08-20-2009, 05:46 PM | #1 |
Member#: 109823
German Castrol Syntec 0W30
I have an 06 STI and was wondering if it's ok to run German Castrol even though it's 0w30, not 5w30 and it's summer time. Thanks in advance.
08-20-2009, 06:09 PM | #2 |
Member#: 40579
Vehicle:2002 WRX Stage 2+ Tuned by IA Performance |
There are lots of threads on GC that cover this. The concensus seems to be that it resists shear better than most 5Ws. I run it all year long, and many others do too. Do some searching and you'll find all the info you need (and then some).
08-20-2009, 08:28 PM | #3 |
Member#: 216135
Vehicle:2011 |
Where do you live? If it gets below zero in the winter, the 0w will be good for cold cranking. If you are in a moderate climate, the 0w likely means nothing, but the highlight of GC is below.
Anyway, the 100 degC viscosity (12.1 cSt) is actually in the low 40 wt range so it will likely shear into a mid 30 wt over a 4k oil change so it's a perfect candidate for our engine (as opposed to a mid 30 wt that shears into a 20 wt in 1000 miles....m1/RP 5w30 hint hint). |
08-20-2009, 10:46 PM | #4 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
I run it all year long without any problem. No significant loss of oil like some people experience with mobil1
08-21-2009, 02:21 AM | #5 | |
Member#: 132301
Vehicle:07 WRX Limited 6MT 20G - SWP - SOLD |
GC is also more stable than most 5w30's. IMO, its better than every mainstream 5w30 out there except Amsoil. |
08-21-2009, 02:59 AM | #6 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
08-21-2009, 03:21 AM | #7 | |
Member#: 46500
Vehicle:So many I can't remember anymore. |
In fact, i think autozone is running a special right now with 5qts and a K&N filter for $28 :P |
08-21-2009, 07:04 AM | #8 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
:banging head:
08-22-2009, 10:24 AM | #9 |
Member#: 3251
NWIC
Vehicle:2009 WRX Hatch DGM |
08-22-2009, 03:37 PM | #10 |
Member#: 57414
SWIC
Vehicle:2002 WRX sedan Silver. Now w/ 100% 18G! |
search "German Castrol UOA" -- and make sure when you go to buy it, it's really German Castrol (it will NOT say "Energy Conserving"). I was extremely pleased with my UOA using GC, and it ran well in temps between -20 to 90. I have a case of Redline 5w40 to finish, but I would consider running GC full time.
My UOAs: http://forums.nasioc.com/forums/show...an+castrol+uoa |
08-23-2009, 03:27 AM | #11 |
Member#: 116052
Vehicle:2011 STI ( Sold ) WRB |
one piece of advise when you have question about anything here, do not just listen random people here. use search fuction wisely and judge yourself.
08-23-2009, 01:18 PM | #12 | |
Member#: 16200
when wlll this ****ing insanity end??????????? |
08-23-2009, 03:33 PM | #13 |
Member#: 202140
RMIC
Vehicle:2007 Fozzie Grey |
I bought Castrol 5w30, just to piss Uncle Scotty off.
^_^ No, not really. |
08-23-2009, 06:03 PM | #14 |
Member#: 41070
Vehicle:2005 Black Tiger (Black Turbo Baja) |
I've run nothing but 5W30 in my turbo Baja for extended, heavy towing just to irritate Uncle Scotty, too! Beautiful UOAs.
However, in an effort to become less anti-social, I recently switched to 10W30. It's all Renewable Lubes' Bio-Syn oil, which he may or may not be more accepting of, and now that I'm on 10W30, I'm even using their HD product. I'm curious as to the UOA comparison, however we've sold the small boat we had, and are about to sell the trailer I used to tow. So, I don't know how good a comparison it will be. |
08-23-2009, 09:25 PM | #15 | |
Member#: 16200
you know what you are doing most do NOT THAT is a HUGE issue on this board stupidity at its finest |
08-23-2009, 11:55 PM | #16 |
Member#: 41070
Yeah, but I couldn't help razzin' you.
For the sake of anyone reading this thread, I run analysis regularly (the expensive but extremely useful kind from Dyson Analysis) and usually have a fairly decent idea what's going to happen before I put a fluid in. I did decide to run Red Line's 5W20 once in a non-Subaru vehicle that spec'd 5W30. Dyson felt certain that it'd run well on it. Really beat on that vehicle hard for that run. You could see that I had my foot on the floor towing quite a bit from the UOA, but you could also see lower wear than many people get just driving around. Fluid selection is very important if you're not just driving around (and often even if you are), and thinking that a brand name or a number on the side of a bottle is going to save you is just flat wrong. We've got an interesting custom-formulated 5W20 in service at work. Can't wait to see how it does. No Subarus, of course; primarily American pickups. |
08-24-2009, 09:31 PM | #17 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
GC's High Temp High Shear is at least 3.5 (to meet European ACEA A3 requirements). Red Line 5W-20's HTHS is 3.2. That's the same or better than most xW-30's in the U.S. Mobil1 5W-30's HTHS is 3.09. I would run Red Line 5W-20 over most xW-30's. -Dennis |
08-24-2009, 09:50 PM | #18 | |
Member#: 16200
and you are the ONLY one insane enough to TOW with a BAJA at 10psi boost for extended periods of time i am quite surprised that you have not melted something......something $$$ or $$$$ |
German Castrol = Castrol Syntec 0W30 European Formula? | Glenn Hough | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 06-27-2008 08:25 PM |
German Castrol Syntec 0W30 | Jon Bogert | Engine/Power/Exhaust | 4 | 08-19-2007 07:28 PM |
UOA - Castrol Syntec 0W30 (GC), 7k miles, FXT | bluesubie | Service & Maintenance | 0 | 03-06-2007 09:56 AM |
Used oil analysis FXT 6,144 miles German Castrol Syntec 0W30 | bluesubie | Service & Maintenance | 4 | 11-19-2005 08:21 AM |
Oil analysis on German Castrol Syntec 0W30, 5,930 miles, FXT | bluesubie | Service & Maintenance | 8 | 03-26-2005 10:06 AM |
