Old 08-17-2009, 07:15 PM   #1
jose.
Member#: 185711
2002 wrx
white
Default Will a 05 wrx MT work in a 02 wrx MT?
Without doing any other modification? I couldn't find any info after searching for about 30 minutes. Thanks in advanced.
jose. is offline   Reply With Quote
Old 08-18-2009, 11:19 AM   #2
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
It should. They didn't change the final drive and clutch stuff until 06.
It should be a swap-and-go, with the exception of the axles. You'll probably need the axles from the 05.
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
Old 09-20-2009, 10:59 PM   #3
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Thanks for the easy answer Andrew.
What about 06 axles with an 05 transmission in an 03 WRX? They both use the male axles right?
PKer is offline   Reply With Quote
Will 04 WRX struts work in an 02 WRX? BlueHeavenWRX Brakes, Steering & Suspension 9 12-16-2008 11:43 PM
will a 04-05 wrx tranny work on my 02 wrx? wrxguy02 Newbies & FAQs 3 04-20-2008 01:19 PM
Will 99rs injectors work in my 02 WRX? blacktalon606 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-02-2007 09:25 AM
will an 05 sti ebrake fit into an 02 wrx? blueandgold Interior & Exterior Modification 3 10-07-2006 02:51 PM
Will 04-05 STi steering wheel fit on 02 WRX w/o modification? txl146 Interior & Exterior Modification 10 04-10-2005 12:06 AM
