Old 02-27-2013, 08:15 PM   #176
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Originally Posted by Junior2JZ View Post
No fading away, just been proven to work yrs back.
This was last seasons data
Trapped [email protected] on them with 4th on a 07 box
Trapped 143 shifting 5th on the old style trans
10.0s, low 1.4s....
Good to hear. Thanks for the reply.
06rexwagon is offline   Reply With Quote
Old 02-27-2013, 09:13 PM   #177
06rexwagon
Member#: 114730
[email protected]
Wait 143mph but 10.0?
Old 02-27-2013, 09:20 PM   #178
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Heavy ass street car and a 1.7 60ft will do that.
Junior2JZ is offline   Reply With Quote
Old 02-27-2013, 09:26 PM   #179
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
You might also look at the m&h drag radials that dave buschur helped develop,I heard Mike and the guys at awd got even better results from them then the hoosiers.You would probably have more info on them than I do JR.Also heard they are a little safer to drive on the street since the sidewall is not as squishy as the hoosiers.I hope to have a set for this year to try out so I can cut consistant mid 1.4's.
john 1badSTI is offline   Reply With Quote
Old 02-27-2013, 10:46 PM   #180
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
M&H is a very nice option... Honestly either one will do the trick.
I don't know about the sidewall thing though, I made a low [email protected] pass in my buddies GTR with the 18" version and was stressed out.. lol They felt like a real deal slick up top haha
Old 02-27-2013, 11:04 PM   #181
06rexwagon
Member#: 114730
[email protected]
Since they're going on my wagon I'm going to have fitment issues I'm sure. I'm concerned about the bias ply growing under speed and also concerned about their stability. I have a set of the Hoosiers on their way. They're going on stock 2006 STi BBS wheels.
Old 02-27-2013, 11:10 PM   #182
john 1badSTI
Member#: 77470
^^^its like riding on marshmellows on the big end huh JR.lol good luck and be careful when you get them CAM.
Old 03-01-2013, 01:13 PM   #183
06rexwagon
Member#: 114730
[email protected]
Jr, are you guys doing a small burnout with these?
Old 03-01-2013, 05:46 PM   #184
4Warned
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
I will let you know how they work in about a month
4Warned is offline   Reply With Quote
Old 03-01-2013, 05:53 PM   #185
fonsworth
Member#: 260681
07 sti
10.90 @ 127
awesome tires!! like john aid its like marshmellows, the comes out so soft.
fonsworth is offline   Reply With Quote
Old 03-01-2013, 10:07 PM   #186
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
I'm kinda surprised that these tires are that unstable on the big end.
Md05STI is offline   Reply With Quote
Old 03-02-2013, 12:34 AM   #187
06rexwagon
Member#: 114730
[email protected]
I think he was talking about the m&h tires.
Old 03-02-2013, 11:06 AM   #188
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Even with those it's kinda surprising. It's not like there big sidewall 15 or 16's.
Old 03-02-2013, 06:04 PM   #189
john 1badSTI
Member#: 77470
no I was referring to the hoosiers,when crystalimpreza(jeff) told me about his experience driving to the track on them and said that whenever he turned it felt like the tire was ready to roll off the rim,which made me assume the sidewall was really thin and soft like a slick.This would make them kinda unsafe to really run on the street as a daily tire.
Old 03-02-2013, 06:15 PM   #190
06rexwagon
Member#: 114730
[email protected]
They won't see any street use on my car.
Old 03-02-2013, 06:39 PM   #191
john 1badSTI
Member#: 77470
then you should be good,just be careful on the big end at high speeds.
Old 03-02-2013, 07:49 PM   #192
06rexwagon
Member#: 114730
[email protected]
Our track is at 5400'. We don't have high speeds.
Old 03-02-2013, 07:55 PM   #193
ASF Machine
Member#: 236349
1993 Impreza
OD Green
RE the M&H DRs:
They are the real deal, high 1.5 60' without 2 step or LC on stock axles. Most forgiving DR IMO.
ASF Machine is offline   Reply With Quote
Old 03-06-2013, 06:13 PM   #194
06rexwagon
Member#: 114730
[email protected]
Got mine mounted and will need spacers as the rear is touching the strut. This is on a wagon with 5x114 bbs wheels. Fronts fit but at full lock touch the inside of the fender just a little. Probably doing a 15mm spacer.
Old 03-07-2013, 12:01 AM   #195
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Originally Posted by ASF Machine View Post
RE the M&H DRs:
speaking of....I am on the hunt for 1.4x's
C J is offline   Reply With Quote
Old 03-13-2013, 04:01 PM   #196
06rexwagon
Member#: 114730
[email protected]
Got mine on the wagon finally. Rolled the rears and did a slight pull too, all using the Eastwood roller and a heat gun. I needed spacers to get the inside of the tire off the strut and the body of the car. I ended up using Ichiba 15mm v2's. The tires fit, but just barely.
Fronts just clear the liner
rears at full tuck.
Track saturday!
Old 03-14-2013, 08:46 AM   #197
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
How tall are they Cam?
Old 03-14-2013, 09:18 AM   #198
06rexwagon
Member#: 114730
[email protected]
Hoosier lists them at 26 inches.
Old 03-14-2013, 09:56 AM   #199
manitou
Member#: 193757
2006 XTI Limited
Thanks! Yeah I need something taller.
I'm thinking of running just rear drags and matching them to my 245/45x18's. Junior said Mickey Thompson's got a tire that may work. It looks like it's the 265/40x18, 26.5" tall, 38" circumference, 9.6" tread width, 10.6" section width. They might work if I match them up with my worn Conti's 245/45x18 at 26.7" tall, 38.8 circumference new. I will need a set of rear 18x9 wheels and I'm not sure I can get this tire inside my rolled and slightly pulled rear fenders.
Hmmm? I'll have to work on this a bit!
Old 03-14-2013, 03:50 PM   #200
john 1badSTI
Member#: 77470
remember going to an 18 will have a shorter sidewall thus defeating the purpose of a soft sidewall to help absorb the shock of the launch to help plant and keep planted the footprint of the tire.
FS: Hoosier 245/45/17 onRadar MAIC Private Classifieds 8 01-24-2010 01:10 AM
TX ATX: 2006 Silver BBS with Hoosier 245/45/17 R6 tires turboge Wheels/Tires 23 08-11-2009 09:59 AM
ATX: 2006 Silver BBS with Hoosier 245/45/17 R6 tires turboge TXIC Private Classifieds 17 08-11-2009 09:59 AM
4 Hoosier Cup R Comp 245 45 17 BGPKR Wheels/Tires 8 10-17-2007 02:51 PM
WTB: gently (haha) used Advan/Hoosier/Kumho race tires 245/45/17 bpwatts TXIC Private Classifieds 2 12-08-2006 11:25 AM
