Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 01-17-2012, 10:12 PM   #51
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Strider327 - you could try to bypass the recirc altogether and see if the stalling issue persists. With this seutp you will cap off all pressure (manifold) and vacuum nipples (turbo inlet). Let us know what happens.
Stephen
IA Performance is offline   Reply With Quote
Old 01-17-2012, 11:08 PM   #52
Strider327
Member#: 131280
2004 Impreza WRX
Will do, I'll see what happens.
Strider327 is offline   Reply With Quote
Old 01-24-2012, 04:16 PM   #53
08OBS
Member#: 274397
2005 WRX
6speed, vf43
I'm getting a P0171 code. It says its running to lean. When ever i fill up at the gas station the car doesn't want to start after. I have to hold the key for a few seconds and it will eventually turn over but it will idle really low and it sounds like the car is starving for fuel.
I got a new turbo inlet put on and that broke the original sensor. My buddy had an extra one and he put that one. I drove about 2k miles and now I'm having this problem. I think it's the sensor itself. I'm gonna swap sensors and see if thats the problem. Should I buy a new sensor or just do the delete?
08OBS is offline   Reply With Quote
Old 01-24-2012, 04:20 PM   #54
IA Performance
Member#: 25194
Dark Gray
08OBS - Assuming the 'sensor' is the thing with 2 nipples and an electrical plug (solenoid) is bad then you will need to replace it since it is not deleted in the suggested diagram from this thread.
Old 01-24-2012, 04:27 PM   #55
08OBS
Member#: 274397
2005 WRX
6speed, vf43
Yea i just realized that.
IA Performance - do you have any pictures of the delete?
Old 01-31-2012, 11:28 PM   #56
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Originally Posted by IA Performance View Post
So If im understanding this correctly, plug any lines going into intake manifold and inlet. You will be deleting everything from the line with the Blue T connector and replacing it with a straight line (green line in the diagram)?
scootarida1 is offline   Reply With Quote
Old 02-01-2012, 02:10 AM   #57
IA Performance
Member#: 25194
Dark Gray
scootarida1 - you are 100% correct
Old 02-01-2012, 02:17 AM   #58
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
subscribed. Need to look over
emsmap is offline   Reply With Quote
Old 02-16-2012, 12:10 AM   #59
MeFryRice
Member#: 143805
13 BRZ
Satin White Pearl
Stupid question of the day, where does the green hose connect to? I'm finishing up reversing my intake manifold and stupid me, I neglected to label that particular line. I've searched for the answer but wasn't successful.
MeFryRice is offline   Reply With Quote
Old 02-16-2012, 01:10 AM   #60
IA Performance
Member#: 25194
Dark Gray
The longest hose, roughly 6", connects the intake manifold nipple (directly above the alternator) to the PCV solenoid (furthest nipple from the plug). The other hose will simply connect back to the line returning to the firewall/gas tank.The more I look at the illustrations and the more I realize they are not correct from the factory. The 2 nipples on the solenoid should be flipped. The green hose in our diagram connects the nipple closest to the plug to the gas tank return line, but the photo shows it opposite.
Stephen
Old 02-16-2012, 10:40 AM   #61
MeFryRice
Member#: 143805
13 BRZ
Satin White Pearl
I appreciate your help Stephen.
- Steve
Old 03-05-2012, 09:36 PM   #62
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
^having the same issues..anyone chime in on this
cosseywrx is offline   Reply With Quote
Old 03-12-2012, 05:58 PM   #63
dalesti
Member#: 72636
2005 WRX STi
So I was pulling my old power steering pump and was replacing it with a brand new one and managed to snap one of the inlet on my PCSV. I took some pictures to see how it's setup from stock. Let me know if you guys have any questions from my pictures. I hope this can help someone out.
Right clicking on the image and viewing it directly should make it larger if the forum resizes.
dalesti is offline   Reply With Quote
Old 03-13-2012, 03:25 AM   #64
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
am i suppose to have 2 Pcsv's on my 08 sti? I found two nearly identical Pcsv. One is attached to the metal bracket holding the Pcsv and the boost control together, ad the other under near the evap line. I'm guessing my 08 sti is different due to california emissions even though it was bought brand new in texas because it does not have a purge valve or a nipple for it.
blue m&m is offline   Reply With Quote
Old 03-28-2012, 11:14 AM   #65
FXTRunner
Member#: 104289
05 Forester
CGM
happy to help. I'm now looking for the 04-06 and 2007 STi intake manifold diagrams so I may update this post with each model. If someone has these feel free to email over a screen shot to stephen@iaperformance.com
Stephen
Were you able to ascertain any diagrams on the 07 manifold? I'm doing a 07 STI swap into an 05 Forester and have discovered the difference between the two and would like to see how to go about bypassing the dual purge control solenoid system.
FXTRunner is online now   Reply With Quote
Old 03-28-2012, 11:41 AM   #66
IA Performance
Member#: 25194
Dark Gray
FXTrunner - no, I do not have the diagrams. You should be able to use the FXT plumbing instead of the 07 STi assuming you are not swapping out the entire assemblies:
- Drivetrain (motor/trans/hubs)
- wiring harness (bulkhead, front, rear, engine)
- ECU
Stephen
Old 03-28-2012, 11:57 AM   #67
ogintheback
Member#: 99163
2005 STI CGM
Hose clamps of course!
Subscribed for later review. Thanks IA Performance!
ogintheback is offline   Reply With Quote
Old 03-28-2012, 12:11 PM   #68
FXTRunner
Member#: 104289
05 Forester
CGM
Right, I only brought over the engine harness from the 05 engine... I'll see if i can bring the purge solenoid hook up but the one port on the 05 manifold is actually deleted on the 07.
Can I tee off one of the ports and use it for both purge valve and purge control solenoid valve?
Old 05-22-2012, 10:25 PM   #69
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
I recently threw a P0442 cel for EVAP LEAK DETECTED (SMALL) could this be something to do with this? Or should I be looking for something else.
Old 05-31-2012, 02:30 PM   #70
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
If it is a leak u can just run your own hose to bypass that evap section
Old 05-31-2012, 07:05 PM   #71
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Originally Posted by blue m&m View Post
It could but mainly because the house gets "t'ed" and route by it easy fix in the event of a leak is to bypass it with your own vacuum line
Im not really to sure I know what you mean. I ended up doing the delete as shown in the diagrams in this thread. If its because of this then I'm wondering if I should be okay to just turn off that code.
Old 06-04-2012, 07:18 PM   #72
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
well here is another bump. I reset the ecu and still threw a P0442 EVAP LEAK DETECTED (SMALL). Does anyone know if I can just turn this CEL off? The line that enters the intake manifold with this delete does not seem as tight as the other spots. Should I throw a hose clamp on it? Right now I am using a zip tie.
Old 07-10-2012, 04:31 PM   #73
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
so I can I just remove that entire assembly and run a line from where it would normally hookup under the intake manifold and run it directly to the intake manifold and then just shut off the cel?
Old 07-10-2012, 04:43 PM   #74
IA Performance
Member#: 25194
Dark Gray
You need to keep the solenoid in place, but the 'T' fittings and Round PCV can all go.
Stephen
Old 07-10-2012, 07:58 PM   #75
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Okay, just trying to check and where this Cel is coming form. I do not have any leaks from that area now but I am still getting the cel. Checked the gas cap and it looks fine.
To be sure I hooked it up correctly, the bottom port with the arrow gets the hose that comes from under the intake manifold and the top port is the hose that goes to the intake manifold correct?
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 09:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 06:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 08:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 05:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 05:36 AM
