Old 05-03-2002, 11:58 PM   #1
Hojai
Member#: 2190
Default which is the best adj. fuel press. regulator?
SX, Paxton or Sard?
isn't that Sard has 2 models? sport and race?
what's the difference?
it doesn't matter if i get the 10-AN or the 6-AN right?
Hojai is offline   Reply With Quote
Old 05-04-2002, 12:27 AM   #2
Hojai
Member#: 2190
ok....
i have known the difference between the Sard race fuel regulator and the sport one.
But, i still need to know which is the best?
Old 05-04-2002, 01:30 AM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
why is vortech not mentioned?
Brad
STiTuner is offline   Reply With Quote
Old 05-04-2002, 01:46 AM   #4
Hojai
Member#: 2190
b/c i am just looking for a regular adjustable fuel pressure regulator, i don't know if Vortech makes one.
isn't that Vortech only has rising rate fuel pressure regulator? both sfmu and fmu are the same right?
Old 05-04-2002, 01:58 AM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
the FMU and SFMU are different
the FMU has set plates
the SFMU comes with three different plates and screws to adjust idle vacum and boost
Brad
wonders who owns him now
Old 05-04-2002, 02:16 AM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Vortech SFMU over @ Scoobymods.com
kastle is offline   Reply With Quote
Old 05-04-2002, 02:24 AM   #7
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
you can now pick up my vortech sfmu here very low price compaired to the price from others
akcel is offline   Reply With Quote
Old 05-04-2002, 02:28 AM   #8
Hojai
Member#: 2190
"The SFMU is the same as RRFPR" that's what scoobymods.com said
so SFMU is not the one i am looking for, i don't know about FMU.
Is FMU the same as RRFPR?
Old 05-04-2002, 02:45 AM   #9
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Hojai, i have the SARD one from technik.. seems to work fine. Call Ross and ask. I think he has 1 with Subaru fittings in stock.
Orbiter is offline   Reply With Quote
Old 05-04-2002, 03:12 AM   #10
Hojai
Member#: 2190
orbiter:
he'd told me already but i am just trying to find something cheaper and at the same time comparable to Sard
by the way, how much do you think the pressure gauge cost if i buy it from Mopac?
Old 05-04-2002, 03:17 AM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
i dont understand..lol...the sfmu is FULLY ADJUSTABLE...it is what you want it to be...oh well
Old 05-04-2002, 04:14 AM   #12
Hojai
Member#: 2190
but i don't need a rising rate one.
Old 05-04-2002, 04:19 AM   #13
STiTuner
Member#: 5778
09 135i
Jet Black
the S-FMU is fully adjustable RRFPR
ok so if you don't have a RRFPR you will always have such high pressure and your car will not be able to learn the difference between on boost and off boost fast enough to control the injectors and your car will have suck!!!
Brad
Old 05-04-2002, 04:26 AM   #14
Hojai
Member#: 2190
but my tecII can handle that right?
Old 05-04-2002, 10:01 PM   #15
STiTuner
Member#: 5778
09 135i
Jet Black
ok using enigine management like that brinks you do a different topic..
pretty much and FPR will work probably even a factory one if you have a pump and injectors to match it.
Brad
Old 05-04-2002, 11:44 PM   #16
Hojai
Member#: 2190
i've got RC 550cc injectors and Walbro fuel pump.
i've heard a lot of ppl are using stock SVX fuel pressure regulator to bring down the pressure to about 32psi right?
i don't know if i can do this. If i can, it will save me a lot of money.
Old 05-05-2002, 01:11 AM   #17
STiTuner
Member#: 5778
09 135i
Jet Black
you have a Tec.. go talk to shiv... your life will become a whole lot easier.
Brad
Old 05-05-2002, 03:33 PM   #18
Hojai
Member#: 2190
thanks
Old 05-05-2002, 05:17 PM   #19
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Wow this thread seemed to get more difficult than it should have.
The Vortech SFMU is adjustable by swapping out the plates inside of the unit to allow different ratios of fuel pressure increases. It either comes with or you can order seperately the 1:1 plate which makes it just an adjustable FPR. If that is what you want you will have spent too much money on the Vortech IMHO as there are cheaper options. Cost around $300
Many including myself have/had high idle fuel pressures after swapping the pump for a hi-flow one. I swapped in a SVX fuel regulator for the stock one and it dropped me back down to around 33psi at idle. It is a simple bolt on procedure. Cost new around $100, used junkyard going rate...
If you have a full tec-II setup, you may want to consider Shiv's fuel rail kit which will convert the fuel rails to parallel, and replace the stock regulator with an included adjustable unit. Cost $400 - $500 (I forget how much he charges for these).
I can't recomend one option over another as I am not sure what you are looking to achieve.
Hope this helps.
Regards,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 05-05-2002, 07:06 PM   #20
Hojai
Member#: 2190
actually i am not is that only the idle fuel pressure i have to lower?
i had emailed shiv but still waiting for his reply.
i think i will not go for Vortech b/c it's more expensive than others.
if i only have to lower the idle fuel pressure, i can just get the stock fuel regulator from SVX. If not i will have to get an adjustable fuel pressure regulator like Sard, SX or Paxton.
Which is the best performance/quiet exhaust for the WRX? SubaruWrx-TKO Newbies & FAQs 2 08-12-2002 03:12 AM
Which is the best aftermarket fuel management for modded WRX please help ImprezaSTIVI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 47 07-24-2002 01:22 PM
Which is the best Fuel Computer? Silverscooby27 Normally Aspirated Powertrain 8 09-29-2001 12:35 PM
Besides of the stock RE-92, which is the best all season tires?? V6 Brakes, Steering & Suspension 28 11-09-2000 12:49 AM
Which is the best muffler without the noise? blasterjeff Normally Aspirated Powertrain 4 11-03-2000 03:44 PM
