Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 12-17-2009, 11:23 PM   #126
wrblue_sti04
Member#: 208103
Originally Posted by Merp View Post
Are you basing that on that video alone?
Devils advocate: Tire pressure, track prep, and suspension could all need work.
Right!!
1st pass 18psi tire pressure, no track prep 1.67
2nd pass less psi tire pressure 1.56 but had transfer case issue
I think we hit 1.4 with prep track
wrblue_sti04 is offline   Reply With Quote
Old 12-18-2009, 02:28 AM   #127
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Car also picked up 2mph with the tire...
What other 17" DOT tire has gone 9s on the EVO/STI platform?
Junior2JZ is offline   Reply With Quote
Old 12-18-2009, 02:42 AM   #128
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
In this case, obviously not, considering people have cut better 60's by almost two tenths on the tire.
Originally Posted by davidbuschur
I have said in past to you Tom, I am not in the tire business, I don't sell tires, I have no tire sponsors, I have nobody giving me tires, I have no dog in the fight of tires, could care less other than my typical sticking my nose into topics of interest, which this one interests me.
I can't speak for everyone but of the drag radials on the market I know of I don't personally know anyone running 13-15 psi of air in them. I could absolutely be wrong but myself, Kevin, Trent, Daniel do not run any of the tires we have tried that low. 18-22 psi is where they seem to like to be run. At the shootout Chris ran the Hoosiers and the BFG's, he had a 1.52 sixty foot on the BFG's, his 4th gear was completely gone as you know so I have no input to his overall ET, that 1.52 was quicker by a good margin than he had the Hoosier that day. Jeff's best was a 1.60 I think and that's a 600+ whp car and Jeff is a good driver. At the same race Project White on the MT's, 18" heavy tire ran a 1.53.
Personally, selling a tire designed for drag racing that isn't producing the best 60' times seems a little "off" to me.
Congrats to Indy for having connections, that is what he brings to the table, tons of connections. Just building a tire with a brochure of specs but not stellar 60' times seems nuts to me. Congrats to you Tom for putting every minute you have into furthering the tune on Indy's car.
The ET/MPH change I see seems to me to be from a lighter tire/wheel package, lighter clutch that actually hooks up and holds the power and continuous work on the tune.
The tire, glad to see it in a 17", too bad it doesn't work for anything but dry use, it's not really recommended for street use (per Tom) and it isn't hooking very well by comparison to other tires that do those other things too.
Bringing a product to market that isn't ready yet won't make a new business stick around for very long.
I am only posting in here again to make something very clear.
I AM DAVID BUSCHUR, I am only responsible for what DAVID BUSCHUR says or types, nothing else and not from anyone else. I am not in the back ground getting with people to start crap, if Slorice, Big Al or anyone else makes a post it is THEIR own doing and THEIR own freaking opinions. DO NOT drag me or Buschur Racing into all the drama. I am sick of that ****.
I asked my questions in here and made my points, those were mine. Anyone else making posts, those are theirs and have nothing to do with me.
Now carry on leave me and Buschur Racing out of this.
Also, IF there is a problem between myself and Tom, Jim or my momma's baby's momma it is nobody's concern here unless it is posted publically for the rest of you to get involved with.
As far as I know there is no problem though to be clear. Tom and I have not talked but it is apparent and definite that things have changed.
Now that I am fired up and on a roll. Tire testing or any other testing required testing. Running a tire on a car isn't proving jack. You want to test, get two sets of identical wheels with the Hoosier on one and the BFG or something else on the other and then go to the track, rent it so you can actually do some testing. That is testing. Changing a bunch of parts, season changes, tune changes and fuel changes and talking about how good a tire is is not testing a tire. Also testing is good, selling 40 sets of tires and calling that testing is not good. I've found you test and prove something first and then sell it, not the other way around. I'd be hung if I did the same thing, so Tom and Jim you should both expect some grief, welcome to the EVO game of being a vendor. You guys are no longer "the good ole boys helping eveyone out." Now you are 9sec9.com and you will be held accountable for your sales and such by the people here, just like I am and all the other vendors. Welcome to the real world.
Old 12-18-2009, 02:49 AM   #129
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
You know the more power you make the harder it is to hook right? So if you put say a BFG 17" or Nitto 17" drag radial on this car it would probably cut 1.8s....
I would say hooking a 1.6/1.5 on a 152mph car with a 17" drag radial is pretty impressive.
Why don't you get to the track so you can add a real record to your signature on EVOM
Old 12-18-2009, 03:05 AM   #130
juanmedina
Member#: 133146
07 FPgreen 7.37@95
no really
Think about it, those tire are expensive and there is no real use for them. There is no point.
Why do you want to run 17" wheels and the amazing tires of 9sec9 for your 9 sec car if you are going to cut 1.56 60' ?
I rather run a 16" wheel with Hoosier QTPs (DOT tires) like Cwill and cut a 1.39 60'
Why run this tires with a high 11 low 12 sec car when Indy Evo has only been able to cut a 1.63-1.7? When CJ and Mikey have been able to cut a 1.60 and I think a 1.59 on regular summer tires. + this tire suck in the rain
Just because they send you a couple of sets doesn't mean that you have to like them
Have you seen Mikey's sig here on NASIOC that one is funny
Old 12-18-2009, 01:10 PM   #131
taossti
Member#: 145445
05 Time Attack STi
I would think that there are other factors that play with 60ft times. Suspension set-up and..oh, the driver.
Also, it takes a little getting used to different tires or set-ups to make it work.
I thought these Hooters were made for the (everyone has them) 17" wheels. Going down to 16 or 15' wheels may work for some cars, but you'll have to change brake set-ups then.
I wear Fruit -O-Loom and the next guy wears Hanes because it works for him.
taossti is offline   Reply With Quote
Old 12-18-2009, 02:04 PM   #132
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Originally Posted by juanmedina View Post
no really
They end up costing as much as a BFG/Nitto
They are for fast cars that want to retain the oem big brakes. I have cut 1.5s on all seasons, does it mean I will put the same all seasons on my car making 500 more whp and still cut 1.5s? That is what you don't seem to get.
Dont even get into the nitto tire, unless you plan on doing a big burn out.. they wont hook for ****.
On the Subaru they will improve gearing vs running a BFG since they only make the 235/40/17.. They will keep you in power longer, and they are lighter.. which helps as well.
Old 12-18-2009, 02:06 PM   #133
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
It may be funny..... But its the truuufe
Ill say this and stand by it. If you have 450whp or less, buy drags, run 18-19psi of tire pressure, a quick slip dump, and hello 1.50-1.60.
I cut about 40 sub 1.65's with my stock turbo, no over exageration. They were all in between me having drive train isues that even still exist. LC, only big turbo guys need it.
I think if my diffs or whatever is going on with my drivetrain was fixed, I'd be able to hit 1.5x's almost every time at a decently prepped track (now). To get a perfect launch, there is def physics and feel. To get a decent launch (high 1.6's), its easy. You just have to not care about the car one bit (like i did for 60k, and now the car doesnt launch, lol)
STi Mikey is offline   Reply With Quote
Old 12-18-2009, 02:09 PM   #134
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Put a 39/43 on your car for a weekend this season. I will lend you the tires, you can post how you like em... along with the 11sec slip
Old 12-18-2009, 02:11 PM   #135
neonglh
Member#: 127886
Hoosier QTP, 9.5 @ 156 so far from our shop, STM.
neonglh is offline   Reply With Quote
Old 12-18-2009, 02:16 PM   #136
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
send me a set son.
wrxwhat is offline   Reply With Quote
Old 12-18-2009, 02:32 PM   #137
juanmedina
Member#: 133146
07 FPgreen 7.37@95
From EVOM,
{thumbdwn} since when a 1.67 and a 1.56 is good at that power level {thumbdwn}
It sounds like they don't hook for crap {pcfreak}
That's not really a fair assessment. You have to give people time to get their cars dialed in and get a good 60ft. I mean, geez, these tires have only been out for 5 months now......
Originally Posted by JuniorAWD View Post
So what other 17" DOT tire has gone 9s on a EVO/STI?
Daniel Buschur's Red Evo went 9.8@148 a few years ago on a set of 17" BFG drag radials. I'm sure there are more too, but he's the first one to come to my mind.
I also know of multiple people cutting low 1.5's on the BFG's.
In my opinion, the BFG drag radial is a real DOT tire.....something that can actually be driven on the street and still cut low 1.5's at the track. The Hoosier drag radial is just a slick tire with a couple grooves in it to get the DOT seal of approval. But its a tire that has been recommended to never take on the street.
This thread is yet another example of a tire that is not performing up to what it was claimed to do.
Old 12-18-2009, 03:13 PM   #138
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Im completely down for that. All I have to do is fix the drivetrain issue. Ill probably see if jimmy can take the trans/diffs out and take a look at them. Or send it to rallispec to have it analyzed.
Old 12-18-2009, 03:32 PM   #139
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
From EVOM,
So...... . What does that have to do with what I posted here to you?
PS
Tim always has something negative to say about IndyEVO or anyone anti Buschur. I don't know why, but that is just how it is.
Old 12-18-2009, 06:53 PM   #140
wrblue_sti04
Member#: 208103
Thanks Junior...we haven't finished the work with the tires. Before end of year we expect to take the car to the track and see if we reach 1.4 and run 9.3 - 9.4 We like to do things when all the probabilities go in the opposite direction
Old 12-29-2009, 11:15 AM   #141
wrblue_sti04
Member#: 208103
Old 12-29-2009, 09:22 PM   #142
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Very nice guys... I hope I can get these kind of times out of my RS with the 17s.. That is simply awesome!!
Its nice to see a 700+whp car hooking on 17s
Old 12-29-2009, 09:25 PM   #143
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Originally Posted by wrxwhat View Post
send me a set son.
I missed this the first time around. I was down @ CFT and met one of the RealStreet guys.. they were tuning a twin turbo police interceptor
Old 12-30-2009, 12:33 AM   #144
CVR STi
Member#: 127428
JR- For the street which would you like better..... hoosiers, BFG, or MT radials ?
CVR STi is offline   Reply With Quote
Old 12-30-2009, 12:38 AM   #145
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
For all around street driving the MT 18" radial that I cut low 1.5s with would be my choice. It was "ok" in the rain, and worked awesome in the dry.. much nicer then the BFG.
For all out street racing action, the Hoosiers get my vote.
Although I did bog the car in the rain with the hoosiers trying to launch it
Jr
Old 12-30-2009, 12:42 AM   #146
CVR STi
Member#: 127428
Seems like you cant do much driving at all with hoosiers..... probably dangerous as **** in any kind of turns
Old 12-30-2009, 12:44 AM   #147
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Na they are not that bad at all.. I wouldnt drive them in the rain though
Dry turning etc was no problem, they felt as good if not better then the bfg/mt
Jr
Old 12-30-2009, 12:49 AM   #148
CVR STi
Member#: 127428
I see.... thanks for the info!
Jr
Old 12-30-2009, 10:23 AM   #149
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Mother ****er you were in Orlando? I heard you were coming down to Sarasota and tuning at that Full Throttle shop, didn't know you would be in Orlando though. Who from the shop did you meet?
Old 12-30-2009, 11:45 PM   #150
wrblue_sti04
Member#: 208103
THANKS!!! More videos..
http://www.grs-motorsports.com/notic...ciembre/10.wmv
http://www.grs-motorsports.com/notic...ciembre/11.wmv
FS: Hoosier 245/45/17 onRadar MAIC Private Classifieds 8 01-24-2010 02:10 AM
TX ATX: 2006 Silver BBS with Hoosier 245/45/17 R6 tires turboge Wheels/Tires 23 08-11-2009 10:59 AM
ATX: 2006 Silver BBS with Hoosier 245/45/17 R6 tires turboge TXIC Private Classifieds 17 08-11-2009 10:59 AM
4 Hoosier Cup R Comp 245 45 17 BGPKR Wheels/Tires 8 10-17-2007 03:51 PM
WTB: gently (haha) used Advan/Hoosier/Kumho race tires 245/45/17 bpwatts TXIC Private Classifieds 2 12-08-2006 12:25 PM
