Old 08-19-2009, 08:01 PM   #1
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Default Wheel lock removal with no key...
Ok, so really this is for my Miata, but the question is the same and pertinent to all...
I have wheel locks, and I had a wheel lock key until my dumbass left it on the wheel for a test drive.
How can I get the wheel locks off?
I've tried the Sears/Craftsman removal kit and all it did was strip the fluting out of the removal socket and give the wheel lock a nice shine....
Problem is, I can't really take it anywhere because the rear brake caliper is seized... (hence the reason for the test drive.)
And I have no welder.
Bueler?
DiscoGsus is offline   Reply With Quote
Old 08-19-2009, 08:43 PM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
get another removal tool and hammer it on. the flutes wont cut the nut, but they can deform it. only the surface of the nut is hardened.
sniper1rfa is offline   Reply With Quote
Old 08-19-2009, 09:19 PM   #3
dundunskeert
Member#: 184151
2000 STI RA Limited
Get a 12 point socket that is just barely to small and hammer it on then just put a ratchet on the socket and take it off.
dundunskeert is offline   Reply With Quote
Old 08-20-2009, 08:04 AM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
dremel 2 sides flat and try to get it off with an open end wrench? That or the 12-pt-socket-pound-on method.
Old 08-20-2009, 08:59 AM   #5
Mi_Panic
Member#: 221016
2008 VW
Grey
I've done this before and it worked out great, it was also a pain.
Mi_Panic is offline   Reply With Quote
Old 08-20-2009, 09:01 AM   #6
ardevas09
Member#: 164710
05 440whp STi
2014 Evo X
dremel idea FTW
ardevas09 is offline   Reply With Quote
Old 08-20-2009, 09:43 AM   #7
littlewhitewagon
Member#: 103068
11 STI sedan
Pounding on a cheap 12 point socket, tighten the other unlocked lug nuts, then loosen the locked lugnut by hand. I have done this numerous times and on VERY expensive wheels like HRE, Rays, Works... this is the only way that I can almost guarantee no wheel damage. When you are going to pound that socket on, use an extension so you can get the socket square and give it a good whack. Use painters tape if the socket is tight and may scratch the wheel.
littlewhitewagon is offline   Reply With Quote
Old 08-20-2009, 09:34 PM   #8
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Win.
5lb sledge to hammer a 19mm socket on the wheel lock, 18" breaker to get them off. Stupid ****ing wheel locks.
Impreza Turns off, then turns on with no key Jutboy Electrical & Lighting 2 02-23-2009 12:40 PM
getting out of valet mode with no key fob???? dstnbmxvr6 Car Audio, Video & Security 1 04-18-2008 02:48 PM
rear differential/wheel lock removal efmd3 Transmission (AT/MT) & Driveline 15 03-17-2008 08:29 AM
Help.. need wheel lock removed ASAP Butt Dyno Mid Atlantic Impreza Club -- MAIC 31 04-20-2005 08:20 PM
Brake light with no key brunetmj Electrical & Lighting 4 09-12-2004 08:51 PM
