Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 08-20-2009, 01:04 AM   #1
sonniwrx
Member#: 205479
2008 WRX, Legacy Gt
Default After Pumping gas, car doesnt start!!
Third time this happen, and its everytime i pump gas. i got a walbo fuel pump 255l. and everytime id go to pump gas it has trouble starting, after it start it dies. once i get it on the road and drive for a few min. everything is good. please help or any idea what to do, i tried filling up while car was on, it died once it started pumping, then i tried pumping when tank was half n car was off didn't start, then tried filling it up same problem.
sonniwrx is offline   Reply With Quote
Old 08-20-2009, 02:07 AM   #2
lennybootzz
Member#: 190811
04 gt35r built
wrb sti
sounds like ping pong balls in the gas tank
lennybootzz is offline   Reply With Quote
Old 08-21-2009, 12:53 AM   #3
sonniwrx
Member#: 205479
2008 WRX, Legacy Gt
I got a Check engine light P0457
Old 08-21-2009, 07:01 AM   #4
06mattsti
Member#: 174796
2006 STI
I just got that code. Alot of times it just means you need to tighten the gas cap. In my case, I had a disconnected evap hose. Its to the right of the turbo inlet, best way to see it is by removing the alternator. There are a few evap hoses down there though.
06mattsti is offline   Reply With Quote
Old 08-21-2009, 07:08 AM   #5
06mattsti
Member#: 174796
2006 STI
If your having a problem even starting the car though, it could be a number of issues. Might have something to do with the carcoal canister, and the hoses related to that.
Old 08-21-2009, 09:30 AM   #6
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
I thought your year was drive-by-wire. Why are you pumping the gas pedal? IIRC, just putting the key in the "ON" position feeds fuel and pressurizes the system. I don't think the actual gas pedal "turns on" until the engine is started.
If I am wrong, someone please correct me. I am pretty sure, but I could be wrong.
TEK112 is offline   Reply With Quote
Old 08-21-2009, 09:44 AM   #7
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
I think what OP means by pumping gas is that he is at the gas station filling the car up with gasoline and paying money to OPEC
48mpg is offline   Reply With Quote
Old 08-21-2009, 11:09 AM   #8
TEK112
Member#: 218140
Wow, I feel retarded. Sorry.
I'm thinking the system is having trouble pressurizing. Check the pump gaskets as well as gas cap and evap control.
Old 08-21-2009, 08:46 PM   #9
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
Fuel filter?
Astartes is offline   Reply With Quote
Old 08-21-2009, 11:45 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
You don't overfill the tank, do you? Stop after the first click or you could fill the evap canister with gas.....
bcblues is online now   Reply With Quote
Old 08-22-2009, 02:26 AM   #11
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
^ this. If you do it a few times it done and you have to replace it. My mom did this to there new Impala 3 months back. She was adding 1-2 gallons after the pump shut off to top the tank off and this is exactly what it did to the car.
Later.
Badmunky is offline   Reply With Quote
Old 08-22-2009, 02:59 PM   #12
Got Boost?
Member#: 113096
06 sti
I am gonna take a stab at this and say he is having the same problem I have been for a long time. I go to the gas station to put gas in my car and then proceed to start it afterward with the same result, and no I am not overfilling the car after the initial click. What I have realized is that the motor becomes flooded and full on runs like crap until driven/cleaned out. I have had much bigger problems, like getting my car running again, and havent had the chance to figure out what it is that is causing it. I have a few ideas as to what it might be, and was gonna work on it until I broke more crap...again.
To the OP, what mods do you have on your car? maybe we can compare and see if that helps. I kinda have a feeling what it might be. Also if you put the gas pedal all the way to the floor when starting, the motor will not prime with fuel when rotating the key to the start position and make the start up a little easier. For obvious reasons, dont leave the pedal on the floor after start up though.
Got Boost? is offline   Reply With Quote
Old 08-24-2009, 08:38 PM   #13
ylime02
Member#: 172814
02 wrx wagon
wrb
I have this same problem after replacing my o rings and fixing a boost leak, I took the entire intake manifold off and we broke a sensor right next to the inlet...so I would check all your hoses and the sensor.
ylime02 is offline   Reply With Quote
Old 08-25-2009, 09:13 PM   #14
Got Boost?
Member#: 113096
06 sti
I know what sensor you are talking about...its the purge control solenoid for the canister. I also broke it the 1st time I had my manifold off With that being said, did replacing the solenoid fix your problem?
Old 08-26-2009, 12:51 AM   #15
ylime02
Member#: 172814
02 wrx wagon
wrb
still waiting for it to come... my car decided it wanted to leak again today so im pretty po'd at it right now...i think i might ground it again..and take away its cell phone and laptop..kids these days err i mean cars these days...im tired of fixing it!
Old 08-26-2009, 08:45 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
****ed up the install and likely need to replact the gasket at the top of the pump assembly
Old 08-26-2009, 12:43 PM   #17
Got Boost?
Member#: 113096
06 sti
story of my life....my car is broken more than running its a money pit
Old 08-26-2009, 12:44 PM   #18
Got Boost?
Member#: 113096
06 sti
are u saying that a bad fuel tank/pump gasket will cause the motor to flood when putting gas in the car?
Old 08-26-2009, 10:58 PM   #19
richy_21
Member#: 58670
2005 got muuuuu?
If the gasket was bad id bet you would get the CEL and you would smell gas in the car....
richy_21 is offline   Reply With Quote
Old 08-27-2009, 04:26 AM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 08-27-2009, 11:28 AM   #21
richy_21
Member#: 58670
2005 got muuuuu?
^I was refering to boost not the other guys. I dont think boost got the cel yet ................
As for that gasket, like i said if it was bad, you would smell the raw fuel smell alot.
Old 08-27-2009, 11:53 AM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
no......the p0457 leak is a 'small' leak usually associated with not tightening the gas cap enough
but since the OP has swapped fuel pumps....I'll assume that the issue lies with the gasket being pinched/distorted
Old 09-06-2009, 12:13 AM   #23
Got Boost?
Member#: 113096
06 sti
i have swapped fuel pumps when I installed a ton of other parts. I do not smell gas, have no cel, and it did not happen till maybe a year later? I just got my car running again, stupid oil pick up broke, and I will try and get this figured out again
Old 09-06-2009, 11:14 PM   #24
WcW
Member#: 209963
The engine is flooding through the charcoal canister lines.
WcW is offline   Reply With Quote
Old 09-12-2009, 04:34 PM   #25
Got Boost?
Member#: 113096
06 sti
whats the fix?
After I filled up some gas, the car won't start zac5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-17-2009 06:19 PM
Cleaned IACV then primed fuel pump, now car wont start!! blessed0903 Service & Maintenance 0 10-13-2009 04:18 PM
Car doesnt start first try (I STFA) PushinRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-09-2008 03:06 PM
Hard to start after getting gas St0k3d Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-09-2005 07:26 PM
Car doesnt seem to "GO" after 4k... then CEL drkwtsn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-14-2005 03:08 PM
