Old 08-17-2009, 12:25 AM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default flat lugnuts wheels on a car that uses acorn style lugnuts?
This isn't subaru related directly, but I figure there's a lot of general wheel knowledge here so I'll give it a shot.
I got a set of old school 4x100 wheels that can fit a hyundai accent (yes yes ), the car uses acorn-style lugnuts with its stock steelies, but the new wheels require a flat lugnut...can I use flat lugnuts with the new wheels on the car? I know the acorn lugnuts help with centering the wheel on the hub...would getting center/hub rings help with this issue?
rougeben83 is offline   Reply With Quote
Old 08-17-2009, 07:24 AM   #2
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
If the wheels require a flat lug nut, then use a flat lug nut. The acorn seat will not give you enough contact to stay tight.
BeatLA is offline   Reply With Quote
Old 08-17-2009, 11:54 AM   #3
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
+1
I had that problem with my B5S4. The original owner had A/M rims and never switched the bolts to rounded when the factories went back on. I heard a clunking sound while driving and realized one of the bolts backed out completely and was laying in the hub. Could have been worse, but only use the bolts / nuts designed for that model rim.
TEK112 is offline   Reply With Quote
Old 08-17-2009, 12:40 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
ok, so the lugnut you use has more to do with the wheel you're going to be using rather than what the car originally came with...thanks!
Old 08-17-2009, 11:04 PM   #5
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Most Subaru wheels are hub-centric, which means they rely in large part on a ring machined into the hub that fits tightly (well, at least firmly) in the center cutout portion of the wheel. Not sure if yours is hubcentric or not, (not really that well versed in Legacies), but I suspect they are.
bcblues is online now   Reply With Quote
Would an AP married to one car work on another car that has another AP married to it? zuczek AccessPort 13 10-24-2006 02:06 AM
flat black wheels on a black car? live- Tire & Wheel 5 09-23-2005 11:14 AM
Dealer put used wheels on my car Cyberdemon Off-Topic 14 08-03-2003 08:13 PM
anyone near irvine that have SSR Comps on their car that i could go have a look at? Wrx0R Southern California Impreza Club Forum -- SCIC 0 04-14-2002 10:22 PM
All that stuff on the car that doesn't really do anything 8Complex Technical Forum Archive 19 07-11-2000 12:17 AM
