Old 08-24-2009, 09:31 AM   #1
Matt A
NASIOC Vendor Manager
Administrator
Member#: 15382
. 2005 OBXT LTD
OMGHi2U Dave - General of the :unamused: army - I made something for you...
an unamused 'contact card'!
(obviously it has all the info, but I edited out the private bits to show to OT)
In my abundant time away from employment, I decided to wanted to learn how to letterpress print, so I found a shop nearby and asked if I could intern. I've been there a few days a week for about two and half months and having an awesome time. We make some really fun stuff. I wanted to do a fun project of my own and I figured this would be a nice way to say 'thank you' to Dave for supplying all of us with the greatest smilie ever conceived. (can you tell I'm slightly obsessed?)
How is this thing of beauty made you ask? Well, I just happened to document the process in order to show everyone.
It all starts with a design - you send an eps file to a company that makes polymer plates for use on the press. Traditionally, letterpress is done with movable lead type, but the polymer plate technology gives you a way to press just about anything you want.
You get the plates back (one for each color that is run) and start planning how you need to cut the paper to run on the press, as well as figuring out what type of paper you want to run.
I decided to run the yellow first because the black will look better run over the yellow instead of the other way around. You can see that the rollers are all inked up with yellow ink.
Make a few test runs to get the desired impression and to line up everything just right. The adjusting takes a while and it needs to be just right, especially if you're running multiple colors.
Matt A is offline   Reply With Quote
Old 08-24-2009, 09:31 AM   #2
Matt A
Administrator
Member#: 15382
. 2005 OBXT LTD
View of the Vandercook Press. You can see where the paper is fed into the press along the guides.
A stack of one run of many, many to come...
Now that the first run with the yellow is done, its time to clean the ink off the press and line up the next plate to run.
Run it a few times without ink to get the alignment correct and to do the major adjustments...
Ink the press up and run a few to get the minute adjustments and alignment just right...looking good!
The face uses a decent amount of ink and the paper is thirsty, so to keep the color consistent, I needed to add ink a few times during the run...
Grabbing the paper after I roll it over the plate
Check each one after it comes off the press. This one looks good! I also look damn fine in an apron if I do say so myself.
More ink...
Little guy all inked up
Old 08-24-2009, 09:32 AM   #3
Matt A
Administrator
Member#: 15382
. 2005 OBXT LTD
w00t! it's coming together...finally
The roller grabs the paper to travel over the plate. In this photo I've already run this sheet over the press once to get the black on there. Now the paper has been turned around and is run a second time. Gotta maximize paper usage!
Sharp!
Cleaning the ink off the press takes about 20 minutes every time. And it needs to be done between each color. All the ink must be cleaned off of all the rollers, etc. Not the most fun.
Dave's info plate that will be run on the backside of the cards...
Aligning again! (four times for this project!)
Mixing the ink for the title for the last run...
Lined up the title, time to run it!
Press is inked up and running...
Old 08-24-2009, 09:32 AM   #4
Matt A
Administrator
Member#: 15382
. 2005 OBXT LTD
Pink title looks sharp.
and of course, once they are all printed, they all need to get cut. Each sheet takes 3 cuts.
First one, complete!
Phew!
So that's letterpress printing in a nutshell. Well... this particular project anyway. I printed a bunch just one sided as well.
It’s a ton of fun and I hope to do a few more projects. Who knows, perhaps I’ll make this an occupation.
Old 08-24-2009, 09:34 AM   #5
karnick
Member#: 103863
just kidding. nice work.
karnick is offline   Reply With Quote
Old 08-24-2009, 09:37 AM   #6
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
Your mancrush is showing...
Who am I kidding, those are really ****ing cool!
WhiteKnightSTi is offline   Reply With Quote
Old 08-24-2009, 09:39 AM   #7
SQ3.0dotJP
Member#: 136330
# OCCUPY
that's pretty cool/waaaaaaaaaaaaaaay too much time on your hands. but cool nonetheless
SQ3.0dotJP is offline   Reply With Quote
Old 08-24-2009, 09:39 AM   #8
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Wet45
chapstien is offline   Reply With Quote
Old 08-24-2009, 09:40 AM   #9
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
Prod is offline   Reply With Quote
Old 08-24-2009, 09:41 AM   #10
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Nice. Can you make me some new cards?
Layman is offline   Reply With Quote
Old 08-24-2009, 09:42 AM   #11
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
wow nice work where can we get some of those?
lionken07 is offline   Reply With Quote
Old 08-24-2009, 09:44 AM   #12
cnw
Member#: 98395
PM r0bman for
parts discounts.
that's pretty awesome, but who outside of ot is going to know wtf the card is all about?
cnw is offline   Reply With Quote
Old 08-24-2009, 09:44 AM   #13
subysleeper
Member#: 59144
... My car is
Front-Mid Engine
I want this!
subysleeper is offline   Reply With Quote
Old 08-24-2009, 09:46 AM   #14
Cole
Member#: 64219
2011 Outbackness
2008 Legacy NA Hellastock
Cole is offline   Reply With Quote
Old 08-24-2009, 09:46 AM   #15
Matt A
Administrator
Member#: 15382
. 2005 OBXT LTD
time to spread the love!
Most of the cards shown are just one sided unamused cards, there are about 50 or so double sided contact cards that I'll send to Dave.
Old 08-24-2009, 09:48 AM   #16
BacDoc
OT Gender Unicorn
Member#: 75141
Bout time to trademark that bitch.
BacDoc is offline   Reply With Quote
Old 08-24-2009, 09:49 AM   #17
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Nice work!
Letter presses are very time consuming but the end product if very clean and has a more had crafted feel to it.
I Interned at a place that had a couple of those floating around. They did prints of paintings. Every job had to be color perfect and took forever to get the prints done, but it was good fun.
RALLYT-WRX is offline   Reply With Quote
Old 08-24-2009, 09:49 AM   #18
WhiteKnightSTi
Member#: 169250
(wirlybird)
People outside of OT are subhuman peons who's only role in life is to carry around my crates of gold and throw themselves into puddles so my supermodel girlfriend doesn't get her shoes wet.
Old 08-24-2009, 09:49 AM   #19
Kaiser
Woodpecker
Member#: 7170
Aut Kaiser,
aut nullus.
Thumbs up
That's some quality work right there, Matt. And you sound more enthused in this single thread than you ever did about agency/office work. I think that's telling you something.
I love seeing the old-style printing process broken down. There's something very appealing about a non-digital medium like this.
Kaiser is online now   Reply With Quote
Old 08-24-2009, 09:49 AM   #20
Grap
Dicky Nipperist
Member#: 6590
Shut up! we don't want them to know....
Grap is offline   Reply With Quote
Old 08-24-2009, 09:50 AM   #21
KC
Member#: 442
16 SS
00 S2000
:golfclap:
KC is offline   Reply With Quote
Old 08-24-2009, 09:59 AM   #22
cnw
Member#: 98395
PM r0bman for
parts discounts.
nod. see: general.
i detect 9 points!
Old 08-24-2009, 10:03 AM   #23
SQ3.0dotJP
Member#: 136330
# OCCUPY
i have a ton of people rocking the in japan, it's international baby.. infact i'm down to 1 sticker
Old 08-24-2009, 10:04 AM   #24
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
(because your dang website takes too long to load the pics)
-=C=- is offline   Reply With Quote
Old 08-24-2009, 10:05 AM   #25
Matt A
Administrator
Member#: 15382
. 2005 OBXT LTD
Originally Posted by -=C=- View Post
6/10
stupid 1and1
My observations of the US Army SPCJJ Off-Topic 60 09-04-2007 03:05 PM
So I'm listening to the best of the Red Army Choir BhamRoadrunner Off-Topic 5 02-19-2007 09:43 AM
Those with an MY04 STi and like the color red, we've got something for you! iON Performance Inc Suspension/Brakes/Handling 7 09-08-2004 09:31 AM
Who has pics of the Subaru army at Starbucks? Bankheist Texas Impreza Club Forum -- TXIC 0 03-25-2002 01:54 PM
I wonder how many of the optional BBS 17" wheels for the WRX they made.... driver Brakes, Steering & Suspension 3 03-26-2001 07:20 AM
