Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 05-05-2002, 04:40 PM   #1
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Default What is "Air assist injector solenoid valve"?
On the vacuum lines diagram under the hood, I can see a "Air assist injector solenoid valve", what is it's function? Do I still need it if I have non-stock injectors (RC 550)?
It looks like the IAC solenoid is part of this system too.
Thanks!
Boostup! is offline   Reply With Quote
Old 05-05-2002, 05:50 PM   #2
kaos200
Member#: 2692
Default Re: What is "Air assist injector solenoid valve"?
Thanks!
On the 2000, 2001 cars it exists as a emmisions "aid" it is supposed to make the fuel "vaporize" (whatever u want to call it) better and quicker. Its a pain in the ass. and no it is not needed. (The car will run fine without it, but will throw a cel)
kaos200 is offline   Reply With Quote
Old 05-05-2002, 06:11 PM   #3
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Thanks for the info, Kaos200.
So did you just plug up the three holes, one at the throttle body IAC solenoid, and two others at the injector boss?
Old 05-05-2002, 07:02 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Default Re: Re: What is "Air assist injector solenoid valve"?
well said kian. You prolly should leave it in there cause it'll make the car breathe better(and lean out a bit) at idle...this is if you have the stock ECU running the car.
jeremy
Wtb:air Assist Injector Solenoid Valve markers Private 'Wanted' Classifieds 1 10-08-2007 04:12 PM
WTB: Air assist injector solenoid valve GC_Anthony Tri-State Area Private Classifieds 1 04-02-2007 12:44 PM
Air Assist Injector Solenoid Valve RichImpreza02 Normally Aspirated Powertrain 3 11-13-2006 11:36 AM
I have an Air Assist Injector Solenoid Valve Malfunction!! Osgood30 Normally Aspirated Powertrain 2 02-27-2003 03:34 PM
