Old 08-21-2009, 11:31 PM   #1
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
Default so i flipped the TB, what about the throttle/cruise cable?
i flipped the tb for the tmic, how do i mount the throttle & cruise control braket to the opposite side?
legacydreamz is offline   Reply With Quote
Old 08-21-2009, 11:38 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
pics...?
Old 08-21-2009, 11:57 PM   #3
legacydreamz
Member#: 92423
2007 Honda CRV
i would but my camera doesnt have flash and my work light burnt out, so i'll have to wait til tmw for a decent pic.
Old 08-22-2009, 12:22 AM   #4
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
just hook up a longer hose
StupidFastWagon is offline   Reply With Quote
Old 08-22-2009, 12:33 AM   #5
legacydreamz
Member#: 92423
2007 Honda CRV
but there is like 1/4-1/2" on clearance between the arm and the intake mani.
Old 08-22-2009, 05:52 PM   #6
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
can you elbow it away or is there no height clearance?
freeride is offline   Reply With Quote
Old 08-22-2009, 10:15 PM   #7
legacydreamz
Member#: 92423
2007 Honda CRV
basically no clearance.
i took pics today but even with sunlight in the garage they were pretty much useless.
Old 08-22-2009, 11:26 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
dude... FLASHLIGHT, or even a lighter?
Old 09-06-2009, 11:07 PM   #9
legacydreamz
Member#: 92423
2007 Honda CRV
kinda figured it out...
after all my years of n/a turbocharging; honda, vw... i completely forgot that the pcv system should not be sourced to a positive pressure source aka the intake manifold. the pcv valve was obstructing my throttle and cc rotor after rotating the tbody.
going to block the pcv valve location on the intake mani and routing the pcv through a catchcan to the turbo intake tube.
bleh.
Old 09-21-2009, 08:08 PM   #10
legacydreamz
Member#: 92423
2007 Honda CRV
cruise control/throttle cable is my next hurdle.
figured i'd make a bracket from some flat stock, but i'm sure one of you has an easier solution...
Old 09-22-2009, 01:45 PM   #11
Skidd
Member#: 1853
GC6 Supercharged
STM
Why? The PCV valve is a check valve. If it sees pressure it will basically be forced closed, and thus act as a plug. It's only open under vacuum. Or are you referring to the valve cover hoses?
Skidd is offline   Reply With Quote
Old 09-23-2009, 12:21 PM   #12
legacydreamz
Member#: 92423
2007 Honda CRV
true, but wont work anyway because the throttle rotor hits.
so i see all these STI's making god like WHP what about the ej20's short_travel_wrx Proven Power Bragging 54 06-18-2005 06:48 PM
What is a PCV valve-does it need servicing? ANSER Newbies & FAQs 2 06-18-2004 11:25 AM
AMG V8 first miles are on the dyno, what about the STI? nicktckhoo STi Forum Archive 12 06-10-2003 07:56 PM
The Z, what about the MINI? bbbradley New England Impreza Club Forum -- NESIC 9 01-11-2002 12:41 AM
