Old 08-17-2009, 04:56 PM   #1
Ammadien
Member#: 100370
2005 Stage 2 sti
Default Stripped turbo stud :(
Hey guys,
Ok here is a pic, I was filling the transmission oil and found a loose nut on the turbo. No problem I said, i try to tighten it and the nut/stud are spinning. I haven't tried to back it out yet but was looking for some opinions.
These studs. I assume they are threaded in, so this means the stud/hole is stripped out right? What are my options for repair? Can you get a heli-coil(sp?) for something that small? Would I want to drill the hole out and use a regular nut/bolt? *sigh* the guy that had the car put a TBE on it then returned it to stock before selling it, I assume this is the result of that. Thoughts? Thanks in advance
Here is the pic to help visualize:
Nate
Ammadien is offline   Reply With Quote
Old 08-17-2009, 05:51 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
if you can get it out I would just put a nut and bolt.
Old 08-17-2009, 05:57 PM   #3
lotarg
Member#: 90940
I stripped studs and a shop put in new ones for me. I don't know how they did it. But if it's just that one then you could probably get away fine with pulling it out with pliers and putting in a small nut and bolt- and not even drilled out the threading of the hole.
lotarg is offline   Reply With Quote
Old 08-17-2009, 08:59 PM   #4
Ammadien
Member#: 100370
2005 Stage 2 sti
Ya just putting a slightly smaller bolt and nut combo was one idea I had. Thanks for the replies fellas.
Nate
Old 08-18-2009, 12:38 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I bet the turbo housing is fine. Its probably just the part of the stud that is underneath the nut that is stripped. I had the EXACT same thing happen because of a bad weld right near that nut. I had to cut the nut off!
Old 08-18-2009, 01:29 PM   #6
Ammadien
Member#: 100370
2005 Stage 2 sti
^ I didn't think about that. Figure'd it would bugger up the threads on the housing, but it's prolly alright. Gonna try to pull the stud out and just replace it with a new stock one. Thanks for the replies
Nate
Old 08-18-2009, 03:55 PM   #7
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
My bolt and nut on the top of the turbo closest to the D/S was stripped from the factory! The nut just spun on the bolt and was very hard to turn (breaker bar with cheater bar on each side and 2 big guys pulling on it...)
jay25RS is offline   Reply With Quote
Old 08-24-2009, 04:19 AM   #8
ttiimmff
Member#: 219575
If you could get a screw driver behind the washer and put a little pressure outward while turning the nut, that might help it come out. I heli coil would be better than a small bolt if you can do that.
ttiimmff is offline   Reply With Quote
Old 08-24-2009, 06:39 PM   #9
Ammadien
Member#: 100370
2005 Stage 2 sti
Well I pulled the stud out. Tried to put a new one in and that stripped as well, so something must have been cross threaded or buggered up in the hole/turbo side threads.
I found a allen head bolt that fit through the hole just fine and put a nut/lock/flat washer on the DP side. Had to grind down the head on the bolt a bit to get it to sit flat, but seems to be a bit quieter and works fine as of now. Thanks for the replies and advice everyone!
Nate
Stripped turbo stud? aakrusen Newbies & FAQs 12 03-16-2010 06:55 PM
Turbo Studs Stripped Yakshii Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 03-10-2009 04:23 PM
Help- stripped and locked up turbo stud gdubduc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 07-31-2008 09:05 AM
Turbo Studs Stripping!! EagleRockWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-03-2006 08:40 PM
Quick help on replacing stripped wheel stud Cabal Tire & Wheel 8 08-08-2005 07:35 PM
