Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 08-20-2009, 01:43 PM   #1
don_radeon
Member#: 202583
2004 Legacy GT
Black w/Domo on back
Default 225 on 7" wide wheel
Hi, I have a set of the BBS Optional RK's for the 02-03 wrx. They're 17x7 and came with 215's but I'm hoping I can fit wider tires on there. Something like the sti potenza's.. Anyone know if I can fit a 225 or 235 on the 7" wide wheel without a problem? Thanks!
don_radeon is offline   Reply With Quote
Old 08-20-2009, 01:51 PM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
A 225 is acceptable and the widest recommended tire for a 7" wide wheel.
Old 08-20-2009, 02:00 PM   #3
mosc
Member#: 177401
2004 STi White
16G powered lagless fun
...for a 45 sidewall tire
mosc is offline   Reply With Quote
Old 08-20-2009, 02:10 PM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
You can do 225/45. Sidewall will be a tad softer and buldge out more than a 215 (obviously).
EdHilario is offline   Reply With Quote
Old 08-20-2009, 02:50 PM   #5
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I have a set of 225-45-17 all seasons that I use for my "winter" tire. I personally can't stand the size, I went with a great compound for my performance tire and went with 215-45-17. I find that I out-grip a lot of the 235's people are running at local auto-x, simply because I have a better compound. If it is grip you want get a really good compound and you won't miss the 10 mm of width. If it is the width you want then the 225 will fit the 7".
Travis
UFOpilot is offline   Reply With Quote
Old 08-20-2009, 03:28 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
Wirelessly posted (Opera/9.60 (J2ME/MIDP; Opera Mini/4.2.14320/554; U; en) Presto/2.2.0)
the 09 wrx comes with 225/45/17s on 17x7 wheels and it looks just fine. no bulging sidewall at all.
Old 08-23-2009, 06:36 PM   #7
Terrible Juan
Member#: 208296
2012 Chrysler 300
2007 OBP WRX VF43'd
I'm guessing a 235 isn't recommended at all, then? (7" wheel)
Arr, I'm so torn between 225/45 and 235/45 with my 17x7's.
Terrible Juan is offline   Reply With Quote
Old 08-23-2009, 07:00 PM   #8
krzyss
Member#: 8365
2013 Ford Focus SE
Do not be torn. 235 requires 7.5" wheel.
Krzys
krzyss is offline   Reply With Quote
Old 08-23-2009, 07:09 PM   #9
grippy monkey
Member#: 131067
your "stance"
sucks
you wouldn't want a 235 on your 7... a 225 already gets a little sloppy with a 7" wheel
grippy monkey is offline   Reply With Quote
Old 08-24-2009, 10:00 AM   #10
mosc
Member#: 177401
2004 STi White
Krzys
Most people for 235 are going to run 235/40/17 which is not only wider but also drops the sidewall. These factors combine mean even a 17x7.5" rim is too narrow, you need 17x8".
Old 08-24-2009, 11:01 AM   #11
Struggly
Member#: 170461
1998 Subaru Legacy
Agreed.
OP, there's nothing stopping you from blasting a 235 on a 7" wheel. In that sense, it'll fit. But from a performance standpoint, it's not the best bet (on my track car, for instance, which is not a Subaru, I run only a 205 on a 15x7). The car will feel much more vague and uncommunicative.
Struggly is offline   Reply With Quote
Can you fit 225's on a 7" wide wheel? Jackie Tire & Wheel 17 07-23-2006 12:45 AM
225/45/17 toyo t1-s on a 7" wide wheel? pleue Tire & Wheel 2 08-15-2005 12:48 PM
225/45 Azenis on 8" wide wheel aakrusen Tire & Wheel 34 07-30-2005 10:30 PM
225 or 215 on 7" wide wheels M3sum Brakes, Steering & Suspension 5 08-08-2002 08:19 PM
max recommended tire width for 7" wide wheels 5 Door Man Brakes, Steering & Suspension 1 04-23-2002 10:36 AM
