Old 08-18-2009, 11:06 PM   #1
02subiebro
Member#: 219130
02 wrx
blue
Default tumle generator valve?
I have a 02 wrx and hooked it up to the computer because check engine light is on and have two problems.problem one is HO2S HEATER CONTOL CIRCUIT LOW but im getting that taking care of and problem two is TUMBLE GENERATOR VALVE POSITION(sencor 1 circuit low) i looked it up and was seeing that people delete it for a couple hundred bucks.whats the smart thing to do and where is the cheapest i could get the part?
02subiebro is offline   Reply With Quote
Old 08-18-2009, 11:15 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the codes
we NEED the codes...the exact codes as in "Pxxxx"
the verbage is irrelevant
the codes
just the codes
Old 08-19-2009, 12:07 AM   #3
02subiebro
Member#: 219130
02 wrx
blue
02 sensor-P0037(BANK1 SENSOR2)
tumble generator-P1088
Old 08-19-2009, 12:43 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
rear o2 sensor heater is dead....opensource it and turn off the code...no worries
the passengers side tgv position sensor is likely dead and needs to be replaced...try unplugging it and re-plugging it
P1086 Tumble generator valve #2 ?? GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 03-31-2006 06:17 AM
P1088 Passenger Tumble Generator Valve Wrxified Service & Maintenance 0 06-03-2003 08:41 PM
Tumble Generator Valve - when do they swith off? rotorbaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-25-2002 09:11 AM
Tumble Generation Valve Info Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-21-2002 04:24 AM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 12:47 PM
