Old 08-22-2009, 07:22 PM   #1
sube-trex
Member#: 97577
2001 IS 300
Question R/R Spark plugs, now horn goes off & no POWER
R/R plugs
Connected all removed electrical connectors
-plug coil packs
-Air box (stock)
-w/w
Proceeded to connect the positive terminal on the battery, (negative connected). As contact was made horn went off right away. Did not hear any audio-able sounds of the fuel pump cycling.
Below is some of my elementary trouble shooting.
1)D/c'd all battery terminals
2)Uninstalled the #5 Fuse (horn & hazard) in the Engine bay
3)Installed battery terminals
4)Turned ignition to ACC
No horn , but still no audio-able sound of the fuel pump cycling.
I have done the plugs before and have not run in to this predicament.
sube-trex is offline   Reply With Quote
Old 08-23-2009, 10:07 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Factory alarm? I will assume you tripped it and now it needs to be reset.
There should be an owners manual suppliment that covers the factory alarm.
Changed spark plugs..now car won't run KyoSaNim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-18-2010 01:31 PM
R/R Spark plugs, now car doesn't start sube-trex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-27-2009 02:21 PM
New Spark Plugs... now rough idle??? bmw50021 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 12-02-2006 01:04 PM
Changed spark plugs - now hesitation at 1500 rpms on cold start ImportVenom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-04-2004 03:32 PM
help-changes spark plugs, now car missfires ej25power Normally Aspirated Powertrain 2 08-22-2002 07:17 PM
