Old 08-25-2009, 06:54 PM   #1
Ammadien
Member#: 100370
2005 Stage 2 sti
Default Tire leaking, concave on inside of rim.
Hey guys,
Well shoot. I went to the track friday, and checked tire pressure prior to leaving.
the front driver's side was low, about 15 psi down. I didn't think much of it and off I went.
Drove it around no problem that weekend but Monday afternoon i notice that same low tire was nearly flat. I check it and its got like 5 psi in it.
I take it off to try to find the leak, and here is what I find:
(i know the pics are horrible but I'll try to explain to help)
The chalk arrow is pointing to the actual leak. But there are other similar marks every 3-4 inches:
Also the side where the mark is is pretty concave, so I dunno if this would come from just running low pressure and the leak is where it cracked?
I figure I'll take it to a tire shop to see if they can plug it or patch it till we get some more tires for summer, but this is an unexpected expense. Would this be possible if it just was ran on low pressure or if I should look for a suspension issue. The guy I got the car from said it was stock, but I am beginning to doubt his honesty and car care expertise. Thoughts? Thanks guys.
Nate
Ammadien is offline   Reply With Quote
Old 08-25-2009, 09:37 PM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
stock rims?
sniper1rfa is offline   Reply With Quote
Old 08-25-2009, 10:36 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
that tire is DONE
run flat and killed
Old 08-26-2009, 02:55 AM   #4
wakeboard_dude5
Member#: 213051
2004 WRX Wagon
Not too sure if it was run flat from pictures but i DO see cords. It almost seems like there was contact with the body. My vote goes to getting suspension/alignment checked out
wakeboard_dude5 is offline   Reply With Quote
Old 08-26-2009, 06:10 AM   #5
Ammadien
Member#: 100370
2005 Stage 2 sti
Originally Posted by sniper1rfa View Post
stock rims?
Yep. Stock sized rubber as well.
I was afraid it was shot. Thanks for the replies everybody.
Nate
Old 08-26-2009, 10:23 AM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....btw, being 15 PSI low in one tire should have been an obvious sign something was wrong.
Kean is offline   Reply With Quote
Old 08-26-2009, 11:05 AM   #7
Badler
Member#: 133597
Wait, you checked it. Saw it was 15lbs low, AND continued to track/drive it for days? Nice.
Badler is online now   Reply With Quote
Old 08-26-2009, 11:24 AM   #8
WeldingHank
Member#: 98645
2002 WRX Wagon
steel belt separation. dump the tire and match it or get 4 new ones.
on another note, keep an eye on your pressures.
WeldingHank is offline   Reply With Quote
Old 08-26-2009, 10:00 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Wow... it was low by 15psi and that didn't even phase you? How hard is it to air up a tire? Plus - with that much of a drop, either you have a nail or something in the tire or someone is being mean and let the air out for you...
You are very lucky you didn't hurt yourself or someone else. I'm guessing the region worn down to the cords is from riding essentially on the rim... how can you have a front tire that low and not notice that something was very wrong while driving?
Inner tire wear from the inside of the tire pharo Tire & Wheel 28 10-17-2009 08:38 AM
Layer of ice on inside of windshield aimetti New England Impreza Club Forum -- NESIC 4 03-03-2006 10:00 AM
tire rubbing on inside of fender josh...just josh Tire & Wheel 4 10-24-2005 01:35 AM
Help! Excessive grease on inside of front passenger rim! Jademonkey Brakes, Steering & Suspension 9 03-26-2002 04:38 PM
('93-'01) How do I clean inside of rims? Tim Sanderson Impreza Forum 10 06-11-2001 12:16 AM
