Old 08-20-2009, 04:14 PM   #1
WRX USA
Member#: 11192
.. VF48'd Bugeye
Default DIY - Covering the Grab Handles (aka Oh Ish Handles)
So like many others I have decided to black out the pillars, map lights, visors, dome lights, and the grab handles (to be referred to as the OSH for the rest of this DIY). And like many others I have found that Plasti-Dip just doesn't work on this rubbery surface. Add to that, the people that tend to use them (the passengers) don't seem to take any care when they grab them which means that no matter how many layers you put on or how much prep you do it is going to come off. Well, I think I have found a solution and the nice thing is that the OSH don't stay "out" after being used as well.
The solution is shrink tube.
I purchased this at Fry's Electronics and they had black, green, red, yellow and white.
This is how my Plasti-Dipped OSH looked after being used.
First I sanded the Plast-Dip off and after some test fitting realized that the center of the OSH was a bit wide for the shrink tube that I have.
I figured that the shrink tube would add some thickness any way and I wanted a very snug fit so I sanded off enough for the tube to snugly slide on.
I cut the tube so that it was just long enough to cover the original grey surface of the OSH (no more than 1/4" extra on each side). Before you shrink it, you want to make sure that the seams on the tube are on the top and bottom of the OSH.
Finally you shrink the tube and reinstall the hardware and it is is ready to go back in the car. You can see the finished black one here with my "Proof of Concept" yellow one (I had the yellow left over from another project).
Here it is installed in my friend's car
And another one showing it installed in my car with my newly Alcantara covered headliner (Note that I used the 'deletes' on the driver, because I think it makes no sense for me to have an OSH).
WRX USA is offline   Reply With Quote
Old 08-20-2009, 04:16 PM   #2
corms333
Member#: 210149
03 wrx sedan
blue
pics in car?
corms333 is offline   Reply With Quote
Old 08-20-2009, 04:23 PM   #3
WRX USA
Member#: 11192
.. VF48'd Bugeye
I have my headliner stripped out right now in preparation to wrap it in Alcantara. As soon as I complete that I can post installed pics.
Old 08-20-2009, 04:45 PM   #4
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Best looking solution for this issue I have seen yet! How much excess tubing did you need on the left/right for it to shrink and fit properly? I will be adding this to my list of things to do when I get back.
aggie113 is offline   Reply With Quote
Old 08-20-2009, 04:56 PM   #5
calmdev
Member#: 191049
06' wrb wrx tr
derpa derp
Originally I used plasti-dip on the handles. Had the same results as you. I used mineral spirits which stripped it right off and just sprayed the handles with regular black paint. Looks fine and hasn't started to rub off..
Your solution looks good too.
calmdev is offline   Reply With Quote
Old 08-20-2009, 04:56 PM   #6
WRX USA
Member#: 11192
.. VF48'd Bugeye
Thanks for the compliment!
I added no more than 1/4" to each side so that the shrink tube totally covers the OSH.
Old 08-20-2009, 05:04 PM   #7
WRX USA
Member#: 11192
.. VF48'd Bugeye
I realize that the heat shrink tubing is rated for continuous operation from 55-135 degrees C and up to 300 degrees C (for short durations) which could be an issue for some people in colder areas so I threw the yellow one in my freezer to see how it holds up.
Old 08-20-2009, 05:12 PM   #8
SupaHottSauce
Member#: 111725
2003 Dylan Peterson
is a scammer
genius, where did you find heat-shrink that big?
SupaHottSauce is offline   Reply With Quote
Old 08-20-2009, 05:18 PM   #9
xfactor58
Member#: 148951
2006 Perry Tuned WRX
CGM
Wow. This is an awesome idea. +1
xfactor58 is offline   Reply With Quote
Old 08-20-2009, 05:43 PM   #10
WRX USA
Member#: 11192
.. VF48'd Bugeye
Fry's Electronics
Old 08-20-2009, 06:15 PM   #11
BoardRider
Member#: 32059
1997 Legacy GT sedan
CBR600, WR400, Z50R
Ha. Great idea! Thanks for sharing!
BoardRider is offline   Reply With Quote
Old 08-20-2009, 06:20 PM   #12
dtfdanyo
Member#: 195365
2005 WRX Wagon
nice idea, post installed pics
dtfdanyo is offline   Reply With Quote
Old 08-21-2009, 01:12 AM   #13
WRX USA
Member#: 11192
.. VF48'd Bugeye
7 hours in the freezer and the shrink tube is fine.
Old 08-21-2009, 01:20 AM   #14
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
looks great, does the tubing come in a wide range of colors?
m1r4g3 is offline   Reply With Quote
Old 08-21-2009, 01:23 AM   #15
WRX USA
Member#: 11192
.. VF48'd Bugeye
I have seen Black, Yellow, White, Red and Green. If you find "STi Blue" let me know
Old 08-21-2009, 03:43 AM   #16
vecdran
Member#: 162932
Hmmm, interesting idea. I think I may still try flocking mine though.
vecdran is offline   Reply With Quote
Old 08-21-2009, 04:55 AM   #17
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
That is really a great idea. Good job.
down_for_the_scooby is offline   Reply With Quote
Old 08-21-2009, 05:24 AM   #18
BuyMeAnEnergyDrink
Member#: 195504
2004 OEM+ WRX Wagon
SRR
Wow, great job. I plati-dipped mine and they turned out like s**t. I went with the deletes.
May HAVE TO try this now...
BuyMeAnEnergyDrink is offline   Reply With Quote
Old 08-21-2009, 08:36 AM   #19
aggie113
Member#: 146311
This would result in total failure. The DIY flocking kits will not hold up to such a high wear item like the handles.
Old 08-21-2009, 08:39 AM   #20
hookedontronics
Member#: 216078
2005 Legacy GT L
good idea man
hookedontronics is offline   Reply With Quote
Old 08-21-2009, 08:54 AM   #21
9vapors
Member#: 92582
This is one of those "why didn't I think of that?" moments...
9vapors is offline   Reply With Quote
Old 08-21-2009, 09:21 AM   #22
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
Great job! It looks real clean.
TEK112 is offline   Reply With Quote
Old 08-21-2009, 11:39 AM   #23
gaugeof12
Member#: 132859
2015 WRX
CWP
Brilliant! This is the best solution I have seen for making the OSH black. Good job.
gaugeof12 is offline   Reply With Quote
Old 08-21-2009, 01:22 PM   #24
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Yep, I have yet to see any solution for the OSH that is as durable as this. I just ended up ditching mine totally, but this may make me hope I kept them.
This mod gets the Sheepdog stamp of approval.
Oh, and do not flock them. The flocking does not like to dry on flexible vinyl without an adhesion promoter and primer, so you'll end up with your passengers having sticky black goop on their hands which they can then wipe all over the car.
sheepdog is offline   Reply With Quote
Old 08-21-2009, 08:25 PM   #25
WRX USA
Member#: 11192
.. VF48'd Bugeye
I added a picture showing it installed.
radon remediation - aka oh noes i have the radioactivity NJSwamplands Off-Topic 29 02-08-2014 01:13 AM
SOLD: Spec C Grab Handle Delete Plates SonicWRX Interior/Dressup/Audio & Security 5 01-17-2010 07:37 PM
Strange sound coming from the passenger side grab handle? Call_me_Tom Interior & Exterior Modification 4 05-05-2005 01:36 PM
Cover of Time....a little goat-ish? pjdwrx Off-Topic 10 09-15-2004 02:40 AM
