08-20-2009, 06:45 PM | #1 |
Member#: 137098
Vehicle:06 sti obp |
low oil today
i have an 06 sti, it has 52k miles on the clock. i've put maybe 3k miles on it since last august. i always check my oil but today it was very low. i looked underneath and found no leaks. i replaced the oil and it ran just fine. should i be worried? possible problem maybe?
08-20-2009, 07:05 PM | #2 | |
Member#: 56183
South East
08-20-2009, 07:14 PM | #3 | |
Member#: 7164
Vehicle:2000 Miata LS Evo Orange Mica (1/644) |
08-20-2009, 07:54 PM | #4 |
Member#: 137098
mobile 1 5w30. up until last august i daily drove it. and i had the oil changed maybe 1k miles ago
08-20-2009, 07:57 PM | #5 |
Member#: 87629
SCIC
ibopgetsrailedforM1
08-20-2009, 08:01 PM | #6 |
Member#: 137098
08-20-2009, 08:03 PM | #7 |
Member#: 141672
There are about one million post concerning mobil1 oil consumption. Strangely, people switch to a different oil and the problem seems to go away.
08-20-2009, 08:04 PM | #8 |
Member#: 137098
oh can someone send me a link? any suggestions on a better oil to use? thanks!
08-20-2009, 08:19 PM | #9 | |
Member#: 141672
08-20-2009, 08:30 PM | #10 |
Member#: 216135
Vehicle:2011 |
Get a good 5w40 (Ams 5w40 or RTS 5w40) or German Castrol 0w30 (which is actually a light 40wt).
08-20-2009, 09:17 PM | #11 |
Member#: 137098
thanks guys
08-20-2009, 09:46 PM | #12 |
Member#: 216135
Vehicle:2011 |
By the way, how much did you have to add to top it off (to full mark)? Usually up to a quart too low isn't a major deal...your oil temps might have averaged a bit on the high side. Running a quart too high usually is worse....foaming, jolting the crank, shearing, misfiring.
08-21-2009, 09:57 AM | #13 |
Member#: 210438
Vehicle:2012 Jeepfiniti G37X Rubicon |
08-21-2009, 05:34 PM | #14 | |
Member#: 137098
Drop in oil pressure / low oil pressure | magicstop | Newbies & FAQs | 3 | 07-24-2015 11:13 PM |
Can An Oil Pressure Gauge Indicate a Low-Oil Condition? | williaty | Service & Maintenance | 23 | 12-24-2006 02:34 AM |
low oil + mechanical oil pressure gauge | Starkiller | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-18-2005 11:55 AM |
Oil Coolers cause low oil pressure upon startup? | kaos200 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-21-2004 02:22 AM |
('93-'01) oil pick-up tube precaution (in case of oil pan dent or unexplained low oil pressure) | Rick G | Impreza Forum | 0 | 01-22-2003 08:58 PM |
