Old 08-19-2009, 01:18 AM   #1
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
Default Water/Methanol Injection question
i didnt find it
i have hydra 2.5 and about to buy the hydramist
i need to tune it for the hydramist
is that mean that the mist tank have to be full all the time??
even to myself it sound dumb question but i realy dont know!!
thanks
davidsti1 is offline   Reply With Quote
Old 08-19-2009, 05:30 AM   #2
WReXd
Member#: 114101
93 Impreza L Swap
No, your tank does not have to be full all the time. Depending on the size, shape, and location of your tank, you may want to keep it at least ~20% full at all times to prevent starvation. Ideally, you'd want a tall, thin tank positioned above the level of the pump. This will allow gravity to feed the water/meth to the pump.
WReXd is offline   Reply With Quote
Old 08-19-2009, 05:59 AM   #3
davidsti1
Member#: 210923
so as long as my tune is with hydramist the engine needs to get the fluid?
Old 08-19-2009, 08:16 AM   #4
WReXd
Member#: 114101
93 Impreza L Swap
Oh, I see what you're asking now. The hydramist has the ability to run multiple maps. If you want the option of running just pump gas, you'll need to have 2 maps, one tuned for water/meth, and one tuned for just pump gas. You will have to pay for an additional tune, but if you do this you won't ever need to worry about always having the tank filled.
A word of caution, though; it is a pita when you run the system dry. Air gets into the system, and it takes a while for all of it to get out. If you spray meth before all the air escapes, your flow rate will decrease. This should trigger the failsafe, but if it doesn't you could damage your engine. Try not to let your tank run completely dry.
Water/Methanol Injection FAQ DonkeyPunch Water/Methanol Injection, Nitrous & Intercooler Cooling 262 05-16-2016 12:03 AM
I have water/methanol injection in a 05 STI I have a question garboplateNY88 Water/Methanol Injection, Nitrous & Intercooler Cooling 12 07-21-2007 08:11 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
