Old 05-04-2002, 02:34 PM   #1
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
Default EGT vs turbo
At what temp do you think a RS-T 99 (5.5psi) is should run un the hiway at 110 to115km/h and at 3000 to 3200rpm?
JST is offline   Reply With Quote
Old 05-04-2002, 05:57 PM   #2
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
do you mean at cruise? and if so, 5.5psi at 3000rpm and cruising? if you're getting 5.5psi at that point, I think there's something wrong w/ your car...
at cruise, you shouldn't run any hotter than a stock RS... under full boost(full throttle) tho, you'll probably get up around 1500 degrees F
mrbell is offline   Reply With Quote
Old 05-04-2002, 11:22 PM   #3
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
No, i run 0 boost or 15 vacuum at 3000rpm.
Help me explain this to a buddy. CFM vs PSI vs Power vs Turbo size Defiant Autospeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 02-09-2008 04:47 PM
5MT vs SportShift AT, n/a vs turbo, Impreza vs Legacy hikeeba General Community 1 10-17-2006 12:15 PM
EGT vs. Oil/Water Temp Gauges? Triance Electrical & Lighting 7 03-16-2003 11:53 AM
EGT vs. OBD-II 1wrxwag Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-25-2002 04:58 PM
EGT vs. Air/Fuel Gauge pfb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-03-2002 10:34 AM
