Old 08-01-2009, 01:08 AM   #1
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
Default Methanol mixing question
Ok,
I'm sorry if this has been covered at all and I did try searching the forums but I couldn't find the answer.
When I mix methanol and water, does there need to be a emulsifier need to be used? Will the meth and water seperate? also, I know to mix by density, so what final density will i be looking for for a 60/40 mix? Basically you need 1.27 times as much meth as water right?
so 1 gallon of meth to .79 gals of water would be good for a 50/50 so 1.1 gals of meth to .711 gals of water is 60/40?
just worried about water seperating thats most of it. thanks for the help anyone
noonagon is offline   Reply With Quote
Old 08-02-2009, 11:37 AM   #2
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
so 25 views and no one can tell me if meth will stay mixed with water?
Old 08-02-2009, 11:41 AM   #3
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
why mix just run straight meth...thats what ive been doing for bout 3 yrs. unless of course you were tuned w/ a mix. TopSpeed should be able to answer your question i would think
krambte79 is offline   Reply With Quote
Old 08-02-2009, 01:23 PM   #4
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
i was tuned with a mix. the boost juice from snow performance.
Old 08-11-2009, 02:28 AM   #5
h.monay
Member#: 216469
Yeah Im very curious about the need for emulsifier too
so can anyone who mixes their own water and meth
chime in????
Okay nvm well according to Methanol Wiki
water and meth are miscible
and will mix
http://en.wikipedia.org/wiki/Methanol
h.monay is offline   Reply With Quote
Old 08-12-2009, 05:49 PM   #6
flycaster
Member#: 60142
Grey
OP - why are you concerned about density? I think you're being a little cerebral here: just mix it 50/50 (60/40, whatever) by volume and be done with it - that's what the rest of us do. And, yes, meth and water are 100% miscible, no "emulsifier" required.
Oh, btw..."boostjuice" is simply 50-50 with a colorant added. Mix your own and save big $$$.
flycaster is offline   Reply With Quote
Old 08-12-2009, 06:19 PM   #7
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
cause volume mixing is wrong when densities are involved. Not the same amount of material, thats like taking a cubic inch of gold and a cubic inch of aluminum, mixing them and calling it 50/50 its not. thanks for the info on miscible or not
Old 08-14-2009, 11:46 AM   #8
wackbards
Member#: 219625
2004 wrx sti
psm
ok this is a valid point: however, I'm pretty sure your tuner isn't a chemist, and I'd warrant a guess that the guys making the "boost Juice" aren't either. while I don't know, I think its pretty safe to assume that 50/50 means by VOLUME. you can probably check with the folks who manufacture boost juice, but my guess is that they wouldn't know specific gravity if it jumped up and bit them in the @$$...
having said that:
specific gravity of water = 1
specific gravity of methanol = .792
if you make a mix that is 50/50 water/meth by volume, you will create a mix that is 45/55 water/meth by weight. This 5% increase in meth concentration will increase the octane of your mix slightly, and increase the corrosiveness and flamability of the solution very slightly. Since many people run mixes as strong as 30/70 water/meth, I think 45/55 is pretty safe.
wackbards is offline   Reply With Quote
Old 08-17-2009, 05:00 PM   #9
flycaster
Member#: 60142
Grey
Originally Posted by wackbards View Post
...I think its pretty safe to assume that 50/50 means by VOLUME. you can probably check with the folks who manufacture boost juice, but my guess is that they wouldn't know specific gravity if it jumped up and bit them in the @$$...
Thank you. Let's leave the high school chemistry class out of this before this discussion denigrates into one about molarity, for goodness sakes. Boostjuice is a 50/50 volume mix, as are all the other mixes, period.
Old 08-18-2009, 02:08 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
bcblues is offline   Reply With Quote
Old 08-19-2009, 06:40 AM   #11
shaman
Member#: 164259
If you mix it, that is what matters. Mix it 1 gallon of each, and then get tuned for it. Or mix is 1.2858809547892893 galons to 1 gallon and get it tuned. Whatevr you do, just make sure you do it the same way next time, Your car doesn't know the difference of volume and weight, just the AFR.
shaman is offline   Reply With Quote
Water/Methanol Injection question davidsti1 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 08-19-2009 08:16 AM
Methanol Mixing Worksheets bcblues Water/Methanol Injection, Nitrous & Intercooler Cooling 25 03-11-2009 06:38 AM
Model Car Paint Mixing Question...Please Help! xfactor834 Off-Topic 6 07-30-2003 12:59 AM
Quick octane mixing question silverscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-29-2003 06:34 PM
('93-'01) Oil switching/mixing question AudiGuy Impreza Forum 10 04-27-2001 12:23 AM
