Old 08-22-2009, 11:08 PM   #1
maddhatteroo7
Member#: 78840
Default how to verify wheels will work?
Well I went to a junk yard and found a set of Speedline wheels that look like these:
They're 16x7 but not sure how to verify it will fit on my car as far as it being 5x100 or what without physically putting them on my car to check. Is there a way to verify without physically putting them on?
maddhatteroo7 is offline   Reply With Quote
Old 08-22-2009, 11:38 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
check the back of the wheel hub, the specs fo the wheel should be stamped around there.
rougeben83 is offline   Reply With Quote
Old 08-22-2009, 11:46 PM   #3
maddhatteroo7
Member#: 78840
I'll try to take a closer look when/if I go back. I did see it was stamped 16x7 but couldn't see/maybe didn't look hard enough to see if there was a hub pattern like 5x100 stamped on it. For $100 they're a damn good deal, just have to buy tires to fit over it. Just kinda concerned if they'll fit over my 4pots I'm going to put on the car later is all.
Old 08-22-2009, 11:48 PM   #4
ed10
Member#: 198026
2002 Impreza WRX
Nulla Tenaci Invia EstVia
16"? I'm not sure they'll clear the 4 pots...
ed10 is offline   Reply With Quote
Old 08-22-2009, 11:51 PM   #5
maddhatteroo7
Member#: 78840
Well I've seen them or similar models of speedlines on plenty of jdm GCs, don't remember if they were on models with 4pots or not. I know for a fact of course the 98-01 RS wheels if they're the gold/silver 5spokes will clear 4pots and there's a set at the same yard, but they're silver. I don't want white on silver. White on gold is the only way to go
Old 08-23-2009, 01:30 AM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
Wirelessly posted (Opera/9.60 (J2ME/MIDP; Opera Mini/4.2.14320/810; U; en) Presto/2.2.0)
they're only $100. buy em regardless!
Old 08-23-2009, 03:21 AM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
16x7? all youre really going to have to check is the spoke clearance on the face of the calipers, rough way to measure it would be to just measure how much the caliper sticks out from the rotor's braking area surface, then take into account the height of the rotor hat and then add that height to the distance between the wheel/hub mating surface and the backside of the wheel spokes...if that measurement is greater than the height of the caliper, the wheels will clear the caliper face.
Old 08-23-2009, 11:44 AM   #8
Speed Stick
Member#: 202852
1993 JDM GC8 Sedan
Graphite Gray Pearl 1C6
$100 is an amazing deal. I'd just buy them and use them till you decide to upgrade to 4 pot for whatever reason. If they don't Fit you could easily sell them.
Speed Stick is offline   Reply With Quote
how to verify OEM sti wheels fit 06-07 MatchesMalone Tire & Wheel 12 06-23-2009 03:27 PM
How to verify Spiider DCCD auto controller works triguy Transmission (AT/MT) & Driveline 2 06-02-2008 01:59 PM
How to verify knock ? PAPsti Engine Management & Tuning 1 08-09-2004 01:59 AM
Part number from STI type RA tranny... got the #, but can't find how to verify it JSiwek Transmission (AT/MT) & Driveline 55 07-31-2003 09:11 PM
How to verify STi suspension?? pooper Newbies & FAQs 2 03-25-2003 02:06 AM
