#1 |
Vendor Sales Rating: (46)
Member#: 173316
W. Canada
![]() Racecomp Engineering "Regular Guy" for GR Chassis Finally, a performance spring designed with function over form is available for the latest Subaru Impreza STI. Incorporating the knowledge gained from designing a growing list of suspension and brake performance parts for the true track day and autocross enthusiast, Racecomp Engineering is proud to announce the latest addition to their line up. The Regular Guy Functional Lowering Springs for the 2008+ Subaru Impreza STI are designed as the ultimate performance spring upgrade for the newly redesigned GR chassis. Paying special attention to the completely new rear suspension design of the GR chassis, the Functional Lowering Springs provide a mild 5mm drop front and rear to maximize the extremely limited suspension travel available. Shorter bumpstops are included front and rear to take things one step further, resulting in more bump travel than stock. Rarely does an aftermarket spring set-up add suspension travel, but in this case it is a crucial design aspect that improves performance while helping to maintain a civil ride on the street. Spring rates of 320 lbs/in front and rear are intended to work with the completely new rear suspension of the GR chassis, which has a lower motion ratio in the rear than previous Imprezas. In addition, the OEM dampers have been carefully examined on a shock dyno to match the new spring rates to the dampers. Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a new performance spring has been produced that adds to available bump travel, matches the excellent OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit. Continuing the “Regular Guy” theme from previous Racecomp designs, the springs are colored black for a low key look. Coupled with the minimal drop, most people would be hard pressed to find anything different from stock….until the road curves. ![]() ![]() Specfications: 5mm drop front and rear 320 lb/in front and rear Shortened bump stops included front and rear (12mm shorter front, 18mm shorter rear) Retail-$425 $395 GTWorx Camberplates '08 STI, WRX and Legacy front-$495 '02-07 GD Chassis front and rear-$465/pair H&R Coilsprings for '08+ STI ![]() 1''drop frt/rr. I installed a set in an '09 STI and the rideheight looked awesome and it was very comfortable, works well with the stock dampers. Retail-$399 $385 Function: • Infinitely adjustable within german TUEV-tested adjustment parameters • Shortened struts for increased spring travel • Trapezoidal threads for simple height adjustment • Three different damping technologies for individual adjustment • Elastomer bump stops with integrated dust boot protection • Easy to read documentation • Ready to use comprehensive solutions • Visually perfect – safe and unique motion dynamics Quality: • Strut housings in inox-line stainless steel technology • Anodized aluminum spring collars and add-on pieces • High-quality, high-tensile racing springs • Special ventilation and sealing system • High-quality damping components • Hardened, chromium-plated piston rods • Special guide and sealing systems • Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology '05+STI and '08 STI and WRX in stock Retail-$2799 PM me for special pricing ![]() '08+ STI, WRX, Legacy, and New Look Forester Front/rear swaybars BSF30Z-22mm adj. frt BSF30XZ-24mm adj. frt BSF35Z-22mm adj. frt BSF39Z-22mm adj. frt BSF39XZ-24mm adj. frt BSR49Z-20mm adj. rr BSR49XZ-22mm adj. rr Front and rear endlinks KLC39-front adj. KLC044-rear adj. KLC066-rear adj. Max-C race upper camberplates Front upper strutbars Lower 4 pt stressbars Front roll center kits Anti-lift kits-Race and comfort Rack bushing Rear diff. inserts and subframe lock bushings 04+ STi, 02+WRX, 2.5I sedan and wagon Whiteline fixed front camber/casterplates Front/rear swaybars Front and rear endlinks Roll center kits ALK-race and comfort Front/rear upper strutbars Rack bushings Rear subframe locking bolts PM me for discount pricing ![]() '04-09 STI-DTC 30, HP+ and HPS HB453W.585 Hawk Brake Pads-$210 HB180W.560 Hawk Brake Pad-$185 HB453N.585 Hawk Brake Pad-$165 HB180N.560 Hawk Brake Pad-$130 HB453F.585 Hawk Brake Pad-$125 HB180F.560 Hawk Brake Pad-$85 '02-07 WRX-HPS and HP+ HB352F.665 Hawk Brake Pad-$95 HB434F.543 Hawk Brake Pad-$88 HB432F.661 Hawk Brake Pad-$95 HB452F.545 Hawk Brake Pad-$88 HB178F.564 Hawk Brake Pad-$98 HB179F.630 Hawk Brake Pad-$90 HB432N.661 Hawk Brake Pad-$142 HB452N.545 Hawk Brake Pad-$135 HB178N.564 Hawk Brake Pad-$142 HB179N.630 Hawk Brake Pad-$130 ![]() DBA Standard Slotted Rotors STI-'04 654SL DBA Brake Rotor-$180ea 654SR DBA Brake Rotor-$180ea 655SL DBA Brake Rotor-$160ea 655SR DBA Brake Rotor-$160ea WRX-'02-07 650SL DBA Brake Rotor -$155ea 650SR DBA Brake Rotor-$155ea 644SL DBA Brake Rotor-$140ea 644SR DBA Brake Rotor-$140ea 653SL DBA Brake Rotor-$150ea 653SR DBA Brake Rotor-$150ea DBA 4000 Slotted Rotors '02-07 WRX('06-07 rears only) 4650SL DBA Brake Rotor-$170ea 4650SR DBA Brake Rotor-$170ea 4653SL DBA Brake Rotor-$160ea 4653SR DBA Brake Rotor-$160ea '05+ STI DBA 4000 slotted 42654SL DBA Brake Rotor-$205ea 42654SR DBA Brake Rotor-$205ea 42655SL DBA Brake Rotor-$185ea 42655SR DBA Brake Rotor-$185ea 05+ Legacy GT Front DBA slotted 42650SL DBA Brake Rotor-$160ea 42650SR DBA Brake Rotor-$160ea DBA 5000 Slotted Rotors '05+ STI(frt)-5654SLR DBA Brake Rotor-$975pr Steel braided brake hoses(all models)-$120set ATE brake fluid(Blue and Clear)-$20/ltr I will match price with any Canadian vendor.
__________________
Service Center: 604 530 9160 Email- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Surrey Board of Trade 2012 business of the year. Providing quality service since 1975!!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by dalesalignment&brake; 09-16-2009 at 03:58 PM. |
#8 | |
Member Sales Rating: (41)
Member#: 102329
VIC
Vehicle:05 AW Piggy Gone 11 SP TOM'S IS-F |
...just jk, ya, you can have them, I go for another source then, as long as you dibs on them first...![]() Hey, what are you doing this weekend ricer? wanna chill out and for fun? msn me ok? we will have fun with our cars ok? ![]() |
