Black Cherry/Green |
Here's a thought. You have an 06. I'd just run you gas down to a quarter, dump a can in and run it down to almost empty. Unless you really lug your engine or using crap gas, your fuel system shouldn't be all that bad. (of course you will miss the really cool smoke show) RP
08-20-2009, 10:05 AM | #14 |
Member#: 43560
I used a full can of Seafoam last night, but the results weren't quite what I had expected. No smoke at all! I did 1/3 in the gas tank, 1/3 in the oil reservoir, and 1/3 in the PCV hose. I followed the instructions exactly as written on the can. I'm thinking maybe I didn't use enough? Next fill-up I'm thinking of using a full can in the gas tank and split another can between the oil reservoir and the PCV hose. Should that do the trick?
08-20-2009, 10:14 AM | #15 |
Member#: 216135
Vehicle:2011 |
I personally would not put it in the oil. I don't really trust anything other than oil in the crankcase. If you think it is dirty in there, then do a couple short OCIs with a high detergent oil.
On the other hand, in the fuel tank and induction through the intake system is fine. You must not have much carbon build up on the valves/pistons. If you've been running top tier 91+ octane fuel, then you probably wouldn't on a 2006. |
08-20-2009, 10:28 AM | #16 | |
Member#: 43560
08-20-2009, 10:55 AM | #17 |
Member#: 216135
Vehicle:2011 |
Yes I highly encourage you to not go very long with that stuff in your crankcase. It is going to shear the hell out of the oil you have in there (it will come out at a much lower viscosity than it should) so I wouldn't drive it too hard with the SF in the oil.
08-23-2009, 06:27 PM | #18 |
Member#: 43560
I've used 2+ cans of Seafoam so far and was not able to produce any smoke. The first can I did 1/3 in the gas tank, 1/3 in the oil reservoir, and 1/3 via the hose pictured below. A few fill ups later I decided to use 1 full can in the gas tank and sucked up an additional 1/3 can via the hose below. Am I doing something wrong?
08-23-2009, 06:44 PM | #19 |
Member#: 96448
Vehicle:02 WRX VF34 |
I used 1/4 can of Seafoam and introduced into BPV vacuum line. It produced minor white smoke, but nothing like what people have described in this thread. Guess result varies
08-23-2009, 11:15 PM | #20 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
08-24-2009, 09:47 AM | #21 |
Member#: 43560
What makes you say this? The instructions on the can specifically say to do so. All the videos I've seen reinforce this. The majority of Seafoam users also mention that they sucked it up into the hose as well.
08-24-2009, 09:56 AM | #22 |
Member#: 16200
08-24-2009, 10:19 AM | #23 |
Member#: 43560
08-25-2009, 01:42 AM | #24 |
Member#: 209999
Vehicle:2004 STI Silver and Black |
sort of a weird question, but would spraying the foam onto your top mount IC while the car is running work?
08-25-2009, 08:07 AM | #25 |
Member#: 130710
NWIC
Vehicle:06 |
I will make it simple; put it in the fuel tank!
Off Topic : Where to buy gun in CA | mikercp | Southern California Impreza Club Forum -- SCIC | 46 | 04-02-2009 01:10 PM |
Where to get Seafoam in NYC? | rice h8r | Tri-State Area Forum | 7 | 05-13-2007 10:35 PM |
Where to connect tactrix cable on 2006 WRX? | eggeegg | Newbies & FAQs | 12 | 02-10-2007 07:39 PM |
PIC REQUEST : BLACK WRXs WITH BLUE LUGNUTS | ultraspdWRX | Member's Car Gallery | 1 | 08-01-2006 05:09 PM |
pic request : GOLD wrx/sti with gold wheels | bosen | Member's Car Gallery | 3 | 09-20-2004 05:26 PM |
