Old 08-22-2009, 03:07 AM   #1
greco2030
Member#: 183614
2002 wrx
aspen white
Default oil pressure light turned on after going threw a puddle
so tonight going home from work it started raining really bad when i turned on to my street it was completely flooded i didnt think it was THAT deep but was wrong the water came up to my headlights and as soonas that happend my oil pressure light came on so i pulled into my drive way and shut the car off checked the air filter(short ram intake) a little wet on the outside of the filter but inside was fine checked the dip stick too see if i was low on oil or if some how water go inside i started the car back up and it started right away with no hesitation at all, light was still on. i disconnected the batterie to try to reset everthing but the light is still on...what else could be causing the light to be on? could water of gotten into the oil pressure gauge gotten wet? and is screwing with it?
greco2030 is offline   Reply With Quote
Old 08-22-2009, 01:18 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the sender got wet and shorted out
it should be ok when it dries out
Old 08-22-2009, 06:26 PM   #3
FunkRider
Member#: 195055
/\++ I had the same problem once. Sender got wet and shorted. You'll notice if you turn the engine off and then key back on the light will be brighter as it can make a 'real' connection with less voltage drop since it is actually seeing no oil pressure with the engine off.
FunkRider is offline   Reply With Quote
Old 08-22-2009, 08:16 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The oil light is an LED rather than a conventional bulb, and it takes only a very small current to make it visibly illuminate. Most likely some water from the puddle got on the sensor and wiring, and since that water is far from pure it's conductive enough to allow some current to flow and turn the light on. If this is the case it should go out once it dries, although it's possible that enough conductive residue could remain to keep it lit.
And disconnecting the battery will have no effect on what that light does.
Old 08-23-2009, 04:05 PM   #5
FunkRider
Member#: 195055
If it is an LED how is it possible that it was slightly dim and then brighter without the presence of actual oil pressure in my case?
Old 08-23-2009, 04:55 PM   #6
gopsu
Member#: 96448
02 WRX VF34
Exactly... same thing happened to my car after washing the engine bay.
gopsu is offline   Reply With Quote
Old 08-23-2009, 09:24 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
...For future reference, I would NEVER drive through water that is up to the headlights.
CKxx is offline   Reply With Quote
Old 08-27-2009, 02:27 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
wise.
Old 02-13-2011, 01:22 PM   #9
2fast4every1
Member#: 268258
2002 Impreza WRX
I just washed my car, and when I started it, the light came on. I was so scared and my parents would kill me this is my 2nd car five months of having my licence.
2fast4every1 is offline   Reply With Quote
Old 02-13-2011, 02:36 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
this wont end well...........
Old 02-13-2011, 03:27 PM   #11
XanRules
Member#: 157348
high impact
sexual violence
XanRules is offline   Reply With Quote
Old 02-14-2011, 12:17 AM   #12
mobomelter
Member#: 258480
2002 ECT0 1X
Originally Posted by XanRules
Surprisingly I was less scared of that statement than the whole trying to ford ****ing rivers in a Subaru.
mobomelter is offline   Reply With Quote
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Factory 2.5L Turbo Powertrain 2 03-05-2010 03:25 PM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Electrical & Lighting 1 02-14-2010 12:58 AM
Washed engine, had oil pressure light kind'a on... mostasz Newbies & FAQs 12 04-03-2009 02:24 PM
Things I should check after going through a puddle jonney_boy Vancouver Impreza Club Forum -- VIC 11 12-29-2008 11:07 PM
Oil pressure light comes on for a split second WS6toWRX Service & Maintenance 12 02-06-2004 02:47 PM
Message Board Statistics All times are GMT -4. The time now is 08:26 PM.
