Old 08-17-2009, 02:43 PM   #1
Smave
Member#: 212675
Lightbulb Need Advice on adding freon
So i replaced my radiator and in doing so i also replaced my thermostat. When replacing my thermostat i broke a bolt in the thermostat housing and the only way to get it out without pulling the engine out and drilling it was to remove the ac and drill it out. I got it all working but when i removed the ac freon sprayed everywhere when i released the seal. I know i need to refill with r134a (to the best of my knowledge). I have heard that if you opened it though that I would have to vaccum it first. Is this correct? also once vaccumed can I just add freon or is there any other procedures I should do before attemting to do this.
Thanks
Smave is offline   Reply With Quote
Old 08-17-2009, 03:28 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why didn't you get a right angle adapter for the drill? I got one for about 20$ at home depot
Old 08-17-2009, 04:31 PM   #3
rdodger
Member#: 156447
99 18g'd 2.5RS-T
How do you plan on putting it into a vacuum. Any air or moisture in an ac system is killer,I normally leave a vacuum pump running for a half hour to get everything out, and its designed for ac systems. You can also purge the system which is dumping gas in one port and letting it go to asmosphere on the other one to push out all the air and moisture but it wastes alot of freon (and I doubt you get it cheap like us a/c techs do) and is most likely illegal to do on purpose. Your best bet is to find an a/c shop to recharge it and tell them what you did, it will probably only be ~ $30 more than buying freon and hoping it works from a parts store.
rdodger is offline   Reply With Quote
Old 08-17-2009, 04:52 PM   #4
Smave
Member#: 212675
@ciper
I havent seen that tool before and it was a pretty tight working space. I will try that if it happens again. Thanks!
@rdoger
I dont plan on putting it on a vaccum myself, i just need to know if i needed to do it or not. I dont want to just refill it with freon and screw it up. Are you saying I need a proffesinal to do this for me(vaccum the system)? By recharge do you mean refill with r134a?
Old 08-17-2009, 05:02 PM   #5
rdodger
Member#: 156447
99 18g'd 2.5RS-T
Originally Posted by Smave View Post
@ciper
@rdoger
Yes you HAVE to vacuum it or purge it.Recharge is just the same as saying refill or repressurize.The only reason those diy kits work for vehicles is because even a vehicle that is very low on freon will usually still have some pressure and thus keep moisture and air out. Since you let everything out and thus exposed the sytem to air/moisture is has to be vacuumed with an expensive pump or you need a guage set that will allow you to dump freon out one port and fill through the other which will push all air and moisture out the dump port. Just call around to a few shops and let them know what happened, and that it needs to be evacuated/vaummed and not just a simple recharge. It shouldn't be too spendy. Next time just bend or work around a/c hoses.
Old 08-17-2009, 05:13 PM   #6
bluerex47
Member#: 73331
04 wrx
world rally blue
I don't have much of anything to add, but wanted to second everything that rdodger said. I work for a refrigeration company,and have done this job more than a few times, similar to rdodgers a/c tech specialty.
Also to note, somewhere you should have a refrigerant charge sticker (either hood or near the radiator) telling you the amount of refrigerant. This is just for your knowledge as the mechanic should already know that.
Good luck!
bluerex47 is offline   Reply With Quote
Need info on adding cd to single din 2000 outback head unit Count Chocula Legacy Forum 4 05-03-2004 02:38 AM
Need advice on rims/Brembo brakes on the STi IndeSTi Alaskan Impreza Club Forum -- AKIC 29 10-30-2003 01:56 AM
Need advice for adding 100 hp to a wagon LTHL VPR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-25-2002 12:48 AM
I need advice on putting 2001 bumper on MY98 RS. sstyle Interior & Exterior Modification 3 03-07-2001 11:41 AM
New Pics-Need advice on future mods on MY99 CRAZY KEN Legacy Forum 1 06-09-2000 10:47 PM
