Old 05-05-2002, 02:01 AM   #1
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
Default gas milage after turbo
after i got my car back with the turbo on it it seems my gas tank doesnt hold as much gas. the MY01 rs gas tank holds like 15 gallons or something and today the gas light was on and it was on empty but whne i filled up it only went 10 gallons before the pump shut off. anyone know what this could be?
boysetsfire is offline   Reply With Quote
Old 05-05-2002, 02:04 AM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
did you try turning it on again???
Brad
is sorry if he seemed too sarcastic
STiTuner is offline   Reply With Quote
Old 05-05-2002, 02:44 AM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default New Pump?
Did you put in a new pump? When you did that maybe you slightly tweaked the system used for measuring the amount of fuel.
Joshua
yebokmj is offline   Reply With Quote
Old 05-05-2002, 04:11 AM   #4
Hojai
Member#: 2190
i have the same problem....
every time i see the fuel light is on, i try to fill up the tank but eventually the pump will shut off before the tank is filled. Therefore every time i pump gas into the tank i do not stick the whole pump into the hole, i only stick it in a little bit just enough to push open the little metal plate and stop pumping when i realize the tank is filled.
Hojai is offline   Reply With Quote
Old 05-05-2002, 11:46 AM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
What pumps are you guys using?
kastle is offline   Reply With Quote
Old 05-05-2002, 02:32 PM   #6
Hojai
Member#: 2190
i am using the Walbro
Old 05-05-2002, 04:15 PM   #7
boysetsfire
Member#: 6218
2001 2.5rs-t
which ever one comes with the FAT kit
acetone in gas increases gas milage? F ur PONY Newbies & FAQs 9 08-07-2009 12:12 AM
After seeing this, i dont feel so bad for my gas milage xaznxeclipsex General Community 14 08-15-2008 02:20 AM
('93-'01) Holly gas milage batman!! JS Impreza Forum 28 06-14-2001 05:53 AM
('93-'01) Post your Gas milage Please Scooby South Impreza Forum 50 04-26-2001 12:53 AM
Gas Milage with a Turbo? yebokmj Normally Aspirated Powertrain 20 10-18-2000 12:20 AM
