Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 08-17-2009, 09:29 PM   #1
batmobile2
Member#: 220602
1995 wrx turbo 2.0
416 blue
Question Help please, need to replace hud stud
Hi guys, i need to replace the hub stud on my 1995 classic scooby, i recently bought some new wheels etc, and when i tried to replace them found that the previous owner ( i only bought it 3mths ago) had kindly cross threaded one of the front hub studs. It was stripped on removal, i have a new one, and have got the manual but it does not cover this procedure,
Anybody had this problem and/or can help please?
I know it goes in from the rear /inside of the hub, but i don't want to strip it down to find i need to take it in for shop repair and have bearings replaced etc.
batmobile2 is offline   Reply With Quote
Old 08-18-2009, 09:25 AM   #2
iluvdrt
Member#: 46248
82 Brat
Tan
Take off the wheel, caliper, and rotor. Pound out old stud with BFH. rotate the hub until you find the spot the stud can fit into the hole. (it will go in, I just don't remember where the relief spot is). use a stud puller (rented at the Zone) to pull the stud through the hole. Reinstall rotor, brakes, wheel. Drive around for a while(<100 miles). Recheck wheel torque.
iluvdrt is offline   Reply With Quote
Old 08-18-2009, 09:27 PM   #3
batmobile2
Member#: 220602
1995 wrx turbo 2.0
416 blue
Thanks for the info, i'll give it go this weekend.
HELP OT: Need to replace an ancient AC wall unit... tomorrow Wagon Of Fury Off-Topic 32 07-16-2008 10:07 AM
Help ! i need to replace my tie rod subyboy828 Brakes, Steering & Suspension 1 08-06-2007 02:35 PM
Help please! Need to borrow Access Port wall plug in Calgary ASAP 85258 Western Canada 1 03-21-2007 08:27 PM
Web people help please! Need to make a small HTML page! GooseMan Off-Topic 6 04-14-2005 02:22 PM
Do I need to replace the studs/bolts? Ft_Laud_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-12-2003 11:22 PM
