Old 08-23-2009, 08:42 PM   #1
notsosimple
Member#: 179937
Default A/C Compressor: Grabs and Squeels on initial start up
Have had some AC issues (would hold charge) and found the leaky hose. Replaced, recharged, now I am having compressor issues. On the initial start up (First thing in the morning, when I get back to my WRX after work, etc) when I turn on the AC the compressor squeals for a good 2-3 seconds.
Checked tension on the belt, it is good. Belt is new within the last 7k miles, as is the tensioner pulley. Only thing that has changed was a recharge. Thinking maybe over charge of the system? Once the compressor is on and is done squealing, it will cycle without any sound at all.
notsosimple is offline   Reply With Quote
Old 08-25-2009, 02:14 PM   #2
notsosimple
Member#: 179937
Anyone? So how do you properly service the clutch? Anyone have a part # or required parts to change it?
Old 08-25-2009, 09:59 PM   #3
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
I had the same prob, I just took the belt off(compressor) and told the kids its going to be a hot summer. I think its the A/C compressor clutch, I would like to know as well if its repairable or do you replace the whole compressor.
KootenayWRX is offline   Reply With Quote
Old 08-26-2009, 12:18 PM   #4
notsosimple
Member#: 179937
Hoping to not replace the entire compressor as I would then have to pay to get the system vacuumed. Anyone?
Old 08-26-2009, 11:24 PM   #5
sonic03rex
Member#: 40534
2016 WRX
bump, I have the same issues except mine decided to stop screaming for mercy, flooded the cabin with a burning smell, then completely stopped engaging all together.
sonic03rex is offline   Reply With Quote
Old 08-26-2009, 11:58 PM   #6
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
Bumpadge, Part number and replacement info needed. THX
Old 08-27-2009, 08:02 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I don't believe you can just replace the clutch (at least easily/cost effectively).
With the belt off, does the outer part of the clutch spin freely? It may have rust build up that can "sometimes" be removed by spraying a lot of WD-40 in the front gap between the 2 clutch parts while spinning the outer part. Cover things first as this is rather messy.
When done spraying, keep spinning to remove as much WD-40 as possible (compressed air can help here), then reattach the belt and start the car.
Old 08-28-2009, 02:07 PM   #8
notsosimple
Member#: 179937
Will rip it apart Monday, have the day off. I know that you can remove the outer clutch and service.
Old 08-28-2009, 11:00 PM   #9
Farnsrocket
Member#: 83567
08 Outback
Obsidian Black Pearl
Farnsrocket is offline   Reply With Quote
Old 08-29-2009, 02:11 PM   #10
CoryH
Member#: 221604
WR Blue
If you have some AC gauges put them on the high and low side start your car. If the low side goes to 0 quick turn off the car if it doesn't go back to 40 or 50 psi on the low side pretty quick its the expansion valve.
CoryH is offline   Reply With Quote
Old 08-29-2009, 10:55 PM   #11
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
Old 09-02-2009, 02:48 PM   #12
notsosimple
Member#: 179937
I do not have a set of manifold gauges; I think it would be a good idea to get some.
Anyway..Ripped a part the forward facing clutch disc. If you take the appropriate allen wrench, and a square shanked screwdriver, you can hold the clutch disc and take off the allen bolt. Be careful not to lose the shims. Looks like my compressor is leaking, but to be sure I cleaned it off really good and will re-inspect after a weeks usage.
It looks like you can take it apart further by using a pair of snap ring pliers and removing it from the compressor shaft. Did not go that far because I fixed it.
Just used a wire brush on both surfaces, then some WD40 to clean the crap off, wiped it down and started; thing is quiet as all get out now.
Old 09-03-2009, 02:10 AM   #13
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
Good one, does not sound too expensive, I llcheck it out even thou summers almost over.
Old 09-06-2009, 05:32 PM   #14
strohausii
Member#: 26770
'02 WRX
midnight black
Did you evacuate the system and hold for ~20 minutes?
Any residual moisture is hell to pay (litterally) in a/c systems.
strohausii is offline   Reply With Quote
Old 09-08-2009, 01:15 PM   #15
notsosimple
Member#: 179937
Why? I did not open the system. I just took the outer clutch disc off and clean. The system was not compromised at all.
engine light on and bad idle at start up wrx2sti1114 Texas Impreza Club Forum -- TXIC 33 10-01-2008 10:08 PM
Axis Stage 2+ Initial Start up and Idle Videos TurboQueef Built Motor Discussion 20 01-12-2008 09:16 PM
DCCD flashing and ABS light on during start up. Digitalfiend Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-18-2005 07:52 PM
clutch noises on initial start up scoobystas Service & Maintenance 1 01-23-2003 07:01 PM
