Welcome to the North American Subaru Impreza Owners Club Thursday March 26, 2015
Old 08-18-2009, 08:40 PM   #1
nine7oh
Member#: 208840
2004 FXT, White
18ged
Default Tranny Fluid Leak? Brand new axle seals just installed
Ok so about a weak ago i realized i was leaking tranny fluid from what was thought to be my axle seals. I had bought new axle seals and o rings for my 04 sti. I pulled my axles and i removed the plates on the tranny that the output shafts come out of so i could get to the seals and the o rings easier. I made tick marks on these plates and i counted the amount of rotations it took to get each plate off. When i was done i lowered the car off the jack stands and then i put 2 quarts of tranny fluid in. I then jacked the rear end of the car up so i could reconnect my exhaust and then the fluid started pouring out from the seals i had just put in. Are these seals not in correctly or is something else messed up.. I have no clue what to do from here so if any of you have any ideas as to what might be happening please let me know. I put everything back together to what i thought was correct and everything was greased and or lubed before it was put in and the pins in the axle were put back in... Again any advice is greatly appreciated. Thanks a ton
nine7oh is offline   Reply With Quote
Old 08-18-2009, 09:49 PM   #2
nine7oh
Member#: 208840
2004 FXT, White
18ged
Bump For Some Help Please!!!
Tranny Leak after installing brand new Axle Seals?? Please help nine7oh Transmission (AT/MT) & Driveline 7 08-20-2009 02:17 AM
Tranny fluid leak!! silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-02-2007 06:10 PM
Front Diff/Tranny fluid leak... Mohaj Transmission (AT/MT) & Driveline 0 06-24-2006 03:45 AM
Dealer installed center diff: all my tranny fluid leaked out on the way home! dcoty Transmission (AT/MT) & Driveline 4 10-20-2003 01:14 AM
tranny fluid leak? Mr Cheese Forester Forum 2 12-31-2002 04:33 PM
