Old 08-17-2009, 09:36 PM   #1
tobylazur
Member#: 150289
2002 WRX Wagon
Default the offset thread....for wagons?
I was reading up on the offset thread, but I can't tell if the offsets listed in the OP's post still apply to wagons as opposed to sedans which have more room under their fenders?
I'm looking to run a 17'' wheel in maybe a 7.5'' or 8'' width on an 02 wagon.
tobylazur is offline   Reply With Quote
Old 08-18-2009, 08:02 PM   #2
d-ta
Member#: 131302
02 WRX Wagon
WRBlue myself
it's a conservative guide to work by so i think you should be fine with the ranges listed in the OP's post. from personal experience:
17x7 +53 on 225/45 = no rubbing issues
17x8 +35 on 235/45 = had to roll fenders
look for something inbetween and you should be fine
d-ta is offline   Reply With Quote
Old 08-18-2009, 08:22 PM   #3
tobylazur
Member#: 150289
2002 WRX Wagon
cool man, thanks.
Old 08-19-2009, 10:31 AM   #4
mosc
Member#: 177401
2004 STi White
16G powered lagless fun
if you want to run 225/45/17 (which you should) try to find at least +48 if not more offset. Rim width can be 17x7 to 17x8.5 inches.
A great choice for wagon guys to me is 04 STi BBS stockers. They're 17x7.5" +53 as well as being very light. They'll allow you to squeeze 225 wide tires by your rear fenders thanks to the high offset.
mosc is offline   Reply With Quote
Old 08-19-2009, 01:40 PM   #5
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Would they be very close to the struts? What about on a lowered car? thanks
mmiller2002 is offline   Reply With Quote
Old 08-19-2009, 04:38 PM   #6
mosc
Member#: 177401
2004 STi White
you shouldn't be that close to the struts with only a 225 wide tire even at +53.
If you intend to lower the car, it's even more important you get enough offset. That, or give up and run 215/45/17.
Old 08-19-2009, 08:05 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
205/55R16 on a 16x6.5+53 and I have fender rubbing problems if I hit a bump while turning.
Of course, that may have something to do with the fact that I have a sedan front suspension under wagon fenders
Old 08-19-2009, 10:48 PM   #8
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
17x8 +48 is great for a wagon, but if you want to run anything wider than a 225, you should roll your fenders. Even 225's might rub depending on your suspension set.
FWIW, I run 245/40-17 on 17x8 +48 FN01R-C's. -1 camber all around, rolled fenders, KW V3 coils, about 1/2" fender gap F/R.
dantastic is offline   Reply With Quote
Old 08-20-2009, 04:11 PM   #9
samsear
Member#: 151969
03 wrx wagon
ok, i am new to all of this so please bear with me.....i have an 03 wrx wagon and i need new wheels, i love the way the 04 sti bbs wheels look.....can someone please recommend wheels i should get without having to do any modifications to make them fit.
thanks
samsear is offline   Reply With Quote
Old 08-20-2009, 07:07 PM   #10
mosc
Member#: 177401
2004 STi White
04 STi BBS!
with 225/45/17
Old 08-21-2009, 12:28 PM   #11
samsear
Member#: 151969
03 wrx wagon
if i was to get 17x7.5 rotas what would be the exact offset to have no rubbing issues? also, are the stock wheels 16x7?
Old 08-21-2009, 12:59 PM   #12
mmiller2002
Member#: 159286
FYI - I have 17x7.5 with +48 offset and 225/45-17 tires no rubbing on lowered REC wagon springs.
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
Where is the original thread for the "driver abuse" Virginia thread plunk10 Off-Topic 2 07-18-2007 09:58 AM
Why did the 'Discsussion' thread for the SOA recommendation thread get closed? left footed whooten News & Rumors 6 09-05-2006 12:47 PM
16x7, 48mm offset okay for wagon? Durmiente Tire & Wheel 8 08-22-2005 02:38 PM
LOOK another thread for Wagon to delete! Crawdads Off-Topic 7 11-17-2004 12:44 AM
Message Board Statistics All times are GMT -4. The time now is 09:12 PM.
