Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 08-20-2009, 10:04 AM   #1
nicksamba_18
Member#: 120770
2002 Subaru WRX
Default Changed plug, ran fine, then sputtering and misfiring again....hallllp
So cyl#2 was misfiring, started simple and changed out the plugs on both cyl 2 and 4. I took the car out for a drive to ensure all was well, after 10 minutes with about 3 min of spirited driving it went back to misfiring.
Injector?
Coil pack?
Injector?
What are your experiences?
nicksamba_18 is offline   Reply With Quote
Old 08-20-2009, 12:31 PM   #2
bzbuzz
Member#: 116052
2011 STI ( Sold )
what plug are you running? stock?
bzbuzz is offline   Reply With Quote
Old 08-20-2009, 12:42 PM   #3
nicksamba_18
Member#: 120770
2002 Subaru WRX
Yes, I bought stock replacements
Mods are intake and turbo back
Old 08-20-2009, 04:01 PM   #4
nicksamba_18
Member#: 120770
2002 Subaru WRX
anybody?
I plan on doing the work tonight, but needs some direction.
Old 08-20-2009, 10:03 PM   #5
lotarg
Member#: 90940
You use 93 octane gas right?
lotarg is offline   Reply With Quote
Old 08-20-2009, 10:44 PM   #6
nicksamba_18
Member#: 120770
2002 Subaru WRX
Always
Old 08-21-2009, 03:43 PM   #7
DCales
Member#: 131509
2006 Impreza WRX
What engine management are you using? Stock, Cobb, Etc... If you have a volt/ohm meter you can do some quick tests on the coil and injector to see if the resistance is within spec. Also could test for power to both while your at. You may want to consider having a compression test done to see if it is a mechanical issue. Also check the spark plugs that you installed to see if you may have damaged the insulation while installing as that does happen on occasion.
DCales is offline   Reply With Quote
Old 08-21-2009, 07:12 PM   #8
nicksamba_18
Member#: 120770
2002 Subaru WRX
I bought a new coil pack today, installing around 9pm.
I am on stock engine management.
What is the spec on the ohms in the coil, it was tested last night but I dont know what the resistance should be.
Old 08-21-2009, 07:14 PM   #9
nicksamba_18
Member#: 120770
2002 Subaru WRX
I cant really get a compression test done, the car is sitting in my garage right now. I am almost afraid to drive it becuase I dont want to cause anymore damage.
Trying to avoid getting this damn thing towed.
Old 08-21-2009, 08:24 PM   #10
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
switch coils and/or injectors to different cylinders, see if misfire codes follow.
Old 08-21-2009, 08:30 PM   #11
nicksamba_18
Member#: 120770
2002 Subaru WRX
Great idea, however, I do not have a code reader.
Old 08-21-2009, 08:36 PM   #12
gopsu
Member#: 96448
02 WRX VF34
this seems like a really easy problem...
Just swap out coil packs to see if code go away - I've done this before.
gopsu is offline   Reply With Quote
Old 08-24-2009, 01:50 PM   #13
nicksamba_18
Member#: 120770
2002 Subaru WRX
.....was the coil pack, replaced and fixed.
Stock 2.5 RS sputters and wont accelerate STiluv55 Normally Aspirated Powertrain 3 06-04-2010 08:20 PM
Misfire after changing plugs? Check this fix! KW_Scoob Service & Maintenance 3 04-09-2008 04:28 PM
Just Changed plugs. Feels like new again vwown3d Normally Aspirated Powertrain 3 11-28-2007 06:14 PM
ran fine untill i let it sit, then it boggs down wrzexed UTEC 3 08-07-2006 05:30 PM
What would cause a car to run for 10 seconds then sputter and die?? Briman2021 Off-Topic 17 01-17-2006 12:00 AM
