Old 08-19-2009, 02:09 AM   #1
Gel Mibson
Member#: 219009
2005 PSM WRX
Cobb AP st.2
Default How much air to put in tires with aftermarket wheels?
My car came with 17' Axis wheels. I'm not sure what type of model they are, but how can I find how much psi is supposed to be in each tire? Is there any way I can find out or is there a standard psi for 17' wheels with tires. Thanks
Gel Mibson is offline   Reply With Quote
Old 08-19-2009, 02:59 AM   #2
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
the wheel has nothing to do with it. read the tire (usually 42psi max). i would try 36 front / 34 rear and play around from there. its all preference
pauli18c is offline   Reply With Quote
Old 08-19-2009, 12:41 PM   #3
Gel Mibson
Member#: 219009
2005 PSM WRX
Cobb AP st.2
Thanks, i'll try that out.
Old 08-19-2009, 05:43 PM   #4
mosc
Member#: 177401
2015 STi White
Matters on the tire too, particularly when it comes to sidewall stiffness. Also, you'll definitely want less pressure around town than you would at the track.
I'm pretty sold on 35/32 atm but I have a very different setup than you. Experiment, you'll figure something out.
mosc is offline   Reply With Quote
Old 08-19-2009, 06:44 PM   #5
van_dutch
Member#: 198633
2004 WRX
Are you talking daily driving or at a motorsports event?
Some will swear by not putting less than 35PSI in to protect your wheels during daily driving. This, however, may not produce the response and wear you want during autox or a track day. Then there is drag racing which requires adjustments to hook up right. Regardless, I agree with mosc in that you need to experiment to find something that is comfortable and gives you the driving characteristics you desire.
van_dutch is offline   Reply With Quote
Old 08-19-2009, 08:41 PM   #6
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Whoa, the correct answer to the question depends on the tire in question first, the use of said tire second.
eg; If I put 36/34 in the tires on my car, I would be riding on marshmallows. I put 51 psi valve stems on and start with 45 front, 43 rear cold. I then will bleed off as needed at the course (auto-x). With that said, I haven't bled any off the last two events and they are right where they want to be.
Use a pyrometer if you are going to fine tune with pressure, it is the only way to be 100% accurate with what you are doing. If you are not running 10/10ths or even competing, then it is not as necessary, but wouldn't be a bad thing.
Each tire compound, design, and size have a sweet spot for alignment specifications and pressure. I wouldn't take advice from anyone who states otherwise.
Travis
UFOpilot is offline   Reply With Quote
Old 08-20-2009, 12:39 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Judging by the fact he doesn't even know what wheels and tires he has, I don't think he's asking how to tune his pressure with a pyrometer. That's a bit of overkill for 99% of motorists.
Starting with pressures in the mid-30s somewhere is a reasonable suggestion. Let us know the tire size and model and we can give more focused recommendations.
Pat Olsen
Old 08-22-2009, 06:56 PM   #8
Gel Mibson
Member#: 219009
2005 PSM WRX
Cobb AP st.2
Sorry, new to this, but I wrote this down from my tire. I'm not sure if it's the right information, but here it is.
BF Goodrich G-Force T/A KDW 225/45ZR17 90Y.
Just to clear some stuff up too - this car is for DD, not for tracking.
Old 08-22-2009, 08:02 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
So, again, mid 30s is a good place to start.
Old 08-22-2009, 08:03 PM   #10
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
In that case, whatever the max pressure on your door card is likely max. I assume you are stock valve stems. For daily driving with that tire, it is simple and any number between 32-38 would probably work just fine. I would start on the high side and see how you like the handling. Then I would get the rears a couple pounds lower than the fronts and see how you like that. Obviously when you find what you are looking for, stick with it. I would also suggest adjusting the front and rear independently otherwise you won't know which adjustment made the change you liked/didn't like.
Travis
Old 08-22-2009, 11:28 PM   #11
Gel Mibson
Member#: 219009
2005 PSM WRX
Cobb AP st.2
Thanks for the info guys!
How Much To Put In a Cat-Back Exhaust? Tek Southern California Impreza Club Forum -- SCIC 5 02-07-2004 10:41 PM
How much boost to run on VF22 with stock tmic? MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-27-2003 12:17 PM
How much $$$ to put in a EJ20 in a 2001 2.5 Rs? Szm426 Normally Aspirated Powertrain 3 07-28-2002 05:46 AM
T1-s's with 17" P1's - how much air? Hank3 Brakes, Steering & Suspension 4 07-22-2002 10:15 PM
How much air do our 2.5's take in per 1RPM? 8Complex Technical Forum Archive 14 06-08-2000 01:31 AM
