Old 08-25-2009, 05:41 PM   #1
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Default Lug nut washers
anyone know where i can get some lug nut washers that fit the stocker wrx wheels and lugs?
happs subi is offline   Reply With Quote
Old 08-25-2009, 05:49 PM   #2
Crawdads
Member#: 30907
SWP GDB-G
Stock wheels and lugnuts are tapered, they don't use a washer.
Crawdads is offline   Reply With Quote
Old 08-25-2009, 06:05 PM   #3
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
my wheels need some kind of washers, i dont know if i have some kind of after market lug nuts or what, but there's not much rim in between the nut and the rotor right now
Old 08-25-2009, 06:45 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Huh?
What wheels do you have? Pics?
Old 08-25-2009, 07:00 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm with mav1c. Huh?
Old 08-26-2009, 03:01 AM   #6
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
I can't upload pics with my phone, would take me like 2 weeks, but you know where the threads go through the rim? Those 5 holes? And then there's supposed to be some kind of washer and then the lug nut comes on? Well the other day when I rotated my tires I noticed that there was a lot of wear as if my tires were put on very aggressively with an impact gun, and then I noticed the diameter of my lug nuts was not quite sufficient enough for my tires, and that there was a lot of room left as if something belonged there... Long story short, I need to find out what washers I can use, or if the stock lugnuts actually come with nonremovable washers, where I can get those or what.. It is not very safe, I might as well be driving around with one loose nut on each wheel
Old 08-26-2009, 03:05 AM   #7
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
And they are stock MY02 wheels
Old 08-26-2009, 03:37 AM   #8
Rwolf
Member#: 210768
2009 Impreza Hatch
Sound Like you may have rims that require "shank style" lug nuts.
I was surprised that my friends 05 Corolla used them. Since the lugnuts are not as common and typically used for old rwd Mag rims.
You should know if it uses shank/mag nuts if the face of the hole is flat, Otherwise it should take conical if looking at the side form a "\ /"
A close up pic would help.
The washers are removable. I guess your options are buying a new set of lug nuts that come with the washers, or maybe ask a tire shop to see if they sell them specifically/separate (or if hardware store would suffice).
Rwolf is offline   Reply With Quote
Old 08-26-2009, 04:10 AM   #9
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
OP has stock wheels. Stock suby wheels don't need any kind of washer between the lug nut and the wheel.
dantastic is offline   Reply With Quote
Old 08-26-2009, 08:17 AM   #10
mav1c
Hoodbridge!
Member#: 560
The tires are those rubber things mounted on the wheels.
You do NOT need any sort of washer for the stock wheels. They use conical lugs that seat in the wheels.
Do you have some sort of aftermarket lug? What do they look like?
You need to learn how to post pics.
Old 08-26-2009, 12:36 PM   #11
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Thank you, I think I'm going with buying new lugs that come with washers. Do you know how I can find the correct dimensions?
Old 08-26-2009, 12:42 PM   #12
rougeben83
Member#: 115154
2005 Outback XT
White on grey
This is what the holes of a stock subaru wheel looks like:
There is NO washer needed. Please stop trying to look for something that isn't there to begin with.
rougeben83 is offline   Reply With Quote
Old 08-26-2009, 12:43 PM   #13
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
The person which had the car before me decided to use lugs like Rwolf was talking about, they do not sit properly in the wheel.
My phone is incapable of uploading media, and I do not have a camera. Regardless, I have found a solution, I just need help figuring out the correct dimensions for new lugs, any takers?
Old 08-26-2009, 12:47 PM   #14
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Some people are a little uppidddy in the tires and wheel section... Those aren't even impreza wheels
Old 08-26-2009, 12:52 PM   #15
Badler
Member#: 133597
Badler is offline   Reply With Quote
Old 08-26-2009, 12:55 PM   #16
rougeben83
Member#: 115154
2005 Outback XT
White on grey
hahaha oh wow...
Old 08-26-2009, 12:59 PM   #17
mav1c
Hoodbridge!
Member#: 560
Ugh. Yes they are. Maybe not the same ones you have, but they are. ALL stock Impreza wheels, no matter what type or year, will have the same style/shape lugnut holes. Just get some stock lugnuts. As a matter of fact, I have some I can sell you.
Old 08-26-2009, 01:53 PM   #18
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Ugh. Yes they are. Maybe no the same ones you have, but they are. ALL stock Impreza wheels, no matter what type or year, will have the same style/shape lugnut holes. Just get some stock lugnuts. As a matter of fact, I have some I can sell you.
Thank you, but I just found some at a tire shop... Can you do me a really big favor and close this thread?
Old 08-27-2009, 09:32 PM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Could you provide us pictures of the lugnuts you're buying? I'm curious to see how you're resolving this perceived "problem."
Old 08-27-2009, 09:41 PM   #20
C-LOS_WRX
Member#: 93140
02 wrx
me too...i might need them...since i'm also running stock wheels and have an 02 rex.
please post pix.
C-LOS_WRX is offline   Reply With Quote
are subaru lug nuts like tuner lug nuts? ezzzey Tire & Wheel 19 11-08-2009 10:03 AM
Volk Lugs Aluminum Extended Lug Nuts, Volk Locking Lug Nuts, Genuine Suby Wheel Locks timeless Wheels/Tires 10 08-21-2008 02:06 AM
FS IL: Rays black lug nuts, SSR chrome lug nuts fweasel Wheels/Tires 3 02-07-2008 07:07 PM
Gorilla lug nuts and OEM locking lug nuts my04sti Private 'For Sale' Classifieds 1 06-17-2006 05:52 PM
Lug nuts, locking lug nuts Bimmer Brakes, Steering & Suspension 2 11-02-2001 10:21 PM
