Old 08-18-2009, 02:41 PM   #1
e_presley20
Member#: 168640
2005 WRX
WR Blue
Default rpf1 17x7.5 or 17x8
I was wondering which wheel would be better over all?
is there a huge difference between 7.5 or 8?
e_presley20 is offline   Reply With Quote
Old 08-18-2009, 03:29 PM   #2
BIGHONKEY
Member#: 89575
'02 wrx sedan
sedona red pearl
About a half inch difference.
BIGHONKEY is offline   Reply With Quote
Old 08-18-2009, 03:39 PM   #3
e_presley20
Member#: 168640
2005 WRX
WR Blue
well i know that, im just saying any noticeable ride quality difference
Old 08-18-2009, 03:49 PM   #4
mosc
Member#: 177401
2004 STi White
16G powered lagless fun
RPF1's don't come in a plethora of sizes for 5x100. I believe 17x8" +45 is your only choice?
mosc is offline   Reply With Quote
Old 08-18-2009, 04:01 PM   #5
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
17x8 +45 or +35. going to an 8" wide wheel allows you to go as wide as 245 while it isn't recommend to go wider than 225 on a 7.5" wheel.
Old 08-18-2009, 04:37 PM   #6
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
I believe the 5x100 comes in a 17x7.5 +48 or 17x8 +48 or +45.
Yes. It would really depend on what size tires you want to use. If you're just daily driving and don't need/want the added performance and grip of a wider tire you can save yourself some money going with a 7.5" wheel and running 225 width tires. If you do go with the 8" wide version I'd get the +45 offset. Its only a 3mm difference, but I know first hand that a 332 stoptech doesn't fit under the +48 but it does fit under the +45. Gives you more options if you want to upgrade brakes at some point...or if you decide to sell them and people want to be sure they clear big brakes.
Scooby921 is offline   Reply With Quote
Old 08-18-2009, 11:37 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
a 17x7.5 is useless if you want a 'wide' tire, as the widest tire that fits...is a 235/40
you can put a 245/40 on a 17x8...and a 235/40 is GREAT on a 17x8
Old 08-19-2009, 01:59 AM   #8
Chainsaw_Willie
Member#: 211337
2006 WRX
I'm running the 215/45s that came with my car on my 17x8 RPF1s until they wear out. Tire Rack even says that's the recommended size for this wheel (though I have no idea why). I see no reason you couldn't run a 225 if you wanted to, it'd be a better fit than the 215s are. When these 215s wear out I'm going either 235 or 245.
Chainsaw_Willie is offline   Reply With Quote
Old 08-19-2009, 08:03 AM   #9
jcbluescooby
Member#: 113012
'04 WRX WRB stg2
'04 Forester XT red
why is a 235/40 GREAT?
jcbluescooby is offline   Reply With Quote
Old 08-19-2009, 12:15 PM   #10
kaptainkevlar
Member#: 80109
07 spec B
I'd imagine Uncle means that 235/40 will fit perfectly on the rim and have a very squared off sidewall. At least that's what I imagine, seeing as how my 225/50 RE-01R's on stock 16x7's are very much NOT square
I'll allow U S to add his witty remark now...
kaptainkevlar is offline   Reply With Quote
16x8 or 17x7.5 or 17x8 gc835 Tire & Wheel 16 10-23-2010 10:44 AM
2009 Impreza 2.5 - 17x7.5 or 17x8 Wheels opusxxvii Tire & Wheel 9 03-14-2010 05:16 PM
17x7.5 or 17x8.5????? dillsky Tire & Wheel 10 03-22-2008 10:01 PM
WTB: Gramlight 57S 17x7.5 or 17x8.5 Bronze moss Private 'Wanted' Classifieds 0 08-15-2006 01:31 PM
17x7.5 or 17x8, 53mm offset? paulw Brakes, Steering & Suspension 2 03-27-2001 12:00 AM
Message Board Statistics All times are GMT -4. The time now is 06:55 PM.
