Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 08-23-2009, 10:26 PM   #1
Do_It_Sidewayz
Member#: 24372
Default Cylinder head dowel pins
It looks as though it is possible to use 4 cylinder head dowel pins on each head, instead of the stock 2 pins.
Has anyone tried this?? is it worth the effort?
Seems like both the block and head are machined to fit the things, but only uses 2 from the factory.
Do_It_Sidewayz is offline   Reply With Quote
Old 08-23-2009, 11:52 PM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
What would be the need to do so ? Why not just use head studs if guides is what your looking for ?
sense of nature is offline   Reply With Quote
Old 08-24-2009, 12:13 AM   #3
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
For one I don't think it would be worth it because the two dowel pins alone don't allow for any movement when the head is placed onto them, sooo adding a third or a fourth doesn't really do anything because there was no extra movement to begin with. Also there is no reason to fix what isn't broken. Nobody has alignment issues.
In response to sense of nature, head studs (arp's) don't fit snugly into the head holes, so if there is no dowel pins in the block and you place the head onto a block with arp studs, there is actually freeplay in which you can move the head around. So using them as guides would not work.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 08-24-2009, 12:32 AM   #4
sense of nature
Member#: 112759
SexyRP
Makes "sense"
I see what he was referring to as far as the need for the extra dowels goes.
Old 08-24-2009, 12:45 AM   #5
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
we could always tig weld them together. That should keep'em together!
I vote boycott ARP!
DK
Old 08-24-2009, 12:54 PM   #6
Do_It_Sidewayz
Member#: 24372
My impression is that the Dowels are really going to hold the things in place, while the studs are going to be holding them down.
I've got like 4 dead blocks around, and it's pretty easy to just put in the dowels. I can't say that it would hurt.
Old 08-27-2009, 11:49 PM   #7
Texy32
Member#: 124252
0506 STI/Tribeca
OBP/SGM
Default dowels
I have but all 8 dowels on the last three builds I have done. It just make sense to me to use the extra dowels.
Texy32 is offline   Reply With Quote
Cam dowel pin removal LiquidForce Built Motor Discussion 5 01-20-2015 08:30 PM
FIDANZA Flywheel: Two dowel pin holes instead of three? WTF Trunk_Monkey Transmission (AT/MT) & Driveline 11 12-22-2010 05:05 PM
how important are dowel pins ? Serkan Transmission (AT/MT) & Driveline 6 11-24-2009 01:34 AM
Missing a dowel pin... dmross Transmission (AT/MT) & Driveline 2 02-16-2009 04:32 PM
Dowel Pins? STI 6speed swap. AWNOPEEL Transmission (AT/MT) & Driveline 3 05-18-2008 03:18 PM
