Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 08-21-2009, 09:27 AM   #1
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
Default Hydrolock Scare
Not sure if this is the right place to put this if not mods please move.
Story:
A couple weeks back we had a really bad downpour and I got stuck having to go through a really big puddle (puddle ending up being a mini pond ). Car died out but I was able to get it back started. Check engine light was on and cruise control was flashing. Got the car to dry land and left it over night. The next day I checked the car out and started it up. Started fine, but whiteish smoke was coming out the exhuast. I drove it to Perry Subaru and they checked it out. They found no water in the oil but when they removed the spark plugs they found water in the engine. They cleared it, test drove it and it drove fine.
Question:
Is there anything that I should be concerned about? Is is possible that something got bent that they couldnt see? Should I get a compression test done?
C/N: Drove car through puddle, got water in motor, got water out of motor, runs fine, ibparanoia.
IBCOOLSTORYBRO, IBYOURANIDIOT.
Thank
midnighted is online now   Reply With Quote
Old 08-21-2009, 09:55 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
take it for a good roadtrip to get everything burnt out, change your oil, and never think about it again. if you actually did hydrolock you wouldn't be on here asking if you did damage, you would KNOW there was a problem by the pieces laying on the garage floor.
Old 08-21-2009, 10:03 AM   #3
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
Gotcha. thats what I wanted to hear. I was just worried about any potential long term implications.
Old 08-21-2009, 10:35 AM   #4
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
does the transmission have vents on it? you might want to change the gear oil and rear diff oil just in case water got in there. also your cats in the exhaust could be wet but I don't know if that does anything bad because water is a byproduct of gasoline combustion anyway
WC LATHE WERKS is offline   Reply With Quote
Old 08-21-2009, 05:17 PM   #5
racer580
Member#: 202667
2006 WRX stage II
Ya, I would change out the oil, tranny oil, and use the whole tank of gas to be on the safe side. The people that took the water out most likely didn't get 100% of it out, and although the oil reservoirs are made to be waterproofed, you just never know sometimes. Idk how high the water level was that you drove through but I would also watch out for appearing rust spots. Especially if you made any mods that had steel in them.
racer580 is offline   Reply With Quote
Old 08-21-2009, 05:22 PM   #6
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
Is it possible for water to get in the transmission though?
Old 08-21-2009, 07:05 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Not sure about the transmission (most of the 5spds don't have a breather, iirc, so unless it got up over the dipstick tube, it's probably fine) - the rear differential, on the other hand, does have a breather - if the water got up over that, then there could be water in there. it'd have to be pretty deep, though...
DrD is online now   Reply With Quote
Old 08-21-2009, 09:36 PM   #8
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
damn that sucks. Do you think Ill be fine just changing the engine oil for now. I wont be able to take it to IAG until probably the friday after next.
Old 08-22-2009, 10:14 AM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Changing the gear oil in the rear differential is easier than changing the oil, imho - undo the fill plug (do that first - if you can't get that out, you really don't want to open the drain), open the drain plug, put in the drain plug, add 0.8qts or so of gear oil, put in the fill plug, and you are good to go.
It's hard to say how much water is in there, if any, without opening it up... that being said, I'm sure you'd be just fine waiting a week.
I25 kinda scares me.... Turn in Concepts Off-Topic 46 06-05-2010 08:51 AM
Scared bike is.... scared? ItalianGuy Off-Topic 6 06-30-2009 07:57 PM
I'm scared, excited but very very scared MattSEG Off-Topic 26 12-01-2004 03:06 PM
Hydrolock scare!!! Eric SS South West Impreza Club Forum -- SWIC 7 07-15-2002 06:16 PM
('93-'01) hydrolock? s Impreza Forum 8 04-17-2001 11:30 AM
