Old 08-18-2009, 05:41 PM   #1
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Default Removing radio trim in 08-09??
Anyone know how to remove the silver trim around the radio in an 08-09 STi without removing the whole dash?
I know it can be done but I'm sure there's a trick as far as where to pull, how to not scratch, etc.
The pieces and a lot tighter than previous models so any tips would be appreciated so I don't jack up the plastic. Thanks
CtGT is offline   Reply With Quote
Old 08-18-2009, 06:34 PM   #2
spincycle
Member#: 155270
2015 Forester XT
Quartz Blue Pearl
I used radio removal tools. they are soft plastic so they didn't scratch the plastic. A wood skewer may also be able to assist in getting this off.
spincycle is offline   Reply With Quote
Old 08-18-2009, 07:08 PM   #3
markdWRX03
Member#: 24546
2009 WRX
I used a small plastic wedge on the upper left corner of the radio trim. On mine the trim was slightly up where you could get something into there to pull it up. All you need to start it a little and should be able to pull it off. It just has push type clips that come out pretty easy.
markdWRX03 is offline   Reply With Quote
Old 08-18-2009, 07:18 PM   #4
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Once you get it started does it pull straight out like most of the other pieces?
Old 08-18-2009, 07:27 PM   #5
AfflxnPB
Member#: 172036
2010 2.5i Prem
SSM
I took off 2 pieces to make it easier. My tools wouldnt fit between the dash and radio cover without mashing it. Open passenger side door and pop off side piece of dash. Unscrew the screw holding the silver piece that goes across and under the radio trim. Then slowly pop out that silver piece after taking out the screw and you get easy access to the radio, trim, and HVAC.
*edit* and yes the radio trim itself only has the pop out clips. No hidden screws or anything.
AfflxnPB is offline   Reply With Quote
Old 08-18-2009, 07:33 PM   #6
FkVtech
Member#: 198968
2008 WRX
RIP Soccerkid52688
Haha i just jammed a butter knife into the bottom where it ends and it poped right out...
FkVtech is offline   Reply With Quote
Old 08-19-2009, 12:24 AM   #7
Jowie
Member#: 193291
2009 WRX Sedan
Its not hard. I don't understand why people keep having issues. Butter knifes etc are a fast way to scratch things up unless you are careful. I just use my fingers:
http://forums.nasioc.com/forums/show...&postcount=180
Short answer, no need to take any trim out other than the radio surround to get the stereo out. Check out that thread from the beginning, lots of great info.
Jowie is offline   Reply With Quote
Old 08-19-2009, 06:14 PM   #8
viperftd
Member#: 206888
2009 Impreza 2.5i
Charcol
You have to be very carefull, but when you get the trim removed all the way to the center dash, you should be able to work it out enough. Also if you have the 'manual' AC and air controls you won't be able to do it.
viperftd is offline   Reply With Quote
Old 08-19-2009, 06:26 PM   #9
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
I found a link last night and was successful. Thanks for all the input!!
http://forums.nasioc.com/forums/show....php?t=1399151
Removing radio trim & dash pocket on 99 Impreza? Suby<3777 Interior & Exterior Modification 3 01-16-2009 08:24 PM
Katzkin or other leather in 08/09? Garandman Interior & Exterior Modification 2 11-18-2008 11:04 PM
Size of door pocket in 08/09 outback Dallas Hinton Vancouver Impreza Club Forum -- VIC 2 08-05-2008 03:40 PM
Remove Radio Trim jfalcon001 New England Impreza Club Forum -- NESIC 8 10-14-2002 03:18 PM
Removing radio trim for gauge install MarkBNX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-29-2002 10:21 PM
