Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 09-12-2009, 05:06 PM   #26
vinxH
Member#: 159796
2006 WRX
when did you buy your WRX? it may still be under warranty? i would think that powertrain may cover it, if not... dealership might do a good will if you put up an argument with them
vinxH is offline   Reply With Quote
Old 09-12-2009, 05:16 PM   #27
Got Boost?
Member#: 113096
06 sti
im in vegas and the dealer here sucks They cannot diagnose a car at all. One of the guys from flat4 took his car in for a cel. the dealer installed a new turbo, injectors, engine harness, new short block and still could not fix the problem. It turned out to be a dirty maf so they installed a new $12k maf sensor
Got Boost? is offline   Reply With Quote
Old 09-12-2009, 05:26 PM   #28
vinxH
Member#: 159796
2006 WRX
I wouldn't complain.
Old 09-12-2009, 07:45 PM   #29
Got Boost?
Member#: 113096
06 sti
I wouldnt have if it was my car...long story short, I got the complete other end of the spectrum when my motor had a broken ring landing at about 15k
Old 09-12-2009, 09:57 PM   #30
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Sounds like you have a partially stuck open Canister Purge Valve (the one bolted to the intake manifold)
Its allowing vapor from the from the tank to enter the intake manifold during fueling this is causing the hard starting. All the vapors should be going into the canister.
Old 09-13-2009, 02:10 PM   #31
Got Boost?
Member#: 113096
06 sti
ill pull it off next time I fuel up, or just clamp the hose...I was thinking the same thing before. but what bothers me is the fact the canister is at the back of the car and the purge control is all the way at the front, so it would have to travel through the canister first
Old 10-29-2012, 01:28 PM   #32
Got Boost?
Member#: 113096
06 sti
Ok, so after a long time down.... I installed new/bigger pump (dw300), new/bigger injectors, fuel pump gasket, removed the manifold and did some cleaning up....All the vacuum lines are good. All the pcv hoses were replaced, all sensors seem to be working. I put gas in the car and it flooded. I am also trying to get my readiness monitors to set so I can smog the car and while driving the car yesterday, a CEL came on ...p0457. I am gonna pull the back seat out and check to make sure the pump is tightened enough with the new gasket. I have also started to pull different hoses at the manifold around the purge control to see if it has any effect. Hopefully I can knock both problems out in one shot? If anybody has any ideas, it would really be appreciated as well.
Old 10-29-2012, 01:33 PM   #33
Dillinja666
Member#: 332644
07 STI
Its white
^^^ This
Dillinja666 is offline   Reply With Quote
Old 10-29-2012, 02:13 PM   #34
Got Boost?
Member#: 113096
06 sti
Originally Posted by Dillinja666 View Post
^^^ This
I am almost wondering if it would be covered by the 8/80 emissions warranty? But my car is so modified I think they would just tell me no as an easy way out?
Old 10-29-2012, 02:17 PM   #35
Dillinja666
Member#: 332644
07 STI
Its white
Well yes if the dealer was a decent one it would be. The EVAP system is definitly part of the emissions system. Some dealers though if the car is overly modified will just throw their hands up and say no though. Might be a good idea to call the dealer you want to go to, tell them the code you have and then tell em that you have modified the car and see if they will play ball with you of if they tell ya to GTFO.
Old 10-29-2012, 04:37 PM   #36
Got Boost?
Member#: 113096
06 sti
So, as per the EPA and the standards they instill, the only three parts covered by 8/80 are the pcm, catalytic converter, and the OBD (on board diagnostic) device. So Ill have to get some more dirty and post what I find
Old 10-29-2012, 04:40 PM   #37
richy_21
Member#: 58670
2005 got muuuuu?
I had this same issue. Removed my canister and poof no more problems..
richy_21 is offline   Reply With Quote
Old 10-29-2012, 04:46 PM   #38
Dillinja666
Member#: 332644
07 STI
Its white
Oops brain fart...I thought you ment the 5/50 or whatever the bumper to bumper warranty is. Yes you are correct for the 8/80. An stuck open purge can cause this issue.
Old 10-29-2012, 08:36 PM   #39
iSTI
Member#: 241769
3 years later i wonder if you got this fixed would like to know what the issue was. lol
iSTI is offline   Reply With Quote
Old 10-29-2012, 08:48 PM   #40
Got Boost?
Member#: 113096
06 sti
Lol.... i have had 2 major break downs, parked the car and have almost parted/sold the car a few times. I am hoping to get tuned this week and will continue to update when i figure it out...unless it blows up again. If that happens, the car is gonna turn into a big down payment on another house after i get rid of it
After I filled up some gas, the car won't start zac5 Factory 2.0L Turbo Powertrain 10 11-17-2009 06:19 PM
Cleaned IACV then primed fuel pump, now car wont start!! blessed0903 Service & Maintenance 0 10-13-2009 04:18 PM
Car doesnt start first try (I STFA) PushinRice Factory 2.5L Turbo Powertrain 7 09-09-2008 03:06 PM
Hard to start after getting gas St0k3d Factory 2.5L Turbo Powertrain 1 11-09-2005 07:26 PM
Car doesnt seem to "GO" after 4k... then CEL drkwtsn Factory 2.0L Turbo Powertrain 2 06-14-2005 03:08 PM
Message Board Statistics All times are GMT -4. The time now is 08:04 AM.
